Enable number based switching
Hi There,
So far great app.
Love it,
I’m using on an AppleTV 4 with a Tivo remote.
Apple remote is honestly a bit small and easy to lose so I prefer using a larger remote that my wife can find.
It would be great to enable the number keypad for switching channels rather than scrolling through the guide.
Unfortunately this is not possible on tvOS
Is there anything possible using Siri search while in the app?
There is no third party support for Siri in the tvOS SDK either. All of the Siri stuff is system based only.
Sure would be nice if Apple would allow you guys to use that feature. Is developing a custom voice command feature into the app an option?
