@maddox @tmm1
It is a bug and should be looked at the pass should work as designed.
Are you running the latest pre-release?
I can't duplicate your issue as it appears they fixed this already by appending -programid# to the scheduled jobid.
Example for Pluto source, pass scheduled two recordings, same time, different channels
1651624080-69-pluto/5fac94083650d7001b3fed6c/S5E90
1651624080-69-pluto/61df108f79ba2f001aa6c4e6/20220503173000--0700
Example for HDHR source, pass scheduled two recordings, same time, different channels
1651624200-561-EP001145450376
1651624200-561-SH009682820000-1651624200
Yes I always run the latest prerelease. I do not trust that they fixed a bug they didn't know existed.
Maybe you need to change something on your pass and save it?
Could be an update fixed the issue, but only for passes created or updated after the fix was put in?
Coule be the scheduler that runs with the daily morning guide update is messing it up.
Haven't tested for that, but just created a test pass and will see tomorrow. I'm sure it will work based on the job id's it created.
[DVR] Rule '000-TEST' (562) found 2 new airings
[DVR] queued recording job for EP000047770078 @ Wed May 4 12:00:00PM on ch=[484] (1651690800-562-EP000047770078)
[DVR] queued recording job for EP011702490222 @ Wed May 4 12:00:00PM on ch=[706] (1651690800-562-EP011702490222)
I'll bet this will fix it for you.
Change the name of your Advanced pass to something like PRIME-TIME and save it.
Then look at the log and I bet the new scheduled jobs it creates will have the -programid# appended to them.
I trust you ....
2022/05/03 18:52:10.366354 [DVR] queued recording job for EP026956860132 @ Tue May 3 7:59:30PM on ch=[6002 12.1] (1651633170-1-EP026956860132)
2022/05/03 18:52:10.369394 [DVR] queued recording job for EP032034590037 @ Tue May 3 7:59:30PM on ch=[6001 2.1] (1651633170-1-EP032034590037)
2022/05/03 18:52:10.372877 [DVR] queued recording job for EP035420860020 @ Tue May 3 7:59:30PM on ch=[6000 8.1] (1651633170-1-EP035420860020)
2022/05/03 18:52:10.376815 [DVR] queued recording job for EP035420740018 @ Tue May 3 8:29:30PM on ch=[6000 8.1] (1651634970-1)
2022/05/03 18:52:10.380773 [DVR] queued recording job for EP024314420125 @ Tue May 3 8:59:30PM on ch=[6000 8.1] (1651636770-1-EP024314420125)
2022/05/03 18:52:10.384487 [DVR] queued recording job for EP036765740031 @ Tue May 3 8:59:30PM on ch=[6001 2.1] (1651636770-1-EP036765740031)
2022/05/03 18:52:10.388573 [DVR] queued recording job for EP036894440018 @ Tue May 3 9:00:30PM on ch=[6002 12.1] (1651636830-1)
2022/05/03 18:52:10.392942 [DVR] queued recording job for EP042368680001 @ Tue May 3 9:59:30PM on ch=[6001 2.1] (1651640370-1)
2022/05/03 18:52:10.397370 [DVR] queued recording job for EP029694490084 @ Tue May 3 10:00:30PM on ch=[6000 8.1] (1651640430-1)
2022/05/03 18:52:10.401831 [DVR] queued recording job for EP003670780704 @ Wed May 4 7:59:30PM on ch=[6003 6.1] (1651719570-1-EP003670780704)
2022/05/03 18:52:10.406175 [DVR] queued recording job for EP017396170211 @ Wed May 4 7:59:30PM on ch=[6001 2.1] (1651719570-1-EP017396170211)
2022/05/03 18:52:10.410581 [DVR] queued recording job for EP019229360174 @ Wed May 4 7:59:30PM on ch=[32.1] (1651719570-1-EP019229360174)
2022/05/03 18:52:10.414690 [DVR] queued recording job for EP021835930137 @ Wed May 4 7:59:30PM on ch=[6000 8.1] (1651719570-1-EP021835930137)
2022/05/03 18:52:10.418765 [DVR] queued recording job for EP030241890120 @ Wed May 4 7:59:30PM on ch=[6002 12.1] (1651719570-1-EP030241890120)
2022/05/03 18:52:10.422715 [DVR] queued recording job for EP038712620016 @ Wed May 4 8:29:30PM on ch=[6001 2.1] (1651721370-1)
2022/05/03 18:52:10.426683 [DVR] queued recording job for EP015679150218 @ Wed May 4 8:59:30PM on ch=[6000 8.1] (1651723170-1-EP015679150218)
2022/05/03 18:52:10.430594 [DVR] queued recording job for EP029960700072 @ Wed May 4 8:59:30PM on ch=[6001 2.1] (1651723170-1-EP029960700072)
2022/05/03 18:52:10.434671 [DVR] queued recording job for EP035160220021 @ Wed May 4 8:59:30PM on ch=[32.1] (1651723170-1-EP035160220021)
2022/05/03 18:52:10.438646 [DVR] queued recording job for EP041903280009 @ Wed May 4 8:59:30PM on ch=[6003 6.1] (1651723170-1-EP041903280009)
2022/05/03 18:52:10.442609 [DVR] queued recording job for EP038154520009 @ Wed May 4 9:00:30PM on ch=[6002 12.1] (1651723230-1)
2022/05/03 18:52:10.446547 [DVR] queued recording job for EP037549350024 @ Wed May 4 9:30:30PM on ch=[6001 2.1] (1651725030-1)
2022/05/03 18:52:10.450655 [DVR] queued recording job for EP017387030182 @ Wed May 4 9:59:30PM on ch=[6000 8.1] (1651726770-1-EP017387030182)
2022/05/03 18:52:10.454551 [DVR] queued recording job for EP029705200074 @ Wed May 4 9:59:30PM on ch=[6001 2.1] (1651726770-1-EP029705200074)
2022/05/03 18:52:10.458129 [DVR] queued recording job for EP038741410012 @ Wed May 4 9:59:30PM on ch=[6003 6.1] (1651726770-1-EP038741410012)
2022/05/03 18:52:10.462267 [DVR] queued recording job for EP000176170500 @ Thu May 5 7:59:30PM on ch=[6000 8.1] (1651805970-1-EP000176170500)
2022/05/03 18:52:10.466650 [DVR] queued recording job for EP012513470402 @ Thu May 5 7:59:30PM on ch=[6002 12.1] (1651805970-1-EP012513470402)
2022/05/03 18:52:10.470771 [DVR] queued recording job for EP026422390090 @ Thu May 5 7:59:30PM on ch=[6003 6.1] (1651805970-1-EP026422390090)
2022/05/03 18:52:10.474951 [DVR] queued recording job for EP028676810080 @ Thu May 5 7:59:30PM on ch=[6001 2.1] (1651805970-1-EP028676810080)
2022/05/03 18:52:10.479089 [DVR] queued recording job for EP035160200035 @ Thu May 5 7:59:30PM on ch=[32.1] (1651805970-1-EP035160200035)
2022/05/03 18:52:10.482993 [DVR] queued recording job for EP036860620025 @ Thu May 5 8:30:30PM on ch=[6003 6.1] (1651807830-1)
2022/05/03 18:52:10.486966 [DVR] queued recording job for EP003169780620 @ Thu May 5 8:59:30PM on ch=[6000 8.1] (1651809570-1-EP003169780620)
2022/05/03 18:52:10.491434 [DVR] queued recording job for EP007322830455 @ Thu May 5 8:59:30PM on ch=[6001 2.1] (1651809570-1-EP007322830455)
2022/05/03 18:52:10.495801 [DVR] queued recording job for EP029731020069 @ Thu May 5 8:59:30PM on ch=[32.1] (1651809570-1-EP029731020069)
2022/05/03 18:52:10.499777 [DVR] queued recording job for EP026422390091 @ Thu May 5 9:00:30PM on ch=[6003 6.1] (1651809630-1-EP026422390091)
2022/05/03 18:52:10.503950 [DVR] queued recording job for EP035124650031 @ Thu May 5 9:00:30PM on ch=[6002 12.1] (1651809630-1-EP035124650031)
2022/05/03 18:52:10.508074 [DVR] queued recording job for EP038741260007 @ Thu May 5 9:29:30PM on ch=[6003 6.1] (1651811370-1)
2022/05/03 18:52:10.512315 [DVR] queued recording job for EP036659770008 @ Thu May 5 9:30:30PM on ch=[6002 12.1] (1651811430-1)
2022/05/03 18:52:10.516675 [DVR] queued recording job for EP024336970134 @ Thu May 5 9:59:30PM on ch=[6003 6.1] (1651813170-1-EP024336970134)
2022/05/03 18:52:10.521043 [DVR] queued recording job for EP035420690029 @ Thu May 5 9:59:30PM on ch=[6000 8.1] (1651813170-1-EP035420690029)
2022/05/03 18:52:10.525171 [DVR] queued recording job for EP011581290303 @ Fri May 6 7:59:30PM on ch=[6001 2.1] (1651892370-1-EP011581290303)
2022/05/03 18:52:10.529438 [DVR] queued recording job for EP017386900210 @ Fri May 6 7:59:30PM on ch=[6000 8.1] (1651892370-1-EP017386900210)
2022/05/03 18:52:10.533389 [DVR] queued recording job for EP029730310068 @ Fri May 6 7:59:30PM on ch=[32.1] (1651892370-1-EP029730310068)
2022/05/03 18:52:10.537420 [DVR] queued recording job for EP033090100144 @ Fri May 6 7:59:30PM on ch=[6002 12.1] (1651892370-1-EP033090100144)
2022/05/03 18:52:10.541414 [DVR] queued recording job for EP036058800005 @ Fri May 6 7:59:30PM on ch=[6003 6.1] (1651892370-1-EP036058800005)
2022/05/03 18:52:10.545291 [DVR] queued recording job for EP026983560097 @ Fri May 6 8:59:30PM on ch=[32.1] (1651895970-1-EP026983560097)
2022/05/03 18:52:10.549344 [DVR] queued recording job for EP029715370076 @ Fri May 6 8:59:30PM on ch=[6003 6.1] (1651895970-1-EP029715370076)
2022/05/03 18:52:10.553445 [DVR] queued recording job for EP000000212020 @ Fri May 6 9:00:30PM on ch=[6001 2.1] (1651896030-1)
2022/05/03 18:52:10.556983 [DVR] queued recording job for EP012801050254 @ Fri May 6 9:59:30PM on ch=[6003 6.1] (1651899570-1)
2022/05/03 18:52:10.560842 [DVR] queued recording job for EP006819110454 @ Sat May 7 7:59:30PM on ch=[6003 6.1] (1651978770-1-EP006819110454)
2022/05/03 18:52:10.564751 [DVR] queued recording job for EP017040100164 @ Sat May 7 7:59:30PM on ch=[32.1] (1651978770-1-EP017040100164)
2022/05/03 18:52:10.568837 [DVR] queued recording job for EP000037101390 @ Sat May 7 8:28:30PM on ch=[6000 8.1] (1651980510-1)
2022/05/03 18:52:10.572812 [DVR] queued recording job for EP041273450005 @ Sat May 7 8:29:30PM on ch=[32.1] (1651980570-1)
2022/05/03 18:52:10.576890 [DVR] queued recording job for EP011583610298 @ Sat May 7 8:59:30PM on ch=[6003 6.1] (1651982370-1-EP011583610298)
2022/05/03 18:52:10.580632 [DVR] queued recording job for EP019142670102 @ Sat May 7 8:59:30PM on ch=[32.1] (1651982370-1-EP019142670102)
2022/05/03 18:52:10.584193 [DVR] queued recording job for EP000023484783 @ Sat May 7 9:59:30PM on ch=[6001 2.1] (1651985970-1)
2022/05/03 18:52:10.587900 [DVR] queued recording job for EP000037101389 @ Sat May 7 10:01:30PM on ch=[6000 8.1] (1651986090-1)
2022/05/03 18:52:10.591891 [DVR] queued recording job for EP000047623928 @ Sat May 7 10:29:30PM on ch=[6001 2.1] (1651987770-1)
2022/05/03 18:52:10.595842 [DVR] queued recording job for EP000186930776 @ Sun May 8 7:59:30PM on ch=[6002 12.1] (1652065170-1-EP000186930776)
2022/05/03 18:52:10.599831 [DVR] queued recording job for EP005520800742 @ Sun May 8 7:59:30PM on ch=[6001 2.1] (1652065170-1-EP005520800742)
2022/05/03 18:52:10.603687 [DVR] queued recording job for EP024345980110 @ Sun May 8 7:59:30PM on ch=[32.1] (1652065170-1-EP024345980110)
2022/05/03 18:52:10.607234 [DVR] queued recording job for EP035115960028 @ Sun May 8 7:59:30PM on ch=[6003 6.1] (1652065170-1-EP035115960028)
2022/05/03 18:52:10.611190 [DVR] queued recording job for EP032285840032 @ Sun May 8 8:29:30PM on ch=[6002 12.1] (1652066970-1)
2022/05/03 18:52:10.614854 [DVR] queued recording job for EP011583610312 @ Sun May 8 8:59:30PM on ch=[6003 6.1] (1652068770-1-EP011583610312)
2022/05/03 18:52:10.618439 [DVR] queued recording job for EP012792980314 @ Sun May 8 8:59:30PM on ch=[6002 12.1] (1652068770-1-EP012792980314)
2022/05/03 18:52:10.622463 [DVR] queued recording job for EP017040100152 @ Sun May 8 8:59:30PM on ch=[32.1] (1652068770-1-EP017040100152)
2022/05/03 18:52:10.626034 [DVR] queued recording job for EP002960010438 @ Sun May 8 9:29:30PM on ch=[6002 12.1] (1652070570-1)
2022/05/03 18:52:10.629670 [DVR] queued recording job for EP026956620109 @ Mon May 9 7:59:30PM on ch=[6002 12.1] (1652151570-1-EP026956620109)
2022/05/03 18:52:10.633618 [DVR] queued recording job for EP029715920083 @ Mon May 9 7:59:30PM on ch=[6003 6.1] (1652151570-1-EP029715920083)
2022/05/03 18:52:10.637523 [DVR] queued recording job for EP029730910070 @ Mon May 9 7:59:30PM on ch=[32.1] (1652151570-1-EP029730910070)
2022/05/03 18:52:10.641855 [DVR] queued recording job for EP041338370010 @ Mon May 9 7:59:30PM on ch=[6000 8.1] (1652151570-1-EP041338370010)
2022/05/03 18:52:10.645926 [DVR] queued recording job for EP032302210059 @ Mon May 9 8:29:30PM on ch=[6003] (1652153370-1)
2022/05/03 18:52:11.056443 [DVR] Waiting 7m18.943559445s until next job 1651629570-5 Jeopardy!
I guess the change was made but the pass had to be refreshed thanks a lot for your help much appreciated, and I am sure the developers also appreciate it.
I would do the same with any other passes you have where you think they could schedule more than one recording at the same time. I just checked through mine!
I was getting a few Interrupted recordings before refreshing the Passes ...now since I refreshed the Passes no longer have that problem.
