DVR Server connection not secure
Hi...I noticed my server is no longer encrypted and also noticed in the remote DVR section: Failed to map port using UPnP. Enable port forwarding for TCP port 8089 -> 8089 manually.
However, I can access fine externally. Channels DVR is runninig via Synology 220+ and have made no changes recently.
No errors under troubleshooting
On the recent prerelease: 2022.09.14.0104
Server logs: 5408ba6c-f906-4ed0-9159-ec06491d4be1
I did search for this recently so applogies if this was already posted.
Could you explain exactly how you are reaching your server, and how you came to this conclusion?
I do not think the server is actually exposed unprotected, and there may be some confusion that we could clear up.
Thanks...and to clarify, it's the browser URL , just noticed the icon next to the URL that connection is not secure. I don't recall seeing that before and started reviewing the server and noticed the remote DVR section. I'm reaching the server within the home network, on my chromebook.
The server does not use https when accessing it locally. Additionally, auth is not required when accessing it from the local LAN.
Any requests from outside of your local LAN will require authentication. And if you use our Remote DVR feature, all network traffic is secured with TLS and accessed over https.
Navigating to my.channelsdvr.net will forward you to https.
I can assure you that everything has been considered in terms of the security.
Appreciate the quick response !
