Usually it means you are out of channel numbers so it avoids duplicating. Not sure why it jumps so high but ive seen it do this several times in my env.
I don't have anything between 7062 and 9043. The 7900 range should be good.
Are yall still having issues with fox stuttering? ESPN3 seems to be working , for now.
Could have been you did at one point in time. Ive seen that as well. If you are worried about it just do it on the eplus gui and then tell channels to prefer the channel number from the m3u
Zeam seems to be working well. Nice work
Tony I sent you some code I use to get my local news, however if I make a server it takes 5 seconds to load can you look at it and see if you can help it go a bit faster? It does a little auth key handoff
Also could you also add ESPN Deportes to the linear channels? Sorry for the request you rock
Version checking added in v4.13.3. Prints to the upper right as described, and will also print to the log (console) once per run per version.
Awesome thanks @tonywagner
Pm sent
Anyone have issues with NFL Sunday Ticket with EPlus TV. Worked great for 3 weeks, and was able to start watching a game earlier today (flyiing back home, was watching on my phone), but when I stepped away and came back 30 minutes later, I couldn't access the NFL Sunday Ticket games (could get my local via OTA).
Got home and tried to trouble shoot. No joy, reinstalled twice (even deleted the volume and recreated), confirmed my YTTV is linked in my NFL account, and can watch games via YTTV app. Just not on the EPlus Docker.
Logs after resintalling looks like it's not picking up any "events" even after connecting with NFL. Not sure what else to do to try and trouble shoot. Thanks,
I can't speak for Sunday Ticket, but I had problems getting the 9:30 London game to work on NFL Network. The guide was just showing that it was going to be sunday previews on NFL Network, but my CC4C docker was trying to record from its NFL Network channel. I had to restart the docker, rebuild the EPG and reload the guide into Channels before it would work properly. Could be an NFL issue?
That sounds like your local container was locked up, I was able to watch the London game via E+ no problem.
Sorry for the noob docker question, but can anyone tell me how to update my docker container to the newest version of EPlusTV.
When i originally installed this I did:
docker pull tonywagner/eplustv
docker run --restart always -p 8000:8000 -v config_dir:/app/config tonywagner/eplustv
That was based on the instructions found on https://hub.docker.com/r/tonywagner/eplustv
Now that I want to update I've done:
which seems to pull the latest image. But stopping and restarting the container does not show that the running version of EPlusTV has changed to the latest version.
Can anyone help?
One issue with EPG
Im seeing an old WPHL listing with an invalid date
<programme channel="102.eplustv" start="Invalid date" stop="Invalid date">
<title lang="en">PWHL - New York Sirens vs Montréal Victoire - Youtube</title>
<video/>
<desc lang="en">PWHL - New York Sirens vs Montréal Victoire - Youtube</desc>
An unrelated could it be possible to make the icon value a variable to use our own icon vs the one hardcoded?
Delete the container and run your docker Run command again to load it.
Weird! Does it go away after disabling the PWHL provider?
It's pretty easy to change channel logos in bulk on TVHeadend, but perhaps not on Channels DVR?
I know there is a pending pull request to change the icon, but perhaps making it customizable would be better. I'll keep that in mind.
I pull all my channels through Threadfin so that I can customize the channel number and logos and then pull it back into channels. Would be great if we could do it natively within Channels, but this is actually pretty easy once you set it up.
But wouldn't this lose all my settings/configuration?
Nope! That's all stored in your local "config_dir". So the recreated container will continue to use it.
Any way to support NBA League pass? I had been doing it with ADBTuner and YTTV but with Amazon owning league pass now I'm not sure how it will work.
