DVR Stuck in update loop
Currently on version 2022.01.27.0906 (on windows 10 64-bit). Server keeps trying to update to version 2022.02.09.0020. Downloads, restarts, says "Up to Date!", then starts all over again.
2022/02/11 07:07:27.968472 [SYS] Starting Channels DVR v2022.01.27.0906 (windows-x86_64 pid:2296) in C:\ProgramData\ChannelsDVR\data
2022/02/11 07:07:28.023554 [SYS] Started HTTP Server
2022/02/11 07:07:28.523025 [HDR] Found 0 devices
2022/02/11 07:07:28.665659 [M3U] Refreshed lineup for PlutoTV with 343 channels
2022/02/11 07:07:28.685531 [M3U] Refreshed lineup for StirrTV with 110 channels
2022/02/11 07:07:29.654439 [DVR] Recording engine started in C:\DVR
2022/02/11 07:07:29.671356 [DBG] Scheduling wake timer for scheduled recording in 23h58m30s
2022/02/11 07:07:29.896842 [SYS] Bonjour service running for dvr-pc-dvr.local. [192.168.12.100 172.27.144.1]
2022/02/11 07:07:30.622054 [SYS] Downloading new version v2022.02.09.0020
2022/02/11 07:07:32.908657 [SYS] Created database snapshot: backup-20220211.070732
2022/02/11 07:07:32.909176 [SYS] Removing old backup backup-20220211.063801
2022/02/11 07:07:39.680158 [IDX] Pruned 0 expired airings from XMLTV-StirrTV in 0s.
2022/02/11 07:07:39.680667 [IDX] Pruned 0 expired airings from X-TVE in 508.9µs.
2022/02/11 07:07:39.680667 [IDX] Pruned 0 expired airings from XMLTV-PlutoTV in 0s.
2022/02/11 07:07:39.680667 [DBG] Scheduling wake timer for guide data in 2h19m50.3193324s
2022/02/11 07:08:30.424566 [SYS] Update downloaded and verified successfully.
2022/02/11 07:08:30.424566 [SYS] Shutting down for upgrade from v2022.01.27.0906 to v2022.02.09.0020
2022/02/11 07:08:30.951489 [SYS] Bonjour service stopped.
2022/02/11 07:08:30.952368 [DVR] Recording engine stopped.
2022/02/11 07:08:31.970883 [SYS] Goodbye.
2022/02/11 07:08:32.381276 [SYS] Starting Channels DVR v2022.01.27.0906 (windows-x86_64 pid:6820) in C:\ProgramData\ChannelsDVR\data
Run the install to uninstall and reinstall, then visit http://127.0.0.1:8089/restore to restore backup
I was running DVR as a background service. I am able to remove the service, uninstall, reinstall. But when I try to start the new install either in the System Tray, or as a background service, it does not appear to start. The Setup reactivates the "Start DVR in System Tray" button, in place of the "Open DVR Settings". When installed as a background service, the "Start DVR Service" button never goes away.
Windows event viewer shows Event ID 1, "Incorrect function."
Can you move or delete c:\programdata\channelsdvr and try again
That seems to have done the trick.
Thank you so much for the quick response.
