Dvr guide not found on Drobo
my dvr is not finding the guide from the cable provider when enter my Zip code
2017/07/02 15:39:10 [ERR] Failed to fetch guide providers: Get https://data.tmsapi.com/v1.1/lineups?api_key=x26sg2rpk8qyuyn9ddzwmsuu&country=usa&postalCode=3374&enhancedCallSign=true: x509: failed to load system roots and no roots provided
2017/07/02 15:39:28 [ERR] Failed to fetch guide providers: Get https://data.tmsapi.com/v1.1/lineups?api_key=x26sg2rpk8qyuyn9ddzwmsuu&country=usa&postalCode=07107&enhancedCallSign=true: x509: failed to load system roots and no roots provided
2017/07/02 15:42:52 [ERR] Failed to refresh auth: Post https://community.getchannels.com/dvr/api: x509: failed to load system roots and no roots provided
2017/07/02 15:47:28 [ERR] Failed to fetch guide providers: Get https://data.tmsapi.com/v1.1/lineups?api_key=x26sg2rpk8qyuyn9ddzwmsuu&country=usa&postalCode=07050&enhancedCallSign=true: x509: failed to load system roots and no roots provided
2017/07/02 15:49:10 [ERR] Failed to fetch guide providers: Get https://data.tmsapi.com/v1.1/lineups?api_key=x26sg2rpk8qyuyn9ddzwmsuu&country=usa&postalCode=07050&enhancedCallSign=true: x509: failed to load system roots and no roots provided
2017/07/02 15:56:13 [ERR] Failed to fetch guide providers: Get https://data.tmsapi.com/v1.1/lineups?api_key=x26sg2rpk8qyuyn9ddzwmsuu&country=usa&postalCode=07050&enhancedCallSign=true: x509: failed to load system roots and no roots provided
2017/07/02 15:56:30 [SYS] Error checking for update: Get https://channels-dvr.s3.amazonaws.com/latest.json: x509: failed to load system roots and no roots provided
2017/07/02 16:10:42 [ERR] Failed to fetch guide providers: Get https://data.tmsapi.com/v1.1/lineups?api_key=x26sg2rpk8qyuyn9ddzwmsuu&country=usa&postalCode=07050&enhancedCallSign=true: x509: failed to load system roots and no roots providedstrong text
Are you able to SSH into the drobo and run some commands?
ls -alh /etc/ssl/certs
Also which package did you use to install onto the Drobo?
The latest package is https://channels-dvr.s3.amazonaws.com/drobo/ChannelsDVR.tgz
Version
2017.06.07.0238
how to SSH into the drobo ?
I’m not sure off-hand, since I don’t have a Drobo. I think you may have installed a broken older package though, because this bug was fixed. Where did you find the drobo install instructions and package?
For ssh you can install “dropbear” app from the drobo dashboard.
Do you use a Mac or pc?
mac
Once you install Dropbear, open Terminal.app on your Mac.
Find the IP of your Drobo and type:
ssh root@IP – ls -alh /etc/ssl /etc/ssl/certs
And copy/paste all the output here.
thanks for your help i install the new package and now is everything is working fine.
Great!
