EPG mixing up UK logos and programming data on PC and Apple TV
Hi.
I'm in the UK and I've just moved to Channels & Hdhomerun as a way of having live TV, svr, and streaming all together in one unit (more difficult to achieve than you would have thought).
However, the channel mapping from hdhomerun is a bit mixed. Channel 2 is BBC2, bit it's showing ITV1 and it's data (which should be channel 3), and there are several other channels that are mixed up. This happens both on the Apple TV app (which will bw my main way to use it) and on the PC app.
Anyone else have/had this problem, and have you solved it?
Thanks
Have you tried going into the channel mapping to see if you can edit? (Im not sure why it is off but this may be a way for you to correct it). Just click manage lineup on the source and click the X or the pencil to change the mapping
Thanks :+1:
I'll give that a try and see what happens !!
That was really helpful, thanks.
Not the complete answer, but the first step to it.
I needed to do that first, redownload the EPG, and then we're sorted.
Set up a collection, and now it's sorted in the Apple TV too.
:grin::+1:
