I currently have two different M3U sources supplying a few channels. I've configured the channel numbers in M3U4U to be the same across both sources, and applied the "stack duplicates by channel number" setting across all clients. I’m hoping that stacking duplicate channels will improve reliability, I just have some extra questions I couldn't find clarity on:
Can channels be stacked within a custom channel collection as well?
If I’m watching a live channel and the stream stalls, will Channels automatically switch to another source in real time? For example, after a certain number of interruptions, will it move to the next source on its own, or do I need to manually exit and try tuning again?
Does the same logic apply to recordings in progress?
Thanks in advance!
