My girlfriend says this happens every week during the bachelor. It just freezes for a while then starts playing again. Only one tuner in use.
2017/03/06 19:59:30 [DVR] Starting job 1488859170-1 The Bachelor on ch=[104 4]
2017/03/06 19:59:30 [DVR] Waiting 1h0m59.984925917s until next job 1488862830-1
2017/03/06 19:59:30 [DVR] Recording for job 1488859170-1 from 1321E9A7 ch104 into "TV/The Bachelor/2017-03-06-1959 The Bachelor 2017-03-06 S21E11.mpg" for 1h0m59.98460158s
2017/03/06 20:07:46 [DVR] Job 1488859170-1 ended prematurely: 52m43.28673891s
2017/03/06 20:07:46 [DVR] Starting job 1488859170-1 The Bachelor on ch=[104 4]
2017/03/06 20:07:46 [DVR] Waiting 52m43.277848525s until next job 1488862830-1
2017/03/06 20:07:48 [DVR] Recording for job 1488859170-1 from 1321E9A7 ch104 into "TV/The Bachelor/2017-03-06-1959 The Bachelor 2017-03-06 S21E11.mpg" for 52m43.271918018s
2017/03/06 20:46:24 [DVR] Job 1488859170-1 ended prematurely: 14m5.585604115s
2017/03/06 20:46:24 [DVR] Starting job 1488859170-1 The Bachelor on ch=[104 4]
2017/03/06 20:46:24 [DVR] Waiting 14m5.571629368s until next job 1488862830-1
2017/03/06 20:46:29 [ERR] Failed to start stream on channel 104 via 1321E9A7: Get http://192.168.0.100:5004/auto/v104?duration=846: dial tcp 192.168.0.100:5004: i/o timeout
2017/03/06 20:46:29 [DVR] Error running job 1488859170-1: could not start stream on channels=[104]: Get http://192.168.0.100:5004/auto/v104?duration=846: dial tcp 192.168.0.100:5004: i/o timeout
2017/03/06 20:46:59 [DVR] Starting job 1488859170-1 The Bachelor on ch=[104 4]
2017/03/06 20:46:59 [DVR] Waiting 13m30.477137379s until next job 1488862830-1
2017/03/06 20:47:04 [ERR] Failed to start stream on channel 104 via 1321E9A7: Get http://192.168.0.100:5004/auto/v104?duration=811: dial tcp 192.168.0.100:5004: i/o timeout
2017/03/06 20:47:04 [DVR] Error running job 1488859170-1: could not start stream on channels=[104]: Get http://192.168.0.100:5004/auto/v104?duration=811: dial tcp 192.168.0.100:5004: i/o timeout
2017/03/06 20:47:34 [DVR] Starting job 1488859170-1 The Bachelor on ch=[104 4]
2017/03/06 20:47:34 [DVR] Waiting 12m55.462123053s until next job 1488862830-1
2017/03/06 20:47:39 [ERR] Failed to start stream on channel 104 via 1321E9A7: Get http://192.168.0.100:5004/auto/v104?duration=776: dial tcp 192.168.0.100:5004: i/o timeout
2017/03/06 20:47:39 [DVR] Error running job 1488859170-1: could not start stream on channels=[104]: Get http://192.168.0.100:5004/auto/v104?duration=776: dial tcp 192.168.0.100:5004: i/o timeout
2017/03/06 20:48:09 [DVR] Starting job 1488859170-1 The Bachelor on ch=[104 4]
2017/03/06 20:48:09 [DVR] Waiting 12m20.451802572s until next job 1488862830-1
2017/03/06 20:48:14 [ERR] Failed to start stream on channel 104 via 1321E9A7: Get http://192.168.0.100:5004/auto/v104?duration=741: dial tcp 192.168.0.100:5004: i/o timeout
2017/03/06 20:48:14 [DVR] Error running job 1488859170-1: could not start stream on channels=[104]: Get http://192.168.0.100:5004/auto/v104?duration=741: dial tcp 192.168.0.100:5004: i/o timeout
2017/03/06 20:48:44 [DVR] Starting job 1488859170-1 The Bachelor on ch=[104 4]
2017/03/06 20:48:44 [DVR] Waiting 11m45.441436755s until next job 1488862830-1
2017/03/06 20:48:49 [ERR] Failed to start stream on channel 104 via 1321E9A7: Get http://192.168.0.100:5004/auto/v104?duration=706: dial tcp 192.168.0.100:5004: i/o timeout
2017/03/06 20:48:49 [DVR] Error running job 1488859170-1: could not start stream on channels=[104]: Get http://192.168.0.100:5004/auto/v104?duration=706: dial tcp 192.168.0.100:5004: i/o timeout
2017/03/06 20:49:19 [DVR] Starting job 1488859170-1 The Bachelor on ch=[104 4]
2017/03/06 20:49:19 [DVR] Waiting 11m10.430900886s until next job 1488862830-1
2017/03/06 20:49:22 [ERR] Failed to start stream on channel 104 via 1321E9A7: Get http://192.168.0.100:5004/auto/v104?duration=671: dial tcp 192.168.0.100:5004: getsockopt: no route to host
2017/03/06 20:49:22 [DVR] Error running job 1488859170-1: could not start stream on channels=[104]: Get http://192.168.0.100:5004/auto/v104?duration=671: dial tcp 192.168.0.100:5004: getsockopt: no route to host
2017/03/06 20:49:52 [DVR] Starting job 1488859170-1 The Bachelor on ch=[104 4]
2017/03/06 20:49:52 [DVR] Waiting 10m37.414722537s until next job 1488862830-1
2017/03/06 20:49:57 [ERR] Failed to start stream on channel 104 via 1321E9A7: Get http://192.168.0.100:5004/auto/v104?duration=638: dial tcp 192.168.0.100:5004: i/o timeout
2017/03/06 20:49:57 [DVR] Error running job 1488859170-1: could not start stream on channels=[104]: Get http://192.168.0.100:5004/auto/v104?duration=638: dial tcp 192.168.0.100:5004: i/o timeout
2017/03/06 20:50:27 [DVR] Starting job 1488859170-1 The Bachelor on ch=[104 4]
2017/03/06 20:50:27 [DVR] Waiting 10m2.404420164s until next job 1488862830-1
2017/03/06 20:50:30 [ERR] Failed to start stream on channel 104 via 1321E9A7: Get http://192.168.0.100:5004/auto/v104?duration=603: dial tcp 192.168.0.100:5004: getsockopt: no route to host
2017/03/06 20:50:30 [DVR] Error running job 1488859170-1: could not start stream on channels=[104]: Get http://192.168.0.100:5004/auto/v104?duration=603: dial tcp 192.168.0.100:5004: getsockopt: no route to host
2017/03/06 20:51:00 [DVR] Starting job 1488859170-1 The Bachelor on ch=[104 4]
2017/03/06 20:51:00 [DVR] Waiting 9m29.386403351s until next job 1488862830-1
2017/03/06 20:51:05 [ERR] Failed to start stream on channel 104 via 1321E9A7: Get http://192.168.0.100:5004/auto/v104?duration=570: dial tcp 192.168.0.100:5004: i/o timeout
2017/03/06 20:51:05 [DVR] Error running job 1488859170-1: could not start stream on channels=[104]: Get http://192.168.0.100:5004/auto/v104?duration=570: dial tcp 192.168.0.100:5004: i/o timeout
2017/03/06 20:51:35 [DVR] Starting job 1488859170-1 The Bachelor on ch=[104 4]
2017/03/06 20:51:35 [DVR] Waiting 8m54.375022513s until next job 1488862830-1
2017/03/06 20:51:40 [ERR] Failed to start stream on channel 104 via 1321E9A7: Get http://192.168.0.100:5004/auto/v104?duration=535: dial tcp 192.168.0.100:5004: i/o timeout
2017/03/06 20:51:40 [DVR] Error running job 1488859170-1: could not start stream on channels=[104]: Get http://192.168.0.100:5004/auto/v104?duration=535: dial tcp 192.168.0.100:5004: i/o timeout
2017/03/06 20:52:10 [DVR] Starting job 1488859170-1 The Bachelor on ch=[104 4]
2017/03/06 20:52:10 [DVR] Waiting 8m19.358533504s until next job 1488862830-1
2017/03/06 20:52:15 [ERR] Failed to start stream on channel 104 via 1321E9A7: Get http://192.168.0.100:5004/auto/v104?duration=500: dial tcp 192.168.0.100:5004: i/o timeout
2017/03/06 20:52:15 [DVR] Error running job 1488859170-1: could not start stream on channels=[104]: Get http://192.168.0.100:5004/auto/v104?duration=500: dial tcp 192.168.0.100:5004: i/o timeout
2017/03/06 20:52:45 [DVR] Starting job 1488859170-1 The Bachelor on ch=[104 4]
2017/03/06 20:52:45 [DVR] Waiting 7m44.347777447s until next job 1488862830-1
2017/03/06 20:52:48 [DVR] Recording for job 1488859170-1 from 1321E9A7 ch104 into "TV/The Bachelor/2017-03-06-1959 The Bachelor 2017-03-06 S21E11.mpg" for 7m44.346799325s
