Hi,
I just bought a year subscription to DVR.
I'm trying to configure EPG data to use DVB signal because here in Finland we don't have functioning providers elsewhere.
I guess i've tried every option from those finnish choises, what is the correct?
Hi,
Does this work in Finnland maybe? I donβt know.
https://forum.silicondust.com/forum/viewtopic.php?t=72813
https://shop.silicondust.com/shop/product-category/software/#main
Well it says supported in EU. I have to ask them for more detailed info.
I just like this Channels way better, so sad this EPG is still not in working order....
edit, just got confirmation from Hdhomerun, they the same problem that Channels does
I did not understand when buying this 80 dollar subscription, that it cannot make use of DVB guide
Can you tell us more about the issue you have with our guide data? Gracenote shows guide information for Finland.
For whatever reason the Sanoma/Nelonen owned channels Nelonen, Jim, Liv and Hero aren't supplying Gracenote with listings so their schedules just say "Julkaistaan pian" (To be Announced)
Thanks for the details.
I got Jellyfin to update EPG data correctly in Finland so I believe Channels should be able to do it also? I'm guessing Sanoma is still not interested in supplying EPG data to Gracenote.
