I reported this on 8/27 and never heard back...
In DVR AppleTV and iPad, episodes are not in correct order and seasons are sometimes not. Restarted apps and DVR many times no change. Example, Alfred Hitchcock season 5 episodes 27, 24, 23.
In the web gui, episodes are in order but season was not. Example, Alfred Hitchcock seasons: 1, 7, 6, 5.
This happened a few months ago, then was fixed, and now with the last Channels update (.26) is back again.
This is very annoying since you have to manually scan all episodes to watch in order, and ESPECIALLY a problem with 2 part episodes.
Again, this was the exact same error months ago, was fixed by and update, and now badly broken again.
Another observation: some shows did not have episode information nut had air dates, this shows used to be in order by air date. Not anymore, this should also be fixed.
