Easiest way to pull Bravo E! SyFy USA etc
So just asking whats the simplest way to pull lost "NBC" stations back into channels I do have docker on my Channels Win 11 PC BUT im not so great at it etc Only have it running the EplusTV during baseball season .....I do have a spare ONN Box ....and all this is for viewing on an Android TV
CC4C seems to be dead BUT not so sure
Just looking for opinions thats all
Do you have Olivetin and Portainer containers running? If not, check out @bnhf 's threads on those because they make Docker much easier.
CC4C isn't dead and there is a new project called Prismcast that both capture chrome tabs. Prismcast has those NBC channels prepopulated, so it might be "easier". Both projects can be installed via Olivetin.
I gave Prismcast a quick shot it shows in Docker as running etc BUT when i try to pull the gui at 5589 or 6080 it does not load
I will look at the Olive Tin thing when i have more time etc Just got called into that all PIA work thing that was not scheduled Yay.....lol
Did you use the Docker Compose I posted in the PrismCast thread?
So I kept messing around and after changing default ports from 5589 to 5599 and 6080 to 7080
I got it "working" Just need to find my restart settings i used for eplusTV
But i did tune a few channels so far so good
And the container restarted after a reboot AND i'm late for work.....lol
