Is there a way to have the DVR app bias selection to ATSC 3.0 Chanel’s for recording? The only way I can see to do this is to go into the pass and hard code the station number. I wish there was a way to have the DVR automatically biased to select the ATSC 3.0 station if it is available.
Have you tried favoring the ATSC 3.0 Channels.? and unfavor the regulars ?
I have them set as favorites. I’ll have to go through and unfavorite their counterparts. Thanks.
I didn’t realize this would affect the DVR channel selection.
Thanks.
How does the DVR pick which tuner to use to make a recording?
On the Channels DVR Server web admin, you can adjust the priority of your tuners to set the order in which they will be used for recording.
The DVR will always prefer favorited and HD channels first when multiple channels are available to record the same program. If the first tuner in the DVR’s list has a favorited channel, it will always be used for recording. If a matching HD channel is available on the first tuner, it will always be preferred for recording.
If no matching channel is on the first tuner, the same process is repeated for each subsequent tuner in the list.
