I was able to display epg guide for hdhomerun channels on Apple TV (CHannels production version)
Channels are mapped:
But on beta version DVR on Apple TV EPG is not seen for that channels,nor on the server component
You're going to need to Submit Diagnostic Logs from the DVR for us to have any idea what's going on with your setup.
Also, please take a screenshot that is the entire browser window so we have a better idea of what it is you're showing us.
After upgrade to 2020.06.27.0310 guide started to appear correctly. Nice surprice thank you.
And again. after beta upgrade guide is missing.
Sent logs f7ac5d69-a49c-4f65-abb9-3ad1590fea6a
Seems like your xmltv file doesn't contain any new data.
You should add some option to see from what url i get This data, after several weeks it is easy to forget. Is the only option to change epg is to delete, and enter new url and again manually assign channels?
