Similar here Works very well usually BUT ive been getting more freeze ups during YES games and sometimes total lockup and the container needs a restart which luckily i can usually do from my phone via teamviewer
I had that problem on the same game, but wasn't quite that frequent, maybe once or twice an hour.
Well I feel dumb, I know that about the 2-3 days, but guess I thought the season started this weekend with pre-season ending last weekend. Thanks
I believe it does, when linked to a NFL.com account.
I can't get ESPN+ events to play. Is this because I have ESPN unlimited thru my DirecTV stream subscription? The events show up in the guide and even work in the ESPN app, just won't play thru the container.
Try to reauthenticate in the web portal. I'm using ESPN Unlimited and the events are playing fine. It took me to my Disney login page then the events would play.
Are NBA games in this app? I know amazon prime has live events and if its redudant I wont add. I am making a chrome capture/hdmi capture epg for those events.
I'm using ESPN Unlimited Bundle. How did you get it to go to the Disney login page? That's what I need to do - but it just gives me cable providers (tried Hulu, that won't work)
The current version of E+TV (4.10.3) does not allow authentication for linear channels (ESPN, ESPN2, etc) without a TV provider. There is a pull request to possibly change this to also use Unlimited login credentials.
Your Unlimited credentials will work for ESPN+ content but not linear channels.
Once you turn on ESPN+ it took me to the Disney login page, and now all ESPN+ events populate and will play in Channels. I logged in with Spectrum for linear.
Got it! Will keep an eye out for this - just what I need! I canceled YouTubeTV now that I have ESPN Unlimited.
Ahh, thank you, I see - ESPN Unlimited includes the linear channels now so I don't have a cable/TV provider anymore - based on other comments it seems I will need to wait for an update to EPlusTV to integrate the ESPN Unlimited Creds for linear channels.
Just checking. CBS credentials also allow paramount integration? Are soccer/rugby on the CBS side of integration?
schedule.db is 0kb, logs look like they got a bunch of entries, says "finished building the schedule" too. the linear channels work, but the there is nothing for all of the other ones. i have tried stopping and restarting, stopping then deleting schedule.db, and pressing the "rebuild epg" button in the eplus web interface. any ideas?
@tonywagner this persists on 4.10.4 for me
Fox network event scheduling should now be fixed in version 4.10.4
fs1 and fs2 play but no epg. b1g and fox soccer plus and msg2 and msgsn2 and espnnews and accn and sec and espnhd don't play. not trying to be rude, just giving an accurate state of eplustv.
It sounds like you need to update to the new version 4.10.4 (Docker image "tonywagner/eplustv").
If issues persist after that update, you will need to provide more details about how you are authenticating.
Yeah this is not my experience. Only had issues with fox channels after switching to tonywagners container.
Tony,
Thanks for taking this on. Just checking...does YTTV support the digital networks? It seems linear are all working including FS1 & FS2. Holiday so I am not seeing a lot of other events.
already on 4.10.4. I have fubo gotham sports sling and amazon prime. hope that helps.
