Hi - using custom channels I think I am experiencing a bug. If I have two channels that are connected to the same EPG listing, only the first will display the channels properly in the guide. The second channel will display an empty timeline - this makes it so I am unable to schedule recordings on that channel. Any thoughts?
Please give more details about these custom channels and the EPG you are using. Did you inspect their channel IDs to see if things match, etc?
Additionally, please submit diagnostics from your Channels DVR Server web admin.
The chances are, the problem is with your custom channels source. Garbage in, garbage out.
