DVR on QNAS stops when trying to scan channels
I have Channels running on a QNAS. My only source is SlingTV.
Every time I attempt to sacn the channels from Sling the DVR halts and I have to restart it. I suspect this has something to do with TVE authorization but I can't troubleshoot it because the DVR keeps stopping.
2023/03/12 08:10:44.911410 [TVE] action=tvejs msg="scienceSelect: missing affiliate=Sling TV"
2023/03/12 08:10:46.328408 [TVE] action=tvejs msg="scienceSelect: path=/login-affiliates"
2023/03/12 08:10:47.348245 [TVE] action=tvejs msg="scienceSelect: missing affiliate=Sling TV"
2023/03/12 08:10:48.690220 [SYS] Shutting down...
2023/03/12 08:10:48.692478 [SYS] Bonjour service stopped.
2023/03/12 08:10:48.694071 [DVR] Recording engine stopped.
2023/03/12 08:10:48.809891 [TVE] action=tvejs msg="scienceSelect: path=/login-affiliates"
2023/03/12 08:10:49.694769 [SYS] Goodbye.
This means something is sending a shutdown signal.
Maybe some issue on your QNAP like memory running out
The QNAS reports 54% ram free.
Does troubleshooting tab show chrome update available?
No. I already updated it and still have the problem.
Can you scan one channel individually?
No. When I attempt that the box disappears and goes back to the Settings screen!
After numerous restarts the DVR has remained running during a scan. The scan is extremely slow - but finally completed.
