I have found a bug that my dvr is running on a mac mini older model that has worked perfect before. Now I can see that the dvr is running but it isn't recording shows at all. I cant even go to a show and hit record it will not record. I can still access all shows on the dvr remotely it just will not record. the log just stops and even though it is still running, it isn't logging anything. Here is the last couple logs
2019/04/21 07:59:30 [DVR] Recording for job 1555855170-64 from 1048CCBF ch7.1 into "TV/Saved by the Bell/Saved by the Bell S03E06 1990-10-13 Blind Dates 2019-04-21-0759.mpg" for 30m59.93618s
2019/04/21 08:29:29 [DVR] Waiting 52.053ms until next job 1555856970-64 Saved by the Bell
2019/04/21 08:29:30 [DVR] Starting job 1555856970-64 Saved by the Bell on ch=[7.1]
2019/04/21 08:29:30 [DVR] Waiting 29m59.942189s until next job 1555858770-64 Saved by the Bell
2019/04/21 08:29:30 [TNR] Sharing existing connection to 1048CCBF for ch7.1 (clients=2, len=0)
2019/04/21 08:29:30 [DVR] Recording for job 1555856970-64 from 1048CCBF ch7.1 into "TV/Saved by the Bell/Saved by the Bell S03E01 1990-09-08 The Prom 2019-04-21-0829.mpg" for 30m59.942142s
2019/04/21 08:30:30 [DVR] Finished job 1555855170-64 Saved by the Bell
2019/04/21 08:30:30 [DVR] Deleting expired job 1555855170-64 Saved by the Bell
2019/04/21 08:30:30 [DVR] Waiting 28m59.226819s until next job 1555858770-64 Saved by the Bell
2019/04/21 08:59:29 [DVR] Deleting expired job 1555855170-64 Saved by the Bell
2019/04/21 08:59:30 [DVR] Starting job 1555858770-64 Saved by the Bell on ch=[7.1]
2019/04/21 08:59:30 [DVR] Waiting 29m59.995871s until next job 1555860570-64 Saved by the Bell
2019/04/21 08:59:30 [TNR] Sharing existing connection to 1048CCBF for ch7.1 (clients=2, len=0)
2019/04/21 08:59:30 [DVR] Recording for job 1555858770-64 from 1048CCBF ch7.1 into "TV/Saved by the Bell/Saved by the Bell S03E16 1990-12-15 From Nurse to Worse 2019-04-21-0859.mpg" for 30m59.995826s
2019/04/21 09:00:29 [DVR] Job 1555856970-64 Saved by the Bell ended prematurely: 22.99ms
2019/04/21 09:00:30 [DVR] Deleting expired job 1555855170-64 Saved by the Bell
2019/04/21 09:00:30 [DVR] Deleting expired job 1555856970-64 Saved by the Bell
2019/04/21 09:05:05 [DVR] Deleting expired job 1555855170-64 Saved by the Bell.
here it shows that it is running
Version
2019.03.12.0544
Check For Update
Uptime
10 days
Started 04/20/2019
Timezone
MDT
Please help
