Ha, not really. It was just a big number that popped in my head :smile:. I can make it bigger for you
If you don't hit save on that field it should stay at 11000, even if it shows 10000
lol too late for that. been playing around with it since i got it working again. all good no worries.
Last night my Synology updated to DSM 7.2.2-72806 Update 3.
Immediately thereafter, my EPlusTV container began crashing with this error:
=== E+TV v4.1.10 starting ===
Error: Cannot create a string longer than 0x1fffffe8 characters
at Object.slice (node:buffer:638:37)
at Buffer.toString (node:buffer:857:14)
at FSReqCallback.readFileAfterClose [as oncomplete] (node:internal/fs/read_fi
le_context:63:23) {
code: 'ERR_STRING_TOO_LONG'
Thanks for posting. Will hold off on updating.
Took a peak at the release notes, and there doesn't appear to be much there.
What's New
  1. Added support for verifying LDAP server certificates when joining a directory. The following limitations apply:
  • Certificate verification for C2 Identity Edge Server is not supported.
  • This configuration cannot be backed up in DSM system configuration backup or Hyper Backup Entire System Backup.
Fixed Issues
  1. Fixed a security vulnerabilities (Synology-SA-25:01).
Try re-creating the volume for the config directory. I wonder if something got corrupted?
That did the trick.
Thanks!!
Can someone help me get this set up? I was able to add ETV to docker but never saw where to change the apps to true or false or how to login. I'm not ever sure how to find the web address to add the m3u to Channels. Here are the logs:
2025-02-08 07:26:42
2025-02-08 07:26:42 > [email protected] start
2025-02-08 07:26:42 > ts-node -r tsconfig-paths/register index.tsx
2025-02-08 07:26:42
2025-02-08 07:26:44 === E+TV v4.1.10 starting ===
2025-02-08 07:26:44 Server started on port 8000
2025-02-08 07:26:44 === Getting events ===
2025-02-08 07:26:44 === Done getting events ===
2025-02-08 07:26:44 === Building the schedule ===
2025-02-08 07:26:44 === Done building the schedule ===
I'm sure I'm doing something wrong, but I just cannot figure it out. Can anyone help?
Thank you
The webUI should be available at http://<hostname or IP of Docker host>:8000 or if you mapped 8000 to another port use that.
Thank you. I could find my local host page, activate everything and import into Channels. However, no guide data shows up yet, but that could be because it's still importing. Also, no channel will play, but that could be because there are no active events. Does that sound right?
Edit: I just have ETVPlus channels but not channel names such as ESPN, Fox, etc.
Maybe post a screenshot of your CDVR Custom Channels settings.
What do you mean by this? Are you talking about ESPN+ channels when you say ETVPlus?
Here's the settings:
When I go the guide I do not see individual channel names such as ESPN, SEC, etc. There are some live channels but they will not play.
Also, do I need to activate dedicated linear channels on the ETVplus local setup page?
No, there are definitely events live now. I'm currently in Portugal so local time here is 3:45p, and so all these events are on now:
Settings posted above. Could it be that I have "local host" instead of an IP address? I cannot find the IP address but docker has a link to local host so that's how I entered by user names and passwords
Are Channels DVR and Docker installed on the same system?
Yes, both are on my M2 Mac Mini
If you use your browser to look at the URLs for the M3U and XML pages do you see data?
The live and upcoming events now show in the guide but when I click on a live event and press play I get a spinning circle for a few minutes and then nothing plays. It will show the logo of the event though.
Can you view those same live events if you go to Watch ESPN Schedule - Live Now, Upcoming and Replays - ESPN in your browser and select one?
Yes. After rebooting my computer, I got it working again. Is there any way that the individual channels will be labeled anything other than ETVPlus 1, 2, etc.? Do they not eventually populate with the real channel names, such as ESPN, SEC, Fox Sports, etc.?
