DVR playback crashes or says Transcode Finished
DVR on PR2100 has been great till the last two days now all recordings do not playback and immediately close, regardless of device I playback with
Check the Log tab of the DVR window to see what errors are shown.
Could not create backup: stat /shares/ChannelsDVR: no such file or directory
It seems your share with all your recordings is not accessible by the DVR anymore, which is why everything is failing to play.
Are you using a network mount or something? Or are the files local on your WD? Maybe you changed the name of the share?
I updated the share file on the WD and the first recording seems to be working fine. Will update if I have any other issues.
