Every 2 or 3 days I find that the DVR has crashed on my Synology 918+. I can most times restart this from the Package Center occasionally though I need to restart the Synology device completely.
Here's part of the log file after the crash which continues with more goroutine statements.
Any help appreciated.
unexpected fault address 0x0
fatal error: fault
[signal SIGSEGV: segmentation violation code=0x80 addr=0x0 pc=0xc89bc3]
goroutine 11711 [running]:
runtime.throw(0x15efae9, 0x5)
runtime/panic.go:1116 +0x72 fp=0xc000eb7c58 sp=0xc000eb7c28 pc=0x436702
runtime.sigpanic()
runtime/signal_unix.go:702 +0x3cc fp=0xc000eb7c88 sp=0xc000eb7c58 pc=0x44d85c
github.com/grafov/m3u8.(*MediaPlaylist).Encode(0xc0009ce100, 0xc000a91d10)
github.com/grafov/[email protected]/writer.go:618 +0xdf3 fp=0xc000eb7eb0 sp=0xc000eb7c88 pc=0xc89bc3
github.com/fancybits/channels-server/dvr.(*m3u8Recorder).Generate(0xc0014f76c0, 0x1, 0x0, 0x0)
github.com/fancybits/channels-server/dvr/m3u8_recorder.go:90 +0x1d7 fp=0xc000eb7f60 sp=0xc000eb7eb0 pc=0x11261b7
github.com/fancybits/channels-server/dvr.(*m3u8Recorder).Generator(0xc0014f76c0)
github.com/fancybits/channels-server/dvr/m3u8_recorder.go:109 +0x8e fp=0xc000eb7fd8 sp=0xc000eb7f60 pc=0x11262de
runtime.goexit()
runtime/asm_amd64.s:1373 +0x1 fp=0xc000eb7fe0 sp=0xc000eb7fd8 pc=0x4698d1
created by github.com/fancybits/channels-server/dvr.newM3u8Recorder
github.com/fancybits/channels-server/dvr/m3u8_recorder.go:49 +0x126
