DVR Recordings Not Completing
I am so frustrated. I have Directv Stream and any movie from the Hallmark Channel will not complete the full recording. The times that it stops varies from two minutes to 60 minutes etc. I played the partial recording and the quality is great.
What do your DVR logs say for the duration of the recording?
For a work around just set you end time long enough to make up for the glitches and you can skip or edit out the extra times later.
Yeah. Especially with TVE it’s not exactly real time, so my default setting is to record three minutes after the scheduled end time. This has never failed for me. May be overkill but it’s just a little bandwidth and disk.
I also do something similar with 3 minutes before and 5 minutes after.
