Dynalink Android TV Box (Rebadged ADT-3)
From what I can tell it's a rebadged version of the Google ADT-3 device, with Netflix and Prime Video apps. Only $29 at Walmart right now. I know a few people have been looking for something based on the ADT-3.
Interested in hearing if Channels DVR apps, both player and server apps are available on this device. Looking into the specs further, uses the same hardware as the TS4K and AirTV Mini, SoC, CPU, GPU, etc. However I see it doesnt have a USB-C port like the TS4K does, would really limit external storage if using as a server.
Channels DVR Server is not compatible with Android 10
It should make a good client device though
It's not usb-c. Not sure why anyone would think it's worth saving a few dollars over the TS4k. MicroUSB just needs to die. Almost 2021. Bad enough we need a dongle cable to use wired headphones these days. To require an otg cable on a device released in 2020 is just dumb.
And oddly enough, I would trust tivo to provide better support for their device than this company. Tivo is at least vested in Android on the cable side for the long run. They might be a sandwich or two short of a picnic when it comes to support, but the TS4k has slowly improved. Keyword being slowly.
You obviously haven't been using the device since its release. TiVo has not done a great job with their updates, and they still have yet to fully fix the hardware decoder that they broke back in August.
If it works for you, great. But the TS4K is far from an optimal device.
If you read my comments elsewhere, I have three of them. Two since launch. Two are de+tivo'd and one I have to leave stock. And that's all I'll say about that. I actually like them better than Sabrina which is surprising because I do a fair amount of complaining to them on a constant basis. At least in regards to my stock one.
I've had hardware decoding enabled for months now. My only issue is actually on Sabrina where I might have to enable software decoding because all of my OTA (live and memorex) are slow and stuttery. No issues on the TS4k.
And I can't seem to get the official app on Sabrina either. I'm stuck with the beta because it's the only app that shows up in the store.
