Sorry to bring this thread up from the dead, but I'm having a similar issue and luckily was able to play around with it on a smaller scale. I'm also using a RPi4 and MacOS. I can consistently get an error -50 when trying to copy over files via SMB. It seems like the only way I can successfully copy files over is by dragging an entire folder of items via the Finder at once. If I try to create a folder on the shared drive in the Finder, I am unable to copy content to that folder. Happy to provide logs or clearer directions...
This is still an issue. Tried to add new items to a current folder via SMB and MacOS and received the same error code -50.
There’s a setting under the sharing pane in macOS that enables you to share folders less securely. I had to turn this on to get it to work. It’s under options in the file sharing preference pane. Had to select my username there. Have you already done that?
That did not seem to work. Assuming you meant the this section...it didn't seem to make a difference.
@tmm1 I know this is a super old thread, but the problem was still persisting when trying to copy files onto the SMB share drive from a MacOS computer to a RPi Image DVR. Found an Apple support document that fixed the problem. It has to do with named streams, which I have no idea what they are. However, after disabling them on my computer (by way of the 2nd option in the disabling section), I was then able to correctly transfer individual files to already created folders on the SMB.
The support document mentions that I should let you know.
This works for Mac, thank you for posting. I have been trying to figure this out for some time now.
Good lord, man. You are a genius. This had me pulling my hair out.
I'll add this for posterity. Steinbch's solution above worked perfectly, however after a week or so I started getting error code -50 again during an upload. After a few WTF moments I realized that the issue was a bad filename. I was attempting to copy a bunch of files from Mac to Channels on a Raspberry Pi and one file had a question mark in the title. MacOS had no issue with it, but the Pi did. Once I renamed that file the issue was solved.
