Duplicate entries in library following imports folder reorganization
I used to have multiple Personal Media Import folders defined for TV Shows. I moved all of the files under a single folder and then removed the definitions for the empty folders. Next I did a Scan Personal Media. All of the files are stream links if this matters.
Following this change and scan, I now have two entries in my library for each stream link. I'm able to play the stream link. After playing it I delete the first entry and it goes away yet the second remains. How do I clean this up?
Diagnostics submitted f6fe46b1-b498-4fd5-9380-b410ff488cc1
What do you mean by "removed the definitions for the empty folders"
Removed from the list of import folders. One can define as many as you like. The used to point to multiple SMB shares. Now just one for TV imports
OK. So if you removed it from Channels DVR Sources here
It will remove the Channels DVR database entries for those Imports.
That is what I expected. It did not.
Try a Prune Deleted, followed by a Rescan.
Tried that yesterday. Did not help
Can you find one that's duplicated and see what directory Channels DVR thinks they're in?
It shows them all in the SMB share that I'm pointing to. I see the duplicates in this listing.
My log is full of these errors:
2025/03/09 17:52:37.094941 error loading snapshot epoch: 205115: error opening segment 123425: error loading segment fromt directory: open recorder.idx\files\00000001e221.seg: The system cannot find the file specified.
2025/03/09 17:52:37.100630 error loading snapshot epoch: 5694: error opening segment 3484: error loading segment fromt directory: open recorder.idx\groups\000000000d9c.seg: The system cannot find the file specified.
2025/03/09 17:52:37.108285 error loading snapshot epoch: 205115: error opening segment 123425: error loading segment fromt directory: open recorder.idx\files\00000001e221.seg: The system cannot find the file specified.
2025/03/09 17:52:37.114224 error loading snapshot epoch: 5694: error opening segment 3484: error loading segment fromt directory: open recorder.idx\groups\000000000d9c.seg: The system cannot find the file specified.
2025/03/09 17:53:37.196297 error loading snapshot epoch: 205115: error opening segment 123425: error loading segment fromt directory: open recorder.idx\files\00000001e221.seg: The system cannot find the file specified.
2025/03/09 17:53:37.203098 error loading snapshot epoch: 5694: error opening segment 3484: error loading segment fromt directory: open recorder.idx\groups\000000000d9c.seg: The system cannot find the file specified.
2025/03/09 17:53:37.211735 error loading snapshot epoch: 205115: error opening segment 123425: error loading segment fromt directory: open recorder.idx\files\00000001e221.seg: The system cannot find the file specified.
2025/03/09 17:53:37.218190 error loading snapshot epoch: 5694: error opening segment 3484: error loading segment fromt directory: open recorder.idx\groups\000000000d9c.seg: The system cannot find the file specified.
2025/03/09 17:57:49.263552 error loading snapshot epoch: 205115: error opening segment 123425: error loading segment fromt directory: open recorder.idx\files\00000001e221.seg: The system cannot find the file specified.
2025/03/09 17:57:49.267927 error loading snapshot epoch: 5694: error opening segment 3484: error loading segment fromt directory: open recorder.idx\groups\000000000d9c.seg: The system cannot find the file specified.
2025/03/09 17:57:49.274165 error loading snapshot epoch: 205115: error opening segment 123425: error loading segment fromt directory: open recorder.idx\files\00000001e221.seg: The system cannot find the file specified.
2025/03/09 17:57:49.281916 error loading snapshot epoch: 5694: error opening segment 3484: error loading segment fromt directory: open recorder.idx\groups\000000000d9c.seg: The system cannot find the file specified.
Recreate search index
The closest thing I found to Recreate search index is under:
Library Database Manage your library database
Maintenance
Regenerate search index
I still have the duplicates
TMM1: What do you think of doing this:
  • Remove the TV Show Folder which is an SMB share from my configuration
  • Delete all of the programs
  • Attach the SMB share
  • Scan Personal Media
Any risk and do you think this will work?
Your DVR storage location is set to:
\\nas.\dvr\DVR
Your imports location is set to:
\\NAS\dvr\DVR\Imports\Movies
technically this is wrong, because the Imports folders are scanned automatically.
so maybe you just need to remove your Personal Media settings and the duplicates will go away.
Yes, that was it.
Thank you
