From what I saw before when it was working, all of the FS1 and 2 events were also on the linear channels. Might have missed some though.
Do you still need that? I can share mine with you.
Well i just checked again and FS1/2 are working via EplusTV so all good and better so far
Has anyone successfully pulled in NESN using this container? It appears that it might work the old way NESN authenticated. I can't get it work and assume others are struggling as well, but just wanted to confirm.
I can confirm. Once NESN changed how the logins work it broke EPlusTV's ability to authenticate and pull in the channels for me as well.
That's what I figured. I was surprised to see this as an option in the EPlusTV settings.
At this point it should be removed to avoid future confusion.
Did the DRM?
They are? I did a complete rebuild just to make sure, and the Fox ones are the only linear stations I can't get to work.
I don't know about DRM. The login flow is different so it no longer works with EPlusTV. They send you an email now with the code to log in. They used to generate a code on the device.
I literally just Che ked from my mobile and FS1 tunes in fine.
As far as I can tell, Fox Sports should not be working from EPlusTV.
However, I am preparing a fix, hopefully published tonight.
If you have another source for FS1 in Channels, Channels may be tuning to that source instead of the one from EPlus.
A user on GitHub said the new NESN was DRM’ed anyway.
But if anyone wants to lend me credentials, I would be happy to take a look!
Now that's crazy I have 2 FS1 and FS2 in my guide 1 is TVE which works fine the other 2 were EPlusTV channels with all sources enabled I can tune both FS1 BUT after disabling all sources except EplusTV I lose FS1 So yup funky magic behind the channels scene..... Lol
Channels will fall back to the next available source if the first one fails. This is great when recording and a channel drops.
Bring down the details when viewing that channel and it will show you the channel number it's tuned to, bitrate, etc...
Do you think the new Fox One app will be compatible with Eplus? They have some linear channels too
FS1, FS2, and BTN should be working again in version 4.10.3
It might work. I plan to take a look at it eventually.
