Hello Channels Community,
I recently downloaded the DVR to give it a try given the various fussiness I have been dealing with using Plex. Everything with the setup went super smooth which was great, however, after adding a few show passes one of them ended up adding itself twice (I noticed it when looking the list over after I added some shows). Thinking that maybe I did something wrong (however I didn't do it any different than the other shows which worked out fine) so I tried to delete one of the passes and when I did that the channels app on my Apple TV crashed out. Getting back into the app both passes were then deleted and re-adding the show worked as normal.
Has anyone else experienced this bug before? Is there anything I need to watch out for regarding how to set up DVR passes going forward? It was definitely a downer on what was otherwise a fairly smooth first night with the SW. Everything I read said Channels is supposed to "just work" and for the most part that has been true so far. However, running into a app crashing bug first thing wasn't a good first impression considering that type of behavior is what I was specifically trying to avoid given that this product has positioned itself as a premium offering...
I did submit the diagnostic logs via the ATV app and would appreciate any feedback from the support team. Thanks!
