Hi everyone,
Just curious to know why I'm getting bunch of errors when streaming live TV thru the web interface?
Seems like transcoding errors and wondering is it is a software or hardware process? Server is Windows 64 Intel 4570T, intel HD4600 supporting Quicksync if that matters...
Steaming from Web interface in Safari MacOs High Sierra, Macbook Pro late 2015
No errors streaming from the Apple TV 4K though...
Thank you!
Channels DVR
[h264_qsv @ 0000000000574b40] Warning during encoding: incompatible video parameters (5)
Last message repeated 1 times
[hls @ 00000000029e1200] Non-monotonous DTS in output stream 0:0; previous: 178219041, current: 178219041; changing to 178219042. This may result in incorrect timestamps in the output file.
[hls @ 00000000029e1200] Non-monotonous DTS in output stream 0:0; previous: 178234056, current: 178234056; changing to 178234057. This may result in incorrect timestamps in the output file.
[hls @ 00000000029e1200] Non-monotonous DTS in output stream 0:0; previous: 178249071, current: 178249071; changing to 178249072. This may result in incorrect timestamps in the output file.
[hls @ 00000000029e1200] Non-monotonous DTS in output stream 0:0; previous: 178264086, current: 178264086; changing to 178264087. This may result in incorrect timestamps in the output file.
[hls @ 00000000029e1200] Non-monotonous DTS in output stream 0:0; previous: 178279101, current: 178279101; changing to 178279102. This may result in incorrect timestamps in the output file.
[hls @ 00000000029e1200] Non-monotonous DTS in output stream 0:0; previous: 178294116, current: 178294116; changing to 178294117. This may result in incorrect timestamps in the output file.
[hls @ 00000000029e1200] Non-monotonous DTS in output stream 0:0; previous: 178309131, current: 178309131; changing to 178309132. This may result in incorrect timestamps in the output file.
[hls @ 00000000029e1200] Non-monotonous DTS in output stream 0:0; previous: 178324146, current: 178324146; changing to 178324147. This may result in incorrect timestamps in the output file.
[hls @ 00000000029e1200] Non-monotonous DTS in output stream 0:0; previous: 178339161, current: 178339161; changing to 178339162. This may result in incorrect timestamps in the output file.
[hls @ 00000000029e1200] Non-monotonous DTS in output stream 0:0; previous: 178354176, current: 178354176; changing to 178354177. This may result in incorrect timestamps in the output file.
[hls @ 00000000029e1200] Non-monotonous DTS in output stream 0:0; previous: 178369191, current: 178369191; changing to 178369192. This may result in incorrect timestamps in the output file.
[hls @ 00000000029e1200] Non-monotonous DTS in output stream 0:0; previous: 178384206, current: 178384206; changing to 178384207. This may result in incorrect timestamps in the output file.
[hls @ 00000000029e1200] Non-monotonous DTS in output stream 0:0; previous: 178399221, current: 178399221; changing to 178399222. This may result in incorrect timestamps in the output file.
[hls @ 00000000029e1200] Non-monotonous DTS in output stream 0:0; previous: 178414236, current: 178414236; changing to 178414237. This may result in incorrect timestamps in the output file.
[hls @ 00000000029e1200] Non-monotonous DTS in output stream 0:0; previous: 178429251, current: 178429251; changing to 178429252. This may result in incorrect timestamps in the output file.
[hls @ 00000000029e1200] Non-monotonous DTS in output stream 0:0; previous: 178444266, current: 178444266; changing to 178444267. This may result in incorrect timestamps in the output file.
[hls @ 00000000029e1200] Non-monotonous DTS in output stream 0:0; previous: 178459281, current: 178459281; changing to 178459282. This may result in incorrect timestamps in the output file.
[hls @ 00000000029e1200] Non-monotonous DTS in output stream 0:0; previous: 178474296, current: 178474296; changing to 178474297. This may result in incorrect timestamps in the output file.
[hls @ 00000000029e1200] Non-monotonous DTS in output stream 0:0; previous: 178489311, current: 178489311; changing to 178489312. This may result in incorrect timestamps in the output file.
[hls @ 00000000029e1200] Non-monotonous DTS in output stream 0:0; previous: 178504326, current: 178504326; changing to 178504327. This may result in incorrect timestamps in the output file.
[hls @ 00000000029e1200] Non-monotonous DTS in output stream 0:0; previous: 178519341, current: 178519341; changing to 178519342. This may result in incorrect timestamps in the output file.
[hls @ 00000000029e1200] Non-monotonous DTS in output stream 0:0; previous: 178534356, current: 178534356; changing to 178534357. This may result in incorrect timestamps in the output file.
[hls @ 00000000029e1200] Non-monotonous DTS in output stream 0:0; previous: 178549371, current: 178549371; changing to 178549372. This may result in incorrect timestamps in the output file.
[hls @ 00000000029e1200] Non-monotonous DTS in output stream 0:0; previous: 178564386, current: 178564386; changing to 178564387. This may result in incorrect timestamps in the output file.
[hls @ 00000000029e1200] Non-monotonous DTS in output stream 0:0; previous: 178579401, current: 178579401; changing to 178579402. This may result in incorrect timestamps in the output file.
[hls @ 00000000029e1200] Non-monotonous DTS in output stream 0:0; previous: 178594416, current: 178594416; changing to 178594417. This may result in incorrect timestamps in the output file.
[hls @ 00000000029e1200] Non-monotonous DTS in output stream 0:0; previous: 178609431, current: 178609431; changing to 178609432. This may result in incorrect timestamps in the output file.
[hls @ 00000000029e1200] Non-monotonous DTS in output stream 0:0; previous: 178624446, current: 178624446; changing to 178624447. This may result in incorrect timestamps in the output file.
[hls @ 00000000029e1200] Non-monotonous DTS in output stream 0:0; previous: 178639461, current: 178639461; changing to 178639462. This may result in incorrect timestamps in the output file.
[hls @ 00000000029e1200] Non-monotonous DTS in output stream 0:0; previous: 178654476, current: 178654476; changing to 178654477. This may result in incorrect timestamps in the output file.
[hls @ 00000000029e1200] Non-monotonous DTS in output stream 0:0; previous: 178669491, current: 178669491; changing to 178669492. This may result in incorrect timestamps in the output file.
[hls @ 00000000029e1200] Non-monotonous DTS in output stream 0:0; previous: 178684506, current: 178684506; changing to 178684507. This may result in incorrect timestamps in the output file.
[hls @ 00000000029e1200] Non-monotonous DTS in output stream 0:0; previous: 178699521, current: 178699521; changing to 178699522. This may result in incorrect timestamps in the output file.
[hls @ 00000000029e1200] Non-monotonous DTS in output stream 0:0; previous: 178714536, current: 178714536; changing to 178714537. This may result in incorrect timestamps in the output file.
[hls @ 00000000029e1200] Non-monotonous DTS in output stream 0:0; previous: 178729551, current: 178729551; changing to 178729552. This may result in incorrect timestamps in the output file.
[hls @ 00000000029e1200] Non-monotonous DTS in output stream 0:0; previous: 178744566, current: 178744566; changing to 178744567. This may result in incorrect timestamps in the output file.
2018/12/01 22:03:22 [HLS] Stopping transcoder session ch15.1-dANY-ipfe80ae213652ebef02%Connexion au réseau local @ 0s
2018/12/01 22:03:22 [TNR] Closed connection to 10716049 for ch15.1
2018/12/01 22:04:09 [TNR] Opened connection to 10716049 for ch10.1
2018/12/01 22:04:09 [HLS] Starting transcoder for channel 10.1 from fe80::ae:2136:52eb:ef02%Connexion au réseau local (encoder=h264_qsv, resolution=, deinterlacer=blend, bitrate=10000)
[mpegts @ 00000000004a3180] Could not find codec parameters for stream 3 (Unknown: none ([241][0][0][0] / 0x00F1)): unknown codec
Consider increasing the value for the 'analyzeduration' and 'probesize' options
[ac3 @ 00000000004a39c0] frame sync error
Error while decoding stream #0:1: Invalid data found when processing input
[aac @ 00000000004d38c0] Queue input is backward in time
[hls @ 00000000030f0500] Non-monotonous DTS in output stream 0:1; previous: 23874, current: 22914; changing to 23875. This may result in incorrect timestamps in the output file.
av_interleaved_write_frame(): Invalid argument
Error writing trailer of N:\Streaming\ch10.1-dANY-ipfe80ae213652ebef02%Connexion au réseau local\stream.m3u8: Invalid argument
Error closing progress log, loss of information possible: Error number -10053 occurred
2018/12/01 23:00:08 [WRN] Buffer for 10716049 ch10.1 is more than 50% full (clients=1, len=16777828)
2018/12/01 23:00:12 [WRN] Buffer for 10716049 ch10.1 is more than 75% full (clients=1, len=25165868)
2018/12/01 23:00:15 [WRN] Buffer for 10716049 ch10.1 is more than 95% full (clients=1, len=31878784)
2018/12/01 23:00:15 [WRN] Buffer for 10716049 ch10.1 is more than 99% full (clients=1, len=33222420)
2018/12/01 23:00:51 [HLS] Stopping inactive session ch10.1-dANY-ipfe80ae213652ebef02%Connexion au réseau local @ 0s
2018/12/01 23:00:51 [TNR] Closed connection to 10716049 for ch10.1
2018/12/01 23:03:17 [TNR] Opened connection to 10716049 for ch10.1
2018/12/01 23:03:18 [HLS] Starting transcoder for channel 10.1 from fe80::ae:2136:52eb:ef02%Connexion au réseau local (encoder=h264_qsv, resolution=, deinterlacer=blend, bitrate=10000)
[mpegts @ 00000000004f3180] Could not find codec parameters for stream 3 (Unknown: none ([241][0][0][0] / 0x00F1)): unknown codec
[ac3 @ 0000000002a4fec0] frame sync error
[aac @ 0000000000582e80] Queue input is backward in time
[hls @ 0000000002831100] Non-monotonous DTS in output stream 0:1; previous: 15234, current: 14274; changing to 15235. This may result in incorrect timestamps in the output file.
2018/12/01 23:25:15 [HLS] Stopping transcoder session ch10.1-dANY-ipfe80ae213652ebef02%Connexion au réseau local @ 0s
2018/12/01 23:25:15 [TNR] Closed connection to 10716049 for ch10.1
2018/12/02 01:02:26 [SYS] Created database snapshot: backup-20181202.010226
2018/12/02 01:02:26 [SYS] Removing old backup backup-20181105.162451
