DVR Errors, apps not opening
Hi,
I'm getting the below errors in the dvr log. I'm running the dvr in docker. I had an ISP issue earlier which has been resolved but now I can't seem to open up any of my channels apps and have errors in the log. I've tried restarting and recreating the container but get the same issues. Any help appreciated!
2019/11/14 19:46:31 [SYS] Starting Channels DVR v2019.11.14.0115 (linux-x86_64 pid:1) in /channels-dvr/data
2019/11/14 19:46:31 [HDR] Found 1 devices
2019/11/14 19:46:32 [SYS] Started HTTP Server
2019/11/14 19:46:32 [DVR] Recording engine started in /shares/DVR/Recordings/Channels
2019/11/14 19:46:32 [SYS] Bonjour service running for dvr-linuxserv.local. [192.168.1.254 172.30.32.1]
2019/11/14 19:46:32 [NAT] Successfully mapped port 8089 using natpmp
2019/11/14 19:46:32 [CACHE] Deleted cache for already deleted file 11
2019/11/14 19:46:33 [SYS] Created database snapshot: backup-20191114.194633
2019/11/14 19:46:33 [SYS] Removing old backup backup-20191012.171634
2019/11/14 19:46:43 [IDX] Pruned 8 expired airings from GBR-1001670-DEFAULT in 47.136937ms.
2019/11/14 19:47:50 [ERR] Failed to fetch station 97331: Get http://data.tmsapi.com/v1.1/stations/97331?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:47:55 [ERR] Failed to fetch station 30644: Get http://data.tmsapi.com/v1.1/stations/30644?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:48:20 [ERR] Failed to fetch station 97331: Get http://data.tmsapi.com/v1.1/stations/97331?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:48:25 [ERR] Failed to fetch station 30644: Get http://data.tmsapi.com/v1.1/stations/30644?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:48:37 [ERR] Failed to fetch station 30644: Get http://data.tmsapi.com/v1.1/stations/30644?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:48:41 [ERR] Failed to fetch station 30644: Get http://data.tmsapi.com/v1.1/stations/30644?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:48:44 [SYS] Shutting down...
2019/11/14 19:48:44 [SYS] Bonjour service stopped.
2019/11/14 19:48:44 [DVR] Recording engine stopped.
2019/11/14 19:48:45 [SYS] Goodbye.
2019/11/14 19:48:50 [SYS] Starting Channels DVR v2019.11.14.0115 (linux-x86_64 pid:1) in /channels-dvr/data
2019/11/14 19:48:50 [HDR] Found 1 devices
2019/11/14 19:48:52 [SYS] Started HTTP Server
2019/11/14 19:48:52 [DVR] Recording engine started in /shares/DVR/Recordings/Channels
2019/11/14 19:48:52 [SYS] Bonjour service running for dvr-linuxserv.local. [192.168.1.254 172.30.32.1]
2019/11/14 19:48:52 [NAT] Successfully mapped port 8089 using natpmp
2019/11/14 19:48:52 [CACHE] Deleted cache for already deleted file 11
2019/11/14 19:48:53 [SYS] Created database snapshot: backup-20191114.194853
2019/11/14 19:48:53 [SYS] Removing old backup backup-20191013.093622
2019/11/14 19:49:02 [IDX] Pruned 0 expired airings from GBR-1001670-DEFAULT in 467.733µs.
2019/11/14 19:50:32 [ERR] Failed to fetch station 97330: Get http://data.tmsapi.com/v1.1/stations/97330?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:50:40 [ERR] Failed to fetch station 30644: Get http://data.tmsapi.com/v1.1/stations/30644?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:50:56 [ERR] Failed to fetch station 30644: Get http://data.tmsapi.com/v1.1/stations/30644?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:51:02 [ERR] Failed to fetch station 97330: Get http://data.tmsapi.com/v1.1/stations/97330?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:51:04 [ERR] Failed to fetch station 30644: Get http://data.tmsapi.com/v1.1/stations/30644?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:51:10 [ERR] Failed to fetch station 68086: Get http://data.tmsapi.com/v1.1/stations/68086?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:51:26 [ERR] Failed to fetch station 30644: Get http://data.tmsapi.com/v1.1/stations/30644?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:51:32 [ERR] Failed to fetch station 89562: Get http://data.tmsapi.com/v1.1/stations/89562?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:51:34 [ERR] Failed to fetch station 30644: Get http://data.tmsapi.com/v1.1/stations/30644?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:51:34 [ERR] Failed to fetch station 68086: Get http://data.tmsapi.com/v1.1/stations/68086?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:51:40 [ERR] Failed to fetch station 17468: Get http://data.tmsapi.com/v1.1/stations/17468?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:51:56 [ERR] Failed to fetch station 68086: Get http://data.tmsapi.com/v1.1/stations/68086?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:52:02 [ERR] Failed to fetch station 89562: Get http://data.tmsapi.com/v1.1/stations/89562?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:52:04 [ERR] Failed to fetch station 68086: Get http://data.tmsapi.com/v1.1/stations/68086?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:52:04 [ERR] Failed to fetch station 17468: Get http://data.tmsapi.com/v1.1/stations/17468?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:52:10 [ERR] Failed to fetch station 17155: Get http://data.tmsapi.com/v1.1/stations/17155?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:52:26 [ERR] Failed to fetch station 68086: Get http://data.tmsapi.com/v1.1/stations/68086?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:52:32 [ERR] Failed to fetch station 17157: Get http://data.tmsapi.com/v1.1/stations/17157?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:52:34 [ERR] Failed to fetch station 17155: Get http://data.tmsapi.com/v1.1/stations/17155?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:52:34 [ERR] Failed to fetch station 68086: Get http://data.tmsapi.com/v1.1/stations/68086?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:52:40 [ERR] Failed to fetch station 17157: Get http://data.tmsapi.com/v1.1/stations/17157?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:52:56 [ERR] Failed to fetch station 17468: Get http://data.tmsapi.com/v1.1/stations/17468?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:53:02 [ERR] Failed to fetch station 17157: Get http://data.tmsapi.com/v1.1/stations/17157?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:53:04 [ERR] Failed to fetch station 17157: Get http://data.tmsapi.com/v1.1/stations/17157?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:53:04 [ERR] Failed to fetch station 17468: Get http://data.tmsapi.com/v1.1/stations/17468?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:53:10 [ERR] Failed to fetch station 20630: Get http://data.tmsapi.com/v1.1/stations/20630?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:53:26 [ERR] Failed to fetch station 17468: Get http://data.tmsapi.com/v1.1/stations/17468?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:53:32 [ERR] Failed to fetch station 87840: Get http://data.tmsapi.com/v1.1/stations/87840?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:53:34 [ERR] Failed to fetch station 17468: Get http://data.tmsapi.com/v1.1/stations/17468?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:53:34 [ERR] Failed to fetch station 20630: Get http://data.tmsapi.com/v1.1/stations/20630?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:53:40 [ERR] Failed to fetch station 89512: Get http://data.tmsapi.com/v1.1/stations/89512?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:53:56 [ERR] Failed to fetch station 17155: Get http://data.tmsapi.com/v1.1/stations/17155?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:54:02 [ERR] Failed to fetch station 87840: Get http://data.tmsapi.com/v1.1/stations/87840?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:54:04 [ERR] Failed to fetch station 89512: Get http://data.tmsapi.com/v1.1/stations/89512?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:54:04 [ERR] Failed to fetch station 17155: Get http://data.tmsapi.com/v1.1/stations/17155?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:54:10 [ERR] Failed to fetch station 84926: Get http://data.tmsapi.com/v1.1/stations/84926?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:54:26 [ERR] Failed to fetch station 17155: Get http://data.tmsapi.com/v1.1/stations/17155?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:54:32 [ERR] Failed to fetch station 83282: Get http://data.tmsapi.com/v1.1/stations/83282?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:54:34 [ERR] Failed to fetch station 84926: Get http://data.tmsapi.com/v1.1/stations/84926?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:54:34 [ERR] Failed to fetch station 17155: Get http://data.tmsapi.com/v1.1/stations/17155?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:54:40 [ERR] Failed to fetch station 20684: Get http://data.tmsapi.com/v1.1/stations/20684?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:54:56 [ERR] Failed to fetch station 17157: Get http://data.tmsapi.com/v1.1/stations/17157?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:55:02 [ERR] Failed to fetch station 83282: Get http://data.tmsapi.com/v1.1/stations/83282?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:55:04 [ERR] Failed to fetch station 20684: Get http://data.tmsapi.com/v1.1/stations/20684?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:55:04 [ERR] Failed to fetch station 17157: Get http://data.tmsapi.com/v1.1/stations/17157?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:55:10 [ERR] Failed to fetch station 44643: Get http://data.tmsapi.com/v1.1/stations/44643?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:55:26 [ERR] Failed to fetch station 17157: Get http://data.tmsapi.com/v1.1/stations/17157?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:55:32 [ERR] Failed to fetch station 97332: Get http://data.tmsapi.com/v1.1/stations/97332?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:55:34 [ERR] Failed to fetch station 44643: Get http://data.tmsapi.com/v1.1/stations/44643?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:55:34 [ERR] Failed to fetch station 17157: Get http://data.tmsapi.com/v1.1/stations/17157?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:55:39 [ERR] Failed to fetch station 30644: Get http://data.tmsapi.com/v1.1/stations/30644?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:55:39 [ERR] Failed to fetch station 17468: Get http://data.tmsapi.com/v1.1/stations/17468?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:55:40 [ERR] Failed to fetch station 48021: Get http://data.tmsapi.com/v1.1/stations/48021?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:55:56 [ERR] Failed to fetch station 20630: Get http://data.tmsapi.com/v1.1/stations/20630?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:56:02 [ERR] Failed to fetch station 97332: Get http://data.tmsapi.com/v1.1/stations/97332?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:56:04 [ERR] Failed to fetch station 48021: Get http://data.tmsapi.com/v1.1/stations/48021?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:56:04 [ERR] Failed to fetch station 20630: Get http://data.tmsapi.com/v1.1/stations/20630?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:56:09 [ERR] Failed to fetch station 68086: Get http://data.tmsapi.com/v1.1/stations/68086?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:56:09 [ERR] Failed to fetch station 30644: Get http://data.tmsapi.com/v1.1/stations/30644?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:56:09 [ERR] Failed to fetch station 17468: Get http://data.tmsapi.com/v1.1/stations/17468?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:56:10 [ERR] Failed to fetch station 62391: Get http://data.tmsapi.com/v1.1/stations/62391?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:56:26 [ERR] Failed to fetch station 20630: Get http://data.tmsapi.com/v1.1/stations/20630?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:56:32 [ERR] Failed to fetch station 24452: Get http://data.tmsapi.com/v1.1/stations/24452?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:56:34 [ERR] Failed to fetch station 20630: Get http://data.tmsapi.com/v1.1/stations/20630?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:56:34 [ERR] Failed to fetch station 62391: Get http://data.tmsapi.com/v1.1/stations/62391?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:56:39 [ERR] Failed to fetch station 17468: Get http://data.tmsapi.com/v1.1/stations/17468?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:56:39 [ERR] Failed to fetch station 68086: Get http://data.tmsapi.com/v1.1/stations/68086?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:56:39 [ERR] Failed to fetch station 29067: Get http://data.tmsapi.com/v1.1/stations/29067?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:56:40 [ERR] Failed to fetch station 25117: Get http://data.tmsapi.com/v1.1/stations/25117?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:56:56 [ERR] Failed to fetch station 89512: Get http://data.tmsapi.com/v1.1/stations/89512?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:57:02 [ERR] Failed to fetch station 24452: Get http://data.tmsapi.com/v1.1/stations/24452?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:57:04 [ERR] Failed to fetch station 89512: Get http://data.tmsapi.com/v1.1/stations/89512?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:57:04 [ERR] Failed to fetch station 25117: Get http://data.tmsapi.com/v1.1/stations/25117?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:57:09 [ERR] Failed to fetch station 17155: Get http://data.tmsapi.com/v1.1/stations/17155?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:57:09 [ERR] Failed to fetch station 68086: Get http://data.tmsapi.com/v1.1/stations/68086?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:57:09 [ERR] Failed to fetch station 29067: Get http://data.tmsapi.com/v1.1/stations/29067?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:57:10 [ERR] Failed to fetch station 21494: Get http://data.tmsapi.com/v1.1/stations/21494?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:57:26 [ERR] Failed to fetch station 89512: Get http://data.tmsapi.com/v1.1/stations/89512?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:57:32 [ERR] Failed to fetch station 98366: Get http://data.tmsapi.com/v1.1/stations/98366?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:57:34 [ERR] Failed to fetch station 89512: Get http://data.tmsapi.com/v1.1/stations/89512?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:57:34 [ERR] Failed to fetch station 21494: Get http://data.tmsapi.com/v1.1/stations/21494?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:57:39 [ERR] Failed to fetch station 17157: Get http://data.tmsapi.com/v1.1/stations/17157?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:57:39 [ERR] Failed to fetch station 17468: Get http://data.tmsapi.com/v1.1/stations/17468?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:57:39 [ERR] Failed to fetch station 24437: Get http://data.tmsapi.com/v1.1/stations/24437?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:57:40 [ERR] Failed to fetch station 56892: Get http://data.tmsapi.com/v1.1/stations/56892?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:57:56 [ERR] Failed to fetch station 84926: Get http://data.tmsapi.com/v1.1/stations/84926?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:58:02 [ERR] Failed to fetch station 98366: Get http://data.tmsapi.com/v1.1/stations/98366?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:58:04 [ERR] Failed to fetch station 84926: Get http://data.tmsapi.com/v1.1/stations/84926?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:58:04 [ERR] Failed to fetch station 56892: Get http://data.tmsapi.com/v1.1/stations/56892?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:58:09 [ERR] Failed to fetch station 20630: Get http://data.tmsapi.com/v1.1/stations/20630?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:58:09 [ERR] Failed to fetch station 17468: Get http://data.tmsapi.com/v1.1/stations/17468?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:58:09 [ERR] Failed to fetch station 24437: Get http://data.tmsapi.com/v1.1/stations/24437?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:58:10 [ERR] Failed to fetch station 21810: Get http://data.tmsapi.com/v1.1/stations/21810?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:58:26 [ERR] Failed to fetch station 84926: Get http://data.tmsapi.com/v1.1/stations/84926?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:58:32 [ERR] Failed to fetch station 30644: Get http://data.tmsapi.com/v1.1/stations/30644?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:58:34 [ERR] Failed to fetch station 84926: Get http://data.tmsapi.com/v1.1/stations/84926?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:58:34 [ERR] Failed to fetch station 21810: Get http://data.tmsapi.com/v1.1/stations/21810?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:58:39 [ERR] Failed to fetch station 89512: Get http://data.tmsapi.com/v1.1/stations/89512?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:58:39 [ERR] Failed to fetch station 17155: Get http://data.tmsapi.com/v1.1/stations/17155?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:58:39 [ERR] Failed to fetch station 25605: Get http://data.tmsapi.com/v1.1/stations/25605?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:58:40 [ERR] Failed to fetch station 45828: Get http://data.tmsapi.com/v1.1/stations/45828?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:58:56 [ERR] Failed to fetch station 20684: Get http://data.tmsapi.com/v1.1/stations/20684?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:59:02 [ERR] Failed to fetch station 30644: Get http://data.tmsapi.com/v1.1/stations/30644?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:59:04 [ERR] Failed to fetch station 45828: Get http://data.tmsapi.com/v1.1/stations/45828?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:59:04 [ERR] Failed to fetch station 20684: Get http://data.tmsapi.com/v1.1/stations/20684?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:59:09 [ERR] Failed to fetch station 84926: Get http://data.tmsapi.com/v1.1/stations/84926?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:59:09 [ERR] Failed to fetch station 17155: Get http://data.tmsapi.com/v1.1/stations/17155?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:59:09 [ERR] Failed to fetch station 25605: Get http://data.tmsapi.com/v1.1/stations/25605?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:59:10 [ERR] Failed to fetch station 47657: Get http://data.tmsapi.com/v1.1/stations/47657?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:59:26 [ERR] Failed to fetch station 20684: Get http://data.tmsapi.com/v1.1/stations/20684?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:59:32 [ERR] Failed to fetch station 110920: Get http://data.tmsapi.com/v1.1/stations/110920?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:59:34 [ERR] Failed to fetch station 47657: Get http://data.tmsapi.com/v1.1/stations/47657?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:59:34 [ERR] Failed to fetch station 20684: Get http://data.tmsapi.com/v1.1/stations/20684?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:59:39 [ERR] Failed to fetch station 20684: Get http://data.tmsapi.com/v1.1/stations/20684?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:59:39 [ERR] Failed to fetch station 17157: Get http://data.tmsapi.com/v1.1/stations/17157?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:59:39 [ERR] Failed to fetch station 24440: Get http://data.tmsapi.com/v1.1/stations/24440?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:59:40 [ERR] Failed to fetch station 24305: Get http://data.tmsapi.com/v1.1/stations/24305?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 19:59:56 [ERR] Failed to fetch station 44643: Get http://data.tmsapi.com/v1.1/stations/44643?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 20:00:02 [ERR] Failed to fetch station 110920: Get http://data.tmsapi.com/v1.1/stations/110920?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 20:00:04 [ERR] Failed to fetch station 44643: Get http://data.tmsapi.com/v1.1/stations/44643?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 20:00:04 [ERR] Failed to fetch station 24305: Get http://data.tmsapi.com/v1.1/stations/24305?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 20:00:09 [ERR] Failed to fetch station 44643: Get http://data.tmsapi.com/v1.1/stations/44643?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 20:00:09 [ERR] Failed to fetch station 17157: Get http://data.tmsapi.com/v1.1/stations/17157?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 20:00:09 [ERR] Failed to fetch station 24440: Get http://data.tmsapi.com/v1.1/stations/24440?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 20:00:10 [ERR] Failed to fetch station 82575: Get http://data.tmsapi.com/v1.1/stations/82575?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 20:00:26 [ERR] Failed to fetch station 44643: Get http://data.tmsapi.com/v1.1/stations/44643?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 20:00:32 [ERR] Failed to fetch station 44718: Get http://data.tmsapi.com/v1.1/stations/44718?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 20:00:34 [ERR] Failed to fetch station 44643: Get http://data.tmsapi.com/v1.1/stations/44643?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 20:00:34 [ERR] Failed to fetch station 82575: Get http://data.tmsapi.com/v1.1/stations/82575?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 20:00:39 [ERR] Failed to fetch station 48021: Get http://data.tmsapi.com/v1.1/stations/48021?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 20:00:39 [ERR] Failed to fetch station 20630: Get http://data.tmsapi.com/v1.1/stations/20630?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 20:00:39 [ERR] Failed to fetch station 98986: Get http://data.tmsapi.com/v1.1/stations/98986?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 20:00:40 [ERR] Failed to fetch station 52335: Get http://data.tmsapi.com/v1.1/stations/52335?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 20:00:56 [ERR] Failed to fetch station 48021: Get http://data.tmsapi.com/v1.1/stations/48021?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 20:01:02 [ERR] Failed to fetch station 44718: Get http://data.tmsapi.com/v1.1/stations/44718?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 20:01:04 [ERR] Failed to fetch station 48021: Get http://data.tmsapi.com/v1.1/stations/48021?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 20:01:04 [ERR] Failed to fetch station 52335: Get http://data.tmsapi.com/v1.1/stations/52335?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 20:01:09 [ERR] Failed to fetch station 62391: Get http://data.tmsapi.com/v1.1/stations/62391?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 20:01:09 [ERR] Failed to fetch station 20630: Get http://data.tmsapi.com/v1.1/stations/20630?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 20:01:09 [ERR] Failed to fetch station 98986: Get http://data.tmsapi.com/v1.1/stations/98986?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 20:01:10 [ERR] Failed to fetch station 110927: Get http://data.tmsapi.com/v1.1/stations/110927?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 20:01:26 [ERR] Failed to fetch station 48021: Get http://data.tmsapi.com/v1.1/stations/48021?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 20:01:32 [ERR] Failed to fetch station 30166: Get http://data.tmsapi.com/v1.1/stations/30166?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 20:01:34 [ERR] Failed to fetch station 48021: Get http://data.tmsapi.com/v1.1/stations/48021?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 20:01:34 [ERR] Failed to fetch station 110927: Get http://data.tmsapi.com/v1.1/stations/110927?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 20:01:39 [ERR] Failed to fetch station 25117: Get http://data.tmsapi.com/v1.1/stations/25117?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 20:01:39 [ERR] Failed to fetch station 89512: Get http://data.tmsapi.com/v1.1/stations/89512?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
2019/11/14 20:01:39 [ERR] Failed to fetch station 52336: Get http://data.tmsapi.com/v1.1/stations/52336?api_key=x26sg2rpk8qyuyn9ddzwmsuu&lineupId=: dial tcp 172.97.66.215:80: i/o timeout
What happens in the app?
Make sure the host and docker ip and dns are correct
Definitely looks like a network issue. From the logs it appears that your DVR server is having problems receiving data from the servers/addresses that Channels receives its guide data from.
Can you remote into the server? If so, can you access outside your local network from the server's host?
Nothing happens in the app, just purple screen with a spinning wheel. I'm runnning channels on the host but it seems that the host network has been disbled for some reason so wondering if that might be the cause of the issue.....
Ok everything is back working but the errors keep appearing in the log....
Could be a firewall issue. What is the docker host OS? Can you ping google.com from there?
Docker host OS is Ubuntu, can ping google from inside the container...
64 bytes from 172.217.9.206: seq=0 ttl=52 time=95.229 ms
and from Ubuntu
64 bytes from iad23s59-in-f14.1e100.net (172.217.8.14): icmp_seq=17 ttl=52 time=90.9 ms
Now seem to have an issue with my HDHomerun not showing up and just getting a spnning wheel. I can access it through VLC but cannot add it manually to channels. Appreciate the help so far!
Seems like some sort of docker networking issue.
What does this command show:
host data.tmsapi.com
Is the netmask set correctly for this interface?
172.16.0.0/12 (172.16.0.0–172.31.255.255) is the reserved, private IP range.
I get
/ # host data.tmsapi.com
sh: host: not found
when I exec into the container
If I do it from linux terminal I get
matt@linuxserv:~$ host data.tmsapi.com
data.tmsapi.com has address 172.97.66.215
data.tmsapi.com is an alias for tms.api.mashery.com.
tms.api.mashery.com is an alias for td-tms.mashery.com.
td-tms.mashery.com is an alias for feeds-tmsapi-com-j-928317298.us-west-1.elb.amazonaws.com.
Definitely a network issue with your Docker container then.
Unfortunately, I'm unfamiliar with Docker, so I can't really help you more. For general configuration, or if Docker uses networkd, I may be able to help.
Thanks for the responses, appreciate it!
Thanks for this. Would you know how to check this as I’m a little unsure?
Sorry, no. Only if you're on my network and I'm your admin.
I don't support Ubunto or Docker. Reply was regarding basic ip v4 netmask, nothing specific to Ubunto or Docker. Check with your Network Administrator, your OS Help Desk, or your favourite web search engine.
So the issue seems to have worked itself out, not ideal from a figuring out what the issue was point of view but I'm now seeing duplication of other issues in the log, as below, any idea what is causing this? THe recording opened and started playing but the live tv (through web dvr) didnt.
019/11/15 11:39:35 [TNR] Opened connection to 12503076/0 for ch101 BBC ONE HD
2019/11/15 11:39:36 [HLS] Probed live stream in 767.248257ms: h264 1920x1080 progressive 2516699bps
2019/11/15 11:39:36 [HLS] Starting transcoder for channel 101 from 172.21.0.10 (encoder=remux, resolution=, deinterlacer=, bitrate=10000)
[h264 @ 0x2479cc0] mmco: unref short failure
Last message repeated 1 times
[h264 @ 0x2479cc0] Increasing reorder buffer to 3
2019/11/15 11:39:51 [HLS] Stopping transcoder session ch101-dANY-ip172.21.0.10 @ 14s
2019/11/15 11:39:51 [TNR] Closed connection to 12503076/0 for ch101 BBC ONE HD
2019/11/15 11:39:57 [ENC] Starting encoder for His Dark Materials S01E02 The Idea of North 2019-11-10-2000.mpg in /shares/DVR/Recordings/Channels/Streaming/file447-ip172.21.0.10/encoder-10-516221983 at 10 (15.416433) (encoder=h264_vaapi, resolution=384, deinterlacer=hardware, bitrate=686 segment_size=1)
[h264 @ 0x2dca440] mmco: unref short failure
[h264 @ 0x2dca440] reference picture missing during reorder
[h264 @ 0x2dca440] Missing reference picture, default is 2147483647
[mpegts @ 0x2dc57c0] start time for stream 2 is not set in estimate_timings_from_pts
[mpegts @ 0x2dc57c0] start time for stream 4 is not set in estimate_timings_from_pts
[mpegts @ 0x2dc57c0] start time for stream 5 is not set in estimate_timings_from_pts
[mpegts @ 0x2dc57c0] start time for stream 6 is not set in estimate_timings_from_pts
[mpegts @ 0x2dc57c0] start time for stream 7 is not set in estimate_timings_from_pts
[mpegts @ 0x2dc57c0] Dropped corrupted packet (stream = 3)
[NULL @ 0x2dca440] illegal reordering_of_pic_nums_idc 19
[NULL @ 0x2dca440] illegal reordering_of_pic_nums_idc 15
[NULL @ 0x2dca440] reference count 1 overflow
[NULL @ 0x2dca440] chroma_log2_weight_denom 8 is out of range
[h264 @ 0x2e61300] mmco: unref short failure
Last message repeated 2 times
[h264 @ 0x301b340] Missing reference picture, default is 4
[h264 @ 0x301b340] Failed to begin picture decode issue: 6 (invalid VASurfaceID).
[h264 @ 0x301b340] hardware accelerator failed to decode picture: Input/output error
[h264 @ 0x3021780] Missing reference picture, default is 4
[h264 @ 0x3021780] Failed to begin picture decode issue: 6 (invalid VASurfaceID).
[h264 @ 0x3021780] hardware accelerator failed to decode picture: Input/output error
[h264 @ 0x2f6bbc0] Missing reference picture, default is 4
[h264 @ 0x2f6bbc0] Failed to begin picture decode issue: 6 (invalid VASurfaceID).
[h264 @ 0x2f6bbc0] hardware accelerator failed to decode picture: Input/output error
Error while decoding stream #0:0: Input/output error
2019/11/15 11:39:59 [ENC] Request for 12 is for different transcoding parameters at 904kbps
2019/11/15 11:39:59 [ENC] Stopped encoder for His Dark Materials S01E02 The Idea of North 2019-11-10-2000.mpg in /shares/DVR/Recordings/Channels/Streaming/file447-ip172.21.0.10/encoder-10-516221983 after encoding 10 to 13
2019/11/15 11:39:59 [ENC] Starting encoder for His Dark Materials S01E02 The Idea of North 2019-11-10-2000.mpg in /shares/DVR/Recordings/Channels/Streaming/file447-ip172.21.0.10/encoder-12-134359284 at 12 (18.016433) (encoder=h264_vaapi, resolution=576, deinterlacer=hardware, bitrate=904 segment_size=1)
[h264 @ 0x2ddb440] mmco: unref short failure
[h264 @ 0x2ddb440] reference picture missing during reorder
[h264 @ 0x2ddb440] Missing reference picture, default is 2147483647
[mpegts @ 0x2dd67c0] start time for stream 2 is not set in estimate_timings_from_pts
[mpegts @ 0x2dd67c0] start time for stream 4 is not set in estimate_timings_from_pts
[mpegts @ 0x2dd67c0] start time for stream 5 is not set in estimate_timings_from_pts
[mpegts @ 0x2dd67c0] start time for stream 6 is not set in estimate_timings_from_pts
[mpegts @ 0x2dd67c0] start time for stream 7 is not set in estimate_timings_from_pts
[mpegts @ 0x2dd67c0] Dropped corrupted packet (stream = 3)
[NULL @ 0x2ddb440] illegal reordering_of_pic_nums_idc 19
[NULL @ 0x2ddb440] illegal reordering_of_pic_nums_idc 15
[NULL @ 0x2ddb440] reference count 1 overflow
[NULL @ 0x2ddb440] chroma_log2_weight_denom 8 is out of range
[h264 @ 0x2ef0400] mmco: unref short failure
[h264 @ 0x2f7cc40] mmco: unref short failure
2019/11/15 11:40:00 [ENC] Request for 12 is for different transcoding parameters at 343kbps
2019/11/15 11:40:00 [ENC] Stopped encoder for His Dark Materials S01E02 The Idea of North 2019-11-10-2000.mpg in /shares/DVR/Recordings/Channels/Streaming/file447-ip172.21.0.10/encoder-12-134359284 after starting from 12 without encoding any segments
2019/11/15 11:40:00 [ENC] Starting encoder for His Dark Materials S01E02 The Idea of North 2019-11-10-2000.mpg in /shares/DVR/Recordings/Channels/Streaming/file447-ip172.21.0.10/encoder-12-757197894 at 12 (18.016433) (encoder=h264_vaapi, resolution=384, deinterlacer=hardware, bitrate=343 segment_size=1)
[h264 @ 0x255a440] mmco: unref short failure
[h264 @ 0x255a440] reference picture missing during reorder
[h264 @ 0x255a440] Missing reference picture, default is 2147483647
[mpegts @ 0x25557c0] start time for stream 2 is not set in estimate_timings_from_pts
[mpegts @ 0x25557c0] start time for stream 4 is not set in estimate_timings_from_pts
[mpegts @ 0x25557c0] start time for stream 5 is not set in estimate_timings_from_pts
[mpegts @ 0x25557c0] start time for stream 6 is not set in estimate_timings_from_pts
[mpegts @ 0x25557c0] start time for stream 7 is not set in estimate_timings_from_pts
[mpegts @ 0x25557c0] Dropped corrupted packet (stream = 3)
[NULL @ 0x255a440] illegal reordering_of_pic_nums_idc 19
[NULL @ 0x255a440] illegal reordering_of_pic_nums_idc 15
[NULL @ 0x255a440] reference count 1 overflow
[NULL @ 0x255a440] chroma_log2_weight_denom 8 is out of range
[h264 @ 0x266f400] mmco: unref short failure
[h264 @ 0x26fbc40] mmco: unref short failure
2019/11/15 11:40:01 [ENC] Request for 14 is for different transcoding parameters at 686kbps
2019/11/15 11:40:01 [ENC] Stopped encoder for His Dark Materials S01E02 The Idea of North 2019-11-10-2000.mpg in /shares/DVR/Recordings/Channels/Streaming/file447-ip172.21.0.10/encoder-12-757197894 after encoding 12 to 13
2019/11/15 11:40:01 [ENC] Starting encoder for His Dark Materials S01E02 The Idea of North 2019-11-10-2000.mpg in /shares/DVR/Recordings/Channels/Streaming/file447-ip172.21.0.10/encoder-14-125041512 at 14 (21.936433) (encoder=h264_vaapi, resolution=384, deinterlacer=hardware, bitrate=686 segment_size=1)
[h264 @ 0x2b6f440] mmco: unref short failure
[h264 @ 0x2b6f440] reference picture missing during reorder
[h264 @ 0x2b6f440] Missing reference picture, default is 2147483647
[mpegts @ 0x2b6a7c0] start time for stream 2 is not set in estimate_timings_from_pts
[mpegts @ 0x2b6a7c0] start time for stream 4 is not set in estimate_timings_from_pts
[mpegts @ 0x2b6a7c0] start time for stream 5 is not set in estimate_timings_from_pts
[mpegts @ 0x2b6a7c0] start time for stream 6 is not set in estimate_timings_from_pts
[mpegts @ 0x2b6a7c0] start time for stream 7 is not set in estimate_timings_from_pts
[mpegts @ 0x2b6a7c0] Dropped corrupted packet (stream = 3)
[NULL @ 0x2b6f440] illegal reordering_of_pic_nums_idc 19
[NULL @ 0x2b6f440] illegal reordering_of_pic_nums_idc 15
[NULL @ 0x2b6f440] reference count 1 overflow
[NULL @ 0x2b6f440] chroma_log2_weight_denom 8 is out of range
[h264 @ 0x2c90040] mmco: unref short failure
[h264 @ 0x2cf4cc0] mmco: unref short failure
2019/11/15 11:40:02 [ENC] Stopped encoder for His Dark Materials S01E02 The Idea of North 2019-11-10-2000.mpg in /shares/DVR/Recordings/Channels/Streaming/file447-ip172.21.0.10/encoder-14-125041512 after encoding 14 to 14
The hardware transcoder is not working. You could switch to software instead.
Thanks, is that something I need to address my end? I am passing my intel processor through as it supports quicsync and it was working before (pretty sure)?
Saw your other comment about the reverse proxy. Thanks for this. I did have auth but disabled it when trying to figure out issues but will put it back up!
I haven't seen that "invalid VASurfaceID" message before.. maybe reboot the machine?
Might be worth trying outside docker too since your docker setup seems to having a lot of issues.
Are you merely passing /dev/dri through as a bind mount to the container image?
(For systemd-nspawn containers, I found that in addition to needing the /dev/dri bind mount, a DeviceAllow=char-drm rw was also needed.)
