DVR Finds No Tuners
The guide provider is different so we can’t easily copy the old profiles.
Instead I would like to provide some tools in the DVR UI to be able to adjust the channel mappings directly. Will take a look this weekend.
In the mean time you could select OTA as your guide source which should make the x.x channels work.
Sounds great. Thank you.
I’m seeing an issue where, every time there is an update installed, the manually entered tuner is lost. I have waited through several updates to confirm.
Sounds like a bug. The new “add manually” feature isn’t remembering tuners across restarts.
This has been fixed in DVR v2017.01.23.2004. You will need to add the tuner again after upgrading, but it should be remembered after that.
Thanks for that quick update. Are you still planning to add options in the web ui to match channels?
Yes still planned, although I don’t have an ETA yet.
The channel mapping fixup tool is almost ready. Let me know if you’d like to test it out.
win2012 r2/ HDHR3-CC. No tuners found, added manually, but only one tuner shown. Any idea how to add the rest?
That is the expected behavior. The list shows devices, not tuners. The language has been fixed for the next build.
Thank you. Why is just 2 shows recorded at the same time? I have 3 tuners
I’m not sure what you mean. Did you schedule three shows and only two recorded?
Sorry, now looks like this problem is solved. But I have another. If all tuners are busy with recording, and if I choose to watch the channel that currently recording I get [tuner unavailable].
I’d love to test it. Just let me know how.
Click the pencil icon in the hdhomerun section next to your DVR guide source.
