Attempting to setup DVR for the first time on 3TB USB drive.
Error: unable to create dvr directory: mkdir /storage/6C5CE2595CE21E12/Channels_DVR/DVR: permission denied.
I previously had seen the message Error: no write permission on DVR directory
I tried reformatting the drive on a W10 PC. I'm 'somewhat' familiar with Linux, but I don't see how to get access to the Shield file system to chmod (if that's even what I should try to do)
here is some of the log file
2018/12/17 20:10:01 [ERR] Failed to read directory /storage/emulated: open /storage/emulated: permission denied
2018/12/17 20:13:06 [ERR] Failed to read directory /storage/42F2C803F2C7F8E5/Channels_DVR: open /storage/42F2C803F2C7F8E5/Channels_DVR: no such file or directory
2018/12/17 20:19:57 [ERR] Failed to read directory /storage/6C5CE2595CE21E18/Channels_DVR/DVR: open /storage/6C5CE2595CE21E18/Channels_DVR/DVR: no such file or directory
If it matters, I previously had seen the following in the log when I had a 120GB SSD connected as "device storage" I disconnected that when I installed the 3TB drive as "removable storage"
2018/12/16 22:57:19 [TNR] Closed connection to 1064D12D for ch5.1
2018/12/16 22:57:19 [DVR] Error running job 1545013800-ch5.1 Tom Petty and the Heartbreakers : One 30th Anniversary Concert From Gainesville, FL: mkdir /storage/emulated/0/DVR/TV: read-only file system
I hope I haven't gone overboard with info on this first post. Thank you for your help
