If I have the DVR engine installed at two locations will it cause issues? Not complaining at all, I just had a missed recording yesterday and wanted to know if that was the issue. I installed the Engine at my Grandparents house for them to try out before they ditch their DVR boxes, it is running on Windows there and a Shield at my place. Both locations were set to record the same program using the same account login with separate DVR engines and I think it was what caused my recording to fail.
Unlikely. The Log will explain what happened.
Ok, that was just my first guess. I guess it was an communication issue between the Shield and Prime.
2017/09/09 23:20:09 [DVR] Starting job 1504997700-ch1275 College Football on ch=[1275]
2017/09/09 23:20:11 [ERR] Failed to start stream on channel 1275 via 131F8367: Get http://192.168.7.10:5004/auto/v1275?: dial tcp 192.168.7.10:5004: i/o timeout
2017/09/09 23:20:11 [DVR] Error running job 1504997700-ch1275 College Football: could not start stream on channels=[1275]: Get http://192.168.7.10:5004/auto/v1275?: dial tcp 192.168.7.10:5004: i/o timeout
