I have my dvr recording folder set up on a pooled drive (using drive pool) it only shows 11gb
However my directory properties show 11tb free
The dvr folder is contained on the pooled e drive
any thoughts?
any thoughts?
I'm not familiar with pooled drives. What is the path you're using for the DVR?
We ask the system for free space available on that and report it up..
Here is the output
[{"device":"C:","mountpoint":"C:","fstype":"NTFS","opts":"rw.compress"},{"device":"D:","mountpoint":"D:","fstype":"NTFS","opts":"rw.compress"},{"device":"E:","mountpoint":"E:","fstype":"NTFS","opts":"rw.compress"}]
Your screenshot shows 11469GB = 11TB. So it's working correctly.
I guess I got confused because it shows 17% full and im only using about 47gb out of 13tb in the total pool for the dvr directory right now.
The windows screenshot shows 2.44 TB used, 11.2 TB free, 13.6 TB capacity.
2.44TB / 13.6 TB = 17.9%
Ahh I understand now, it's using the total pool used vs total pool free space. Giving the 17%
