DVR not responding on qnap after latest betas
Hi guys,
Noticed over last two days using latest beta as at 26th May 21 18:41 the dvr keeps becoming unresponsive and can't access by ip address, all recordings are unaccessible until you log onto qnap and restart the dvr software. Has been working flawlessly for weeks, this just started after this latest beta...
Not sure if others are having issues or if devs are aware...
John
Please click Support > Submit Diagnostics on your DVR web UI
Logs submitted, b3d3f184-b33f-4a71-96f2-2cf3528886ae
Thanks John.
Thank you for letting us know about this. It should be fixed in v2021.05.26.1807
Channels is absolutely excellent. Reported a fault and within 15 mins update was pushed and fixed. This is why I'm a channels devoted fan... :slight_smile: :slight_smile: :slight_smile:
I am having the same problem on my synology also - I just downloaded the 2021.05.26.1807 update - maybe this will take care of it.
Fixed it for me, so far... :slight_smile:
