I have noticed the last couple of weeks that shows sort of skip in the middle. I might be missing a few seconds every now and then but it happens several times during the program. Not sure how to fix it.
First step is to check your DVR log and see if there are errors shown from when the recording was happening.
If your DVR computer is on wifi, then you should plug it in instead.
how can I look back? I see the most recent log and I will check that out tonight.
2018/01/30 19:53:57 [DVR] Starting job 1517360400-3 The Flash on ch=[33.1]
2018/01/30 19:53:57 [DVR] Waiting 6m2.701397307s until next job 1517364000-ch4.1 State of the Union 2018
2018/01/30 19:53:59 [ERR] Failed to start stream on channel 33.1 via 1055FD37: Get http://192.168.1.7:5004/auto/v33.1?transcode=none: dial tcp 192.168.1.7:5004: i/o timeout
2018/01/30 19:53:59 [DVR] Error running job 1517360400-3 The Flash: could not start stream on channels=[33.1]: Get http://192.168.1.7:5004/auto/v33.1?transcode=none: dial tcp 192.168.1.7:5004: i/o timeout
2018/01/30 19:54:29 [DVR] Starting job 1517360400-3 The Flash on ch=[33.1]
2018/01/30 19:54:29 [DVR] Waiting 5m30.65319158s until next job 1517364000-ch4.1 State of the Union 2018
2018/01/30 19:54:29 [TNR] Opened connection to 1055FD37 for ch33.1 [transcode=none]
2018/01/30 19:54:29 [DVR] Recording for job 1517360400-3 from 1055FD37 ch33.1 into "TV/The Flash/The Flash S04E12 2018-01-30 Honey I Shrunk Team Flash 2018-01-30-1900.mpg" for 5m30.653140124s
2018/01/30 20:00:00 [DVR] Deleting expired job 1517360400-3 The Flash
2018/01/30 20:00:00 [TNR] Closed connection to 1055FD37 for ch33.1
2018/01/30 20:00:00 [DVR] Starting job 1517364000-ch4.1 State of the Union 2018 on ch=[4.1]
2018/01/30 20:00:00 [DVR] Finished job 1517360400-3 The Flash
2018/01/30 20:00:00 [TNR] Opened connection to 1055FD37 for ch4.1 [transcode=none]
2018/01/30 20:00:00 [DVR] Starting job 1517364000-23 Black Lightning on ch=[33.1]
2018/01/30 20:00:00 [DVR] Waiting 22h59m59.396145824s until next job 1517446800-2 Riverdale
2018/01/30 20:00:00 [ERR] Failed to start stream on channel 33.1 via 1055FD37: got HDHR error: 805 All Tuners In Use
2018/01/30 20:00:00 [DVR] Error running job 1517364000-23 Black Lightning: could not start stream on channels=[33.1]: got HDHR error: 805 All Tuners In Use
2018/01/30 20:00:00 [DVR] Waiting 22h59m59.263176144s until next job 1517446800-2 Riverdale
2018/01/30 20:00:01 [DVR] Recording for job 1517364000-ch4.1 from 1055FD37 ch4.1 into "TV/State of the Union 2018/State of the Union 2018 2018-01-30 2018-01-30-2000.mpg" for 1h29m59.645809821s
2018/01/30 20:00:01 [DVR] Processing file-153: TV/The Flash/The Flash S04E12 2018-01-30 Honey I Shrunk Team Flash 2018-01-30-1900.mpg
2018/01/30 20:00:06 [DVR] Running commercial detection on file 153 (TV/The Flash/The Flash S04E12 2018-01-30 Honey I Shrunk Team Flash 2018-01-30-1900.mpg)
2018/01/30 20:00:30 [DVR] Starting job 1517364000-23 Black Lightning on ch=[33.1]
2018/01/30 20:00:30 [DVR] Waiting 22h59m29.375756527s until next job 1517446800-2 Riverdale
2018/01/30 20:00:30 [DVR] Waiting 22h59m29.246535825s until next job 1517446800-2 Riverdale
2018/01/30 20:00:30 [TNR] Opened connection to 1055FD37 for ch33.1 [transcode=none]
2018/01/30 20:00:30 [DVR] Recording for job 1517364000-23 from 1055FD37 ch33.1 into "TV/Black Lightning/Black Lightning S01E03 2018-01-30 Lawanda The Book of Burial 2018-01-30-2000.mpg" for 59m29.375704351s
2018/01/30 20:03:34 [DVR] Cancelling stream 1055FD37 ch4.1 after 3s read timeout
2018/01/30 20:03:34 [DVR] Cancelling stream 1055FD37 ch33.1 after 3s read timeout
2018/01/30 20:03:34 [TNR] Closed connection to 1055FD37 for ch33.1
2018/01/30 20:03:34 [DVR] Job 1517364000-23 Black Lightning ended prematurely: 56m25.10529103s
2018/01/30 20:03:34 [TNR] Closed connection to 1055FD37 for ch4.1
2018/01/30 20:03:34 [DVR] Job 1517364000-ch4.1 State of the Union 2018 ended prematurely: 1h26m25.104692458s
2018/01/30 20:03:34 [DVR] Starting job 1517364000-ch4.1 State of the Union 2018 on ch=[4.1]
2018/01/30 20:03:36 [ERR] Failed to start stream on channel 4.1 via 1055FD37: Get http://192.168.1.7:5004/auto/v4.1?transcode=none: dial tcp 192.168.1.7:5004: i/o timeout
2018/01/30 20:03:36 [DVR] Error running job 1517364000-ch4.1 State of the Union 2018: could not start stream on channels=[4.1]: Get http://192.168.1.7:5004/auto/v4.1?transcode=none: dial tcp 192.168.1.7:5004: i/o timeout
2018/01/30 20:03:36 [DVR] Starting job 1517364000-23 Black Lightning on ch=[33.1]
2018/01/30 20:03:36 [DVR] Waiting 22h56m23.098219927s until next job 1517446800-2 Riverdale
2018/01/30 20:03:37 [ERR] Failed to start stream on channel 33.1 via 1055FD37: got HDHR error: 805 All Tuners In Use
2018/01/30 20:03:37 [DVR] Error running job 1517364000-23 Black Lightning: could not start stream on channels=[33.1]: got HDHR error: 805 All Tuners In Use
2018/01/30 20:03:37 [DVR] Starting job 1517364000-ch4.1 State of the Union 2018 on ch=[4.1]
2018/01/30 20:03:37 [ERR] Failed to start stream on channel 4.1 via 1055FD37: got HDHR error: 805 All Tuners In Use
2018/01/30 20:03:37 [DVR] Error running job 1517364000-ch4.1 State of the Union 2018: could not start stream on channels=[4.1]: got HDHR error: 805 All Tuners In Use
2018/01/30 20:03:37 [DVR] Starting job 1517364000-23 Black Lightning on ch=[33.1]
2018/01/30 20:03:37 [DVR] Waiting 22h56m22.072779676s until next job 1517446800-2 Riverdale
2018/01/30 20:04:06 [DVR] Starting job 1517364000-ch4.1 State of the Union 2018 on ch=[4.1]
2018/01/30 20:04:07 [TNR] Opened connection to 1055FD37 for ch4.1 [transcode=none]
2018/01/30 20:04:07 [DVR] Starting job 1517364000-23 Black Lightning on ch=[33.1]
2018/01/30 20:04:07 [DVR] Waiting 22h55m52.856897343s until next job 1517446800-2 Riverdale
2018/01/30 20:04:07 [DVR] Recording for job 1517364000-ch4.1 from 1055FD37 ch4.1 into "TV/State of the Union 2018/State of the Union 2018 2018-01-30 2018-01-30-2000.mpg" for 1h25m53.091939047s
2018/01/30 20:04:07 [TNR] Opened connection to 1055FD37 for ch33.1 [transcode=none]
2018/01/30 20:04:07 [DVR] Recording for job 1517364000-23 from 1055FD37 ch33.1 into "TV/Black Lightning/Black Lightning S01E03 2018-01-30 Lawanda The Book of Burial 2018-01-30-2000.mpg" for 55m52.856852631s
2018/01/30 20:04:07 [DVR] Waiting 22h55m52.080538441s until next job 1517446800-2 Riverdale
2018/01/30 20:04:07 [DVR] Waiting 22h55m52.066135796s until next job 1517446800-2 Riverdale
2018/01/30 20:04:07 [DVR] Waiting 22h55m52.05099478s until next job 1517446800-2 Riverdale
2018/01/30 20:04:31 [DVR] Cancelling stream 1055FD37 ch33.1 after 3s read timeout
2018/01/30 20:04:31 [TNR] Closed connection to 1055FD37 for ch33.1
2018/01/30 20:04:31 [DVR] Job 1517364000-23 Black Lightning ended prematurely: 55m28.725706898s
2018/01/30 20:04:31 [DVR] Cancelling stream 1055FD37 ch4.1 after 3s read timeout
2018/01/30 20:04:31 [TNR] Closed connection to 1055FD37 for ch4.1
2018/01/30 20:04:31 [DVR] Job 1517364000-ch4.1 State of the Union 2018 ended prematurely: 1h25m28.722337516s
2018/01/30 20:04:31 [DVR] Starting job 1517364000-ch4.1 State of the Union 2018 on ch=[4.1]
2018/01/30 20:04:33 [ERR] Failed to start stream on channel 4.1 via 1055FD37: Get http://192.168.1.7:5004/auto/v4.1?transcode=none: dial tcp 192.168.1.7:5004: i/o timeout
2018/01/30 20:04:33 [DVR] Error running job 1517364000-ch4.1 State of the Union 2018: could not start stream on channels=[4.1]: Get http://192.168.1.7:5004/auto/v4.1?transcode=none: dial tcp 192.168.1.7:5004: i/o timeout
2018/01/30 20:04:33 [DVR] Starting job 1517364000-23 Black Lightning on ch=[33.1]
2018/01/30 20:04:33 [DVR] Waiting 22h55m26.717626235s until next job 1517446800-2 Riverdale
2018/01/30 20:04:34 [ERR] Failed to start stream on channel 33.1 via 1055FD37: got HDHR error: 805 All Tuners In Use
2018/01/30 20:04:34 [DVR] Error running job 1517364000-23 Black Lightning: could not start stream on channels=[33.1]: got HDHR error: 805 All Tuners In Use
2018/01/30 20:04:34 [DVR] Starting job 1517364000-ch4.1 State of the Union 2018 on ch=[4.1]
2018/01/30 20:04:34 [ERR] Failed to start stream on channel 4.1 via 1055FD37: got HDHR error: 805 All Tuners In Use
2018/01/30 20:04:34 [DVR] Error running job 1517364000-ch4.1 State of the Union 2018: could not start stream on channels=[4.1]: got HDHR error: 805 All Tuners In Use
2018/01/30 20:04:34 [DVR] Starting job 1517364000-23 Black Lightning on ch=[33.1]
2018/01/30 20:04:34 [DVR] Waiting 22h55m25.6761037s until next job 1517446800-2 Riverdale
2018/01/30 20:05:03 [DVR] Starting job 1517364000-ch4.1 State of the Union 2018 on ch=[4.1]
2018/01/30 20:05:03 [TNR] Opened connection to 1055FD37 for ch4.1 [transcode=none]
2018/01/30 20:05:03 [DVR] Starting job 1517364000-23 Black Lightning on ch=[33.1]
2018/01/30 20:05:03 [DVR] Waiting 22h54m56.481564641s until next job 1517446800-2 Riverdale
2018/01/30 20:05:03 [DVR] Recording for job 1517364000-ch4.1 from 1055FD37 ch4.1 into "TV/State of the Union 2018/State of the Union 2018 2018-01-30 2018-01-30-2000.mpg" for 1h24m56.71138072s
2018/01/30 20:05:03 [TNR] Opened connection to 1055FD37 for ch33.1 [transcode=none]
2018/01/30 20:05:03 [DVR] Recording for job 1517364000-23 from 1055FD37 ch33.1 into "TV/Black Lightning/Black Lightning S01E03 2018-01-30 Lawanda The Book of Burial 2018-01-30-2000.mpg" for 54m56.481519017s
2018/01/30 20:05:04 [DVR] Waiting 22h54m55.690100783s until next job 1517446800-2 Riverdale
2018/01/30 20:05:04 [DVR] Waiting 22h54m55.66541881s until next job 1517446800-2 Riverdale
2018/01/30 20:05:04 [DVR] Waiting 22h54m55.64839461s until next job 1517446800-2 Riverdale
2018/01/30 20:08:34 [DVR] Cancelling stream 1055FD37 ch33.1 after 3s read timeout
2018/01/30 20:08:34 [TNR] Closed connection to 1055FD37 for ch33.1
2018/01/30 20:08:34 [DVR] Job 1517364000-23 Black Lightning ended prematurely: 51m25.603915536s
2018/01/30 20:08:34 [DVR] Cancelling stream 1055FD37 ch4.1 after 3s read timeout
2018/01/30 20:08:34 [TNR] Closed connection to 1055FD37 for ch4.1
2018/01/30 20:08:34 [DVR] Job 1517364000-ch4.1 State of the Union 2018 ended prematurely: 1h21m25.599947773s
2018/01/30 20:08:34 [DVR] Starting job 1517364000-ch4.1 State of the Union 2018 on ch=[4.1]
2018/01/30 20:08:36 [ERR] Failed to start stream on channel 4.1 via 1055FD37: Get http://192.168.1.7:5004/auto/v4.1?transcode=none: dial tcp 192.168.1.7:5004: i/o timeout
2018/01/30 20:08:36 [DVR] Error running job 1517364000-ch4.1 State of the Union 2018: could not start stream on channels=[4.1]: Get http://192.168.1.7:5004/auto/v4.1?transcode=none: dial tcp 192.168.1.7:5004: i/o timeout
2018/01/30 20:08:36 [DVR] Starting job 1517364000-23 Black Lightning on ch=[33.1]
This is the results from last night. Same issues of skipping.
These errors mean that the network connection between your HDHR and DVR is getting dropped in the middle of a recording.
This means your DVR is hitting a network timeout when trying to connect to your HDHR to start a recording.
This one is self-explanatory… there are no available tuners since all are busy.
It seems like there’s a serious network issue between your DVR and HDHR. Are they both plugged into the same switch? I would double check the cables and make sure they are cat6
HDHR is pulled into the Orbi Satellite. This seems to just start happening in last couple of weeks. I can try and restart that satellite. Is there any issues with Orbi?
I’m not familiar with Orbi, but if you’re saying the HDHR is connected to the rest of the network via wifi then that’s not a good idea. You need a wired connection or you will have lots of problems.
The Orbi is a Netgear product. The satellite has a wired connection. This problem just started. Has there been any updates that might have triggered this? Thanks again for all your help.
There have been no updates in this area, and your logs clearly show a networking issue in your setup.
Thank you so much. I’ll see if I can restart it.
But the satellite is wifi to the rest of the network? That is where the problem is. Try connecting the HDHR, DVR, and ATV all to the same Orbi. (wired)
