OK. I noticed that my SEC Network+ was working under EPlusTV last night. Is it intermittently not working or do certain channels still work? Thanks
SEC Network+ isn't DRM-d so it'll work. The only things ESPN-wise that are DRM'd are ESPN+ (or ESPN Select)
Well I spent some time messing with it today. I changed DNS to Cloudflare and it didn't seem to make a difference. Then changed to Google. Same.
Does the error log look identical to you?
2025-11-12 19:10:22.348 |
2025-11-12 19:10:22.348 | > [email protected] start
2025-11-12 19:10:22.348 | > ts-node -r tsconfig-paths/register index.tsx
2025-11-12 19:10:33.852 | === E+TV v4.14.4 starting ===
2025-11-12 19:10:40.032 | Updating FOX One prelim token
2025-11-12 19:10:40.386 | Refreshing TV Provider token (FOX One)
2025-11-12 19:10:41.651 | HTTP server started on port 8000
2025-11-12 19:10:41.896 | === Getting events ===
2025-11-12 19:10:41.905 | Looking for FOX One events...
2025-11-12 19:10:45.383 | === Done getting events ===
2025-11-12 19:10:45.383 | === Building the schedule ===
2025-11-12 19:10:45.389 | === Done building the schedule ===
2025-11-12 19:10:55.240 | Channel #316 has an active event (Jesse Watters Primetime). Going to start the stream.
2025-11-12 19:25:19.001 | Channel #312 has an active event (College Basketball - Wisconsin-Milwaukee at Indiana). Going to start the stream.
2025-11-12 19:26:43.948 | Could not parse chunklist properly!
2025-11-12 19:26:43.986 | Could not get chunklist for channel #316.
2025-11-12 19:26:43.986 | AxiosError: timeout of 60000ms exceeded
2025-11-12 19:26:43.987 |     at RedirectableRequest.handleRequestTimeout (/app/node_modules/axios/lib/adapters/http.js:570:16)
2025-11-12 19:26:43.987 |     at RedirectableRequest.emit (node:events:517:28)
2025-11-12 19:26:43.987 |     at RedirectableRequest.emit (node:domain:489:12)
2025-11-12 19:26:43.987 |     at Timeout.<anonymous> (/app/node_modules/follow-redirects/index.js:169:12)
2025-11-12 19:26:43.987 |     at listOnTimeout (node:internal/timers:569:17)
2025-11-12 19:26:43.987 |     at processTimers (node:internal/timers:512:7) {
2025-11-12 19:26:43.987 |   code: 'ECONNABORTED',
2025-11-12 19:26:43.987 |   config: {
2025-11-12 19:26:43.987 |     transitional: {
2025-11-12 19:26:43.987 |       silentJSONParsing: true,
2025-11-12 19:26:43.987 |       forcedJSONParsing: true,
2025-11-12 19:26:43.987 |       clarifyTimeoutError: false
2025-11-12 19:26:43.987 |     },
2025-11-12 19:26:43.987 |     adapter: [ 'xhr', 'http' ],
2025-11-12 19:26:43.987 |     transformRequest: [ [Function: transformRequest] ],
2025-11-12 19:26:43.987 |     transformResponse: [ [Function: transformResponse] ],
2025-11-12 19:26:43.987 |     timeout: 60000,
2025-11-12 19:26:43.987 |     xsrfCookieName: 'XSRF-TOKEN',
2025-11-12 19:26:43.987 |     xsrfHeaderName: 'X-XSRF-TOKEN',
2025-11-12 19:26:43.987 |     maxContentLength: -1,
2025-11-12 19:26:43.987 |     maxBodyLength: -1,
2025-11-12 19:26:43.987 |     env: { FormData: [Function [FormData]], Blob: [class Blob] },
2025-11-12 19:26:43.987 |     validateStatus: [Function: validateStatus],
2025-11-12 19:26:43.987 |     headers: AxiosHeaders {
2025-11-12 19:26:43.987 |       Accept: 'application/json, text/plain, */*',
2025-11-12 19:26:43.987 |       'Accept-Encoding': 'identity',
2025-11-12 19:26:43.987 |       'User-Agent': 'foxone-androidtv/1.3.0 (Linux; Android 12; en-us; onn. 4K Streaming Box Build/SGZ1.221127.063.A1.9885170)'
2025-11-12 19:26:43.987 |     method: 'get',
2025-11-12 19:26:43.987 |     url: 'https://foxdtc-video.akamaized.net/live-dr/fnc-ue2/hdntl=exp=1763082655~acl=%2f*~data=hdntl~hmac=eccbddb286e5e600d07db98baa90dad9dab0fea00f8d06be389c93e9fe251a13/index_7.m3u8',
2025-11-12 19:26:43.987 |     data: undefined
2025-11-12 19:26:43.987 |   request: <ref *1> Writable {
2025-11-12 19:26:43.987 |     _writableState: WritableState {
2025-11-12 19:26:43.987 |       objectMode: false,
2025-11-12 19:26:43.987 |       highWaterMark: 16384,
2025-11-12 19:26:43.987 |       finalCalled: false,
2025-11-12 19:26:43.987 |       needDrain: false,
2025-11-12 19:26:43.987 |       ending: false,
2025-11-12 19:26:43.987 |       ended: false,
2025-11-12 19:26:43.987 |       finished: false,
2025-11-12 19:26:43.987 |       destroyed: false,
2025-11-12 19:26:43.987 |       decodeStrings: true,
2025-11-12 19:26:43.987 |       defaultEncoding: 'utf8',
2025-11-12 19:26:43.987 |       length: 0,
2025-11-12 19:26:43.987 |       writing: false,
2025-11-12 19:26:43.987 |       corked: 0,
2025-11-12 19:26:43.987 |       sync: true,
2025-11-12 19:26:43.987 |       bufferProcessing: false,
2025-11-12 19:26:43.987 |       onwrite: [Function: bound onwrite],
2025-11-12 19:26:43.987 |       writecb: null,
2025-11-12 19:26:43.987 |       writelen: 0,
2025-11-12 19:26:43.987 |       afterWriteTickInfo: null,
2025-11-12 19:26:43.987 |       buffered: [],
2025-11-12 19:26:43.987 |       bufferedIndex: 0,
2025-11-12 19:26:43.987 |       allBuffers: true,
2025-11-12 19:26:43.987 |       allNoop: true,
2025-11-12 19:26:43.987 |       pendingcb: 0,
2025-11-12 19:26:43.987 |       constructed: true,
2025-11-12 19:26:43.987 |       prefinished: false,
2025-11-12 19:26:43.987 |       errorEmitted: false,
2025-11-12 19:26:43.987 |       emitClose: true,
2025-11-12 19:26:43.988 |       autoDestroy: true,
2025-11-12 19:26:43.988 |       errored: null,
2025-11-12 19:26:43.988 |       closed: false,
2025-11-12 19:26:43.988 |       closeEmitted: false,
2025-11-12 19:26:43.988 |       [Symbol(kOnFinished)]: []
2025-11-12 19:26:43.988 |     },
2025-11-12 19:26:43.988 |     _events: [Object: null prototype] {
2025-11-12 19:26:43.988 |       response: [Function: handleResponse],
2025-11-12 19:26:43.988 |       error: [Function: handleRequestError],
2025-11-12 19:26:43.988 |       socket: [Array]
2025-11-12 19:26:43.988 |     _eventsCount: 3,
2025-11-12 19:26:43.988 |     _maxListeners: undefined,
2025-11-12 19:26:43.988 |     _options: {
2025-11-12 19:26:43.988 |       maxRedirects: 21,
2025-11-12 19:26:43.988 |       maxBodyLength: Infinity,
2025-11-12 19:26:43.988 |       protocol: 'https:',
2025-11-12 19:26:43.988 |       path: '/live-dr/fnc-ue2/hdntl=exp=1763082655~acl=%2f*~data=hdntl~hmac=eccbddb286e5e600d07db98baa90dad9dab0fea00f8d06be389c93e9fe251a13/index_7.m3u8',
2025-11-12 19:26:43.988 |       method: 'GET',
2025-11-12 19:26:43.988 |       headers: [Object: null prototype],
2025-11-12 19:26:43.988 |       agents: [Object],
2025-11-12 19:26:43.988 |       auth: undefined,
2025-11-12 19:26:43.988 |       beforeRedirect: [Function: dispatchBeforeRedirect],
2025-11-12 19:26:43.988 |       beforeRedirects: [Object],
2025-11-12 19:26:43.988 |       hostname: 'foxdtc-video.akamaized.net',
2025-11-12 19:26:43.988 |       port: '',
2025-11-12 19:26:43.988 |       agent: undefined,
2025-11-12 19:26:43.988 |       nativeProtocols: [Object],
2025-11-12 19:26:43.988 |       pathname: '/live-dr/fnc-ue2/hdntl=exp=1763082655~acl=%2f*~data=hdntl~hmac=eccbddb286e5e600d07db98baa90dad9dab0fea00f8d06be389c93e9fe251a13/index_7.m3u8'
2025-11-12 19:26:43.988 |     _ended: true,
2025-11-12 19:26:43.988 |     _ending: true,
2025-11-12 19:26:43.988 |     _redirectCount: 0,
2025-11-12 19:26:43.988 |     _redirects: [],
2025-11-12 19:26:43.988 |     _requestBodyLength: 0,
2025-11-12 19:26:43.988 |     _requestBodyBuffers: [],
2025-11-12 19:26:43.988 |     _onNativeResponse: [Function (anonymous)],
2025-11-12 19:26:43.988 |     _currentRequest: ClientRequest {
2025-11-12 19:26:43.988 |       _events: [Object: null prototype],
2025-11-12 19:26:43.988 |       _eventsCount: 7,
2025-11-12 19:26:43.988 |       outputData: [],
2025-11-12 19:26:43.988 |       outputSize: 0,
2025-11-12 19:26:43.988 |       writable: true,
2025-11-12 19:26:43.988 |       destroyed: false,
2025-11-12 19:26:43.988 |       _last: true,
2025-11-12 19:26:43.988 |       chunkedEncoding: false,
2025-11-12 19:26:43.988 |       shouldKeepAlive: false,
2025-11-12 19:26:43.988 |       maxRequestsOnConnectionReached: false,
2025-11-12 19:26:43.988 |       _defaultKeepAlive: true,
2025-11-12 19:26:43.988 |       useChunkedEncodingByDefault: false,
2025-11-12 19:26:43.988 |       sendDate: false,
2025-11-12 19:26:43.988 |       _removedConnection: false,
2025-11-12 19:26:43.988 |       _removedContLen: false,
2025-11-12 19:26:43.988 |       _removedTE: false,
2025-11-12 19:26:43.988 |       strictContentLength: false,
2025-11-12 19:26:43.988 |       _contentLength: 0,
2025-11-12 19:26:43.988 |       _hasBody: true,
2025-11-12 19:26:43.988 |       _trailer: '',
2025-11-12 19:26:43.988 |       finished: true,
2025-11-12 19:26:43.988 |       _headerSent: true,
2025-11-12 19:26:43.988 |       _closed: false,
2025-11-12 19:26:43.988 |       socket: [TLSSocket],
2025-11-12 19:26:43.988 |       _header: 'GET /live-dr/fnc-ue2/hdntl=exp=1763082655~acl=%2f*~data=hdntl~hmac=eccbddb286e5e600d07db98baa90dad9dab0fea00f8d06be389c93e9fe251a13/index_7.m3u8 HTTP/1.1\r\n' +
2025-11-12 19:26:43.988 |         'Accept: application/json, text/plain, */*\r\n' +
2025-11-12 19:26:43.988 |         'Accept-Encoding: identity\r\n' +
2025-11-12 19:26:43.988 |         'User-Agent: foxone-androidtv/1.3.0 (Linux; Android 12; en-us; onn. 4K Streaming Box Build/SGZ1.221127.063.A1.9885170)\r\n' +
2025-11-12 19:26:43.988 |         'Host: foxdtc-video.akamaized.net\r\n' +
2025-11-12 19:26:43.988 |         'Connection: close\r\n' +
2025-11-12 19:26:43.988 |         '\r\n',
2025-11-12 19:26:43.988 |       _keepAliveTimeout: 0,
2025-11-12 19:26:43.988 |       _onPendingData: [Function: nop],
2025-11-12 19:26:43.988 |       agent: [Agent],
2025-11-12 19:26:43.988 |       socketPath: undefined,
2025-11-12 19:26:43.988 |       maxHeaderSize: undefined,
2025-11-12 19:26:43.988 |       insecureHTTPParser: undefined,
2025-11-12 19:26:43.988 |       joinDuplicateHeaders: undefined,
2025-11-12 19:26:43.988 |       _ended: false,
2025-11-12 19:26:43.988 |       res: null,
2025-11-12 19:26:43.988 |       aborted: false,
2025-11-12 19:26:43.988 |       timeoutCb: null,
2025-11-12 19:26:43.988 |       upgradeOrConnect: false,
2025-11-12 19:26:43.988 |       parser: [HTTPParser],
2025-11-12 19:26:43.988 |       maxHeadersCount: null,
2025-11-12 19:26:43.989 |       reusedSocket: false,
2025-11-12 19:26:43.989 |       host: 'foxdtc-video.akamaized.net',
2025-11-12 19:26:43.989 |       protocol: 'https:',
2025-11-12 19:26:43.989 |       _redirectable: [Circular *1],
2025-11-12 19:26:43.989 |       [Symbol(kCapture)]: false,
2025-11-12 19:26:43.989 |       [Symbol(kBytesWritten)]: 0,
2025-11-12 19:26:43.989 |       [Symbol(kNeedDrain)]: false,
2025-11-12 19:26:43.989 |       [Symbol(corked)]: 0,
2025-11-12 19:26:43.989 |       [Symbol(kOutHeaders)]: [Object: null prototype],
2025-11-12 19:26:43.989 |       [Symbol(errored)]: null,
2025-11-12 19:26:43.989 |       [Symbol(kHighWaterMark)]: 16384,
2025-11-12 19:26:43.989 |       [Symbol(kRejectNonStandardBodyWrites)]: false,
2025-11-12 19:26:43.989 |       [Symbol(kUniqueHeaders)]: null
2025-11-12 19:26:43.989 |     },
2025-11-12 19:26:43.989 |     _currentUrl: 'https://foxdtc-video.akamaized.net/live-dr/fnc-ue2/hdntl=exp=1763082655~acl=%2f*~data=hdntl~hmac=eccbddb286e5e600d07db98baa90dad9dab0fea00f8d06be389c93e9fe251a13/index_7.m3u8',
2025-11-12 19:26:43.989 |     _timeout: null,
I'm not sure of the timeout details as to what it's timing out on. A developer would have to tell you.
My best guess is it's timing out after 60 seconds trying to get a playlist.
Are you sure you overrode the container DNS?
You have to use bridge mode networking to do that.
You can verify the DNS servers the container is using by looking at the file /etc/resolv.conf inside the eplustv container
sudo docker exec eplustv cat /etc/resolv.conf
nameserver 75.75.75.75
nameserver 75.75.76.76
And by doing these nslookup commands from docker to see what DNS server IP address the container is using (Server:)
fastly.net
sudo docker exec eplustv nslookup fa.edge.foxdtc.digitalvideoplatform.com
Server:         75.75.75.75
Address:        75.75.75.75:53
Non-authoritative answer:
fa.edge.foxdtc.digitalvideoplatform.com canonical name = fa-dvpvideo.map.fastly.net
Address: 151.101.42.18
Address: 2a04:4e42:a::530
cloudfront.net
sudo docker exec eplustv nslookup cf.edge.foxdtc.digitalvideoplatform.com
Server:         75.75.75.75
cf.edge.foxdtc.digitalvideoplatform.com canonical name = d33560mwi6nhtw.cloudfront.net
Address: 108.138.246.122
Address: 108.138.246.2
Address: 108.138.246.84
Address: 108.138.246.46
Address: 2600:9000:234c:ae00:14:9b62:100:93a1
Address: 2600:9000:234c:f800:14:9b62:100:93a1
Address: 2600:9000:234c:5e00:14:9b62:100:93a1
Address: 2600:9000:234c:9c00:14:9b62:100:93a1
Address: 2600:9000:234c:c400:14:9b62:100:93a1
Address: 2600:9000:234c:2400:14:9b62:100:93a1
Address: 2600:9000:234c:a600:14:9b62:100:93a1
Address: 2600:9000:234c:a00:14:9b62:100:93a1
akamai.net
sudo docker exec eplustv nslookup foxdtc-video.akamaized.net
Server:         75.75.75.75
foxdtc-video.akamaized.net      canonical name = a1626.dscz.akamai.net
Address: 23.200.146.67
Address: 23.200.146.83
Address: 2600:1406:c400::17c8:9253
Address: 2600:1406:c400::17c8:9243
Do you have any ad blockers or DNS filtering running (including on your router)?
Try overriding the container DNS with your ISP's DNS Server IP address. For my Xfinity it's
--dns=75.75.75.75
And then verify it stuck by using the docker commands I posted.
It looks the same. Same timeout in the same place.
This is correct. It is timing out trying to get the playlist.
Thanks for responding. I tried to watch it last night and it isn't working again. What I did notice is that sec network worked, Sec network + didn't. Maybe I was looking at the SEC network the night before.
Would it be possible to add a high school conference to Hudl as well? The one I am looking at locally would be Minnesota High School Sports. I believe Team1 and Hudl are the same. Thanks for considering. I tried looking at your Hudl handler but I don't know how to find the slug for a conference.
It appears that ESPN3 has the same issue as SEC+, and likely ACC Extra too.
It sounds like they may have recently migrated those digital networks to DRM, joining ESPN+.
Can anyone else confirm?
If so, I'd guess that the ESPN linear networks are on borrowed time here as well.
This should be do-able, I will look into it. It might take some work in the EPlusTV GUI to handle state/team/conference selections, with so many available.
That would be awesome to have and I’m sure others would appreciate it with all the high school sports on this platform!
Sorry for the delay. Been slammed with work!
I do not have any ad blockers or DNS filtering. I will change from Google DNS to my ISP DNS and try again, although that's what I had at the beginning of this.
I have the following code in my Docker Engine:
  "dns": [
    "8.8.8.8",
    "8.8.4.4"
Running this I get:
# Generated by Docker Engine.
# This file can be edited; Docker Engine will not make further changes once it
# has been modified.
nameserver 8.8.8.8
nameserver 8.8.4.4
# Based on host file: '/etc/resolv.conf' (legacy)
# Overrides: [nameservers]
Running this I get:
Server:         8.8.8.8
Address:        8.8.8.8:53
Address: 151.101.2.18
Address: 151.101.66.18
Address: 151.101.194.18
Address: 151.101.130.18
Address: 2a04:4e42:200::530
Address: 2a04:4e42::530
Address: 2a04:4e42:600::530
Address: 2a04:4e42:400::530
Running this I get:
Server:         8.8.8.8
Address:        8.8.8.8:53
Address: 206.222.215.165
Address: 2605:d000:3e8:3e9:a7a0::1
Running this I get:
Server:         8.8.8.8
Address:        8.8.8.8:53
Address: 23.195.81.24
Address: 23.195.81.26
Address: 2600:1405:6400::17c3:5118
Address: 2600:1405:6400::17c3:511a
Ok so switched back to my ISP DNS and it just crashed again...
2025-11-14 12:54:56.312 | === Done building the schedule ===
2025-11-14 12:55:05.553 | Channel #316 has an active event (America Reports). Going to start the stream.
2025-11-14 13:14:00.935 | Error fetching 316-segment-1HWiWfvE: timeout of 60000ms exceeded
2025-11-14 13:14:00.975 | AxiosError: timeout of 60000ms exceeded
2025-11-14 13:14:00.975 |     at RedirectableRequest.handleRequestTimeout (/app/node_modules/axios/lib/adapters/http.js:570:16)
2025-11-14 13:14:00.975 |     at RedirectableRequest.emit (node:events:517:28)
2025-11-14 13:14:00.975 |     at RedirectableRequest.emit (node:domain:489:12)
2025-11-14 13:14:00.975 |     at Timeout.<anonymous> (/app/node_modules/follow-redirects/index.js:169:12)
2025-11-14 13:14:00.975 |     at listOnTimeout (node:internal/timers:569:17)
2025-11-14 13:14:00.975 |     at processTimers (node:internal/timers:512:7) {
2025-11-14 13:14:00.975 |   code: 'ECONNABORTED',
2025-11-14 13:14:00.975 |   config: {
2025-11-14 13:14:00.975 |     transitional: {
2025-11-14 13:14:00.975 |       silentJSONParsing: true,
2025-11-14 13:14:00.975 |       forcedJSONParsing: true,
2025-11-14 13:14:00.975 |       clarifyTimeoutError: false
2025-11-14 13:14:00.975 |     },
2025-11-14 13:14:00.975 |     adapter: [ 'xhr', 'http' ],
2025-11-14 13:14:00.975 |     transformRequest: [ [Function: transformRequest] ],
2025-11-14 13:14:00.975 |     transformResponse: [ [Function: transformResponse] ],
2025-11-14 13:14:00.975 |     timeout: 60000,
2025-11-14 13:14:00.975 |     xsrfCookieName: 'XSRF-TOKEN',
2025-11-14 13:14:00.975 |     xsrfHeaderName: 'X-XSRF-TOKEN',
2025-11-14 13:14:00.975 |     maxContentLength: -1,
2025-11-14 13:14:00.975 |     maxBodyLength: -1,
2025-11-14 13:14:00.975 |     env: { FormData: [Function [FormData]], Blob: [class Blob] },
2025-11-14 13:14:00.975 |     validateStatus: [Function: validateStatus],
2025-11-14 13:14:00.975 |     headers: AxiosHeaders {
2025-11-14 13:14:00.975 |       Accept: 'application/json, text/plain, */*',
2025-11-14 13:14:00.975 |       'User-Agent': 'foxone-androidtv/1.3.0 (Linux; Android 12; en-us; onn. 4K Streaming Box Build/SGZ1.221127.063.A1.9885170)',
2025-11-14 13:14:00.975 |       'Accept-Encoding': 'gzip, compress, deflate, br'
2025-11-14 13:14:00.975 |     responseType: 'arraybuffer',
2025-11-14 13:14:00.975 |     method: 'get',
2025-11-14 13:14:00.975 |     url: 'https://foxdtc-video.akamaized.net/live-dr/fnc-ue2/hdntl=exp=1763232903~acl=%2f*~data=hdntl~hmac=b91fa6aa0d5e3c3323f7cdb2289073b9f20186e368b66c4515200865e20787ed/segment_7_8945676.ts',
2025-11-14 13:14:00.975 |     data: undefined
2025-11-14 13:14:00.975 |   request: <ref *1> Writable {
2025-11-14 13:14:00.975 |     _writableState: WritableState {
2025-11-14 13:14:00.975 |       objectMode: false,
2025-11-14 13:14:00.975 |       highWaterMark: 16384,
2025-11-14 13:14:00.975 |       finalCalled: false,
2025-11-14 13:14:00.975 |       needDrain: false,
2025-11-14 13:14:00.975 |       ending: false,
2025-11-14 13:14:00.975 |       ended: false,
2025-11-14 13:14:00.975 |       finished: false,
2025-11-14 13:14:00.975 |       destroyed: false,
2025-11-14 13:14:00.975 |       decodeStrings: true,
2025-11-14 13:14:00.975 |       defaultEncoding: 'utf8',
2025-11-14 13:14:00.975 |       length: 0,
2025-11-14 13:14:00.975 |       writing: false,
2025-11-14 13:14:00.975 |       corked: 0,
2025-11-14 13:14:00.975 |       sync: true,
2025-11-14 13:14:00.975 |       bufferProcessing: false,
2025-11-14 13:14:00.975 |       onwrite: [Function: bound onwrite],
2025-11-14 13:14:00.975 |       writecb: null,
2025-11-14 13:14:00.975 |       writelen: 0,
2025-11-14 13:14:00.975 |       afterWriteTickInfo: null,
2025-11-14 13:14:00.975 |       buffered: [],
2025-11-14 13:14:00.976 |       bufferedIndex: 0,
2025-11-14 13:14:00.976 |       allBuffers: true,
2025-11-14 13:14:00.976 |       allNoop: true,
2025-11-14 13:14:00.976 |       pendingcb: 0,
2025-11-14 13:14:00.976 |       constructed: true,
2025-11-14 13:14:00.976 |       prefinished: false,
2025-11-14 13:14:00.976 |       errorEmitted: false,
2025-11-14 13:14:00.976 |       emitClose: true,
2025-11-14 13:14:00.976 |       autoDestroy: true,
2025-11-14 13:14:00.976 |       errored: null,
2025-11-14 13:14:00.976 |       closed: false,
2025-11-14 13:14:00.976 |       closeEmitted: false,
2025-11-14 13:14:00.976 |       [Symbol(kOnFinished)]: []
2025-11-14 13:14:00.976 |     },
2025-11-14 13:14:00.976 |     _events: [Object: null prototype] {
2025-11-14 13:14:00.976 |       response: [Function: handleResponse],
2025-11-14 13:14:00.976 |       error: [Function: handleRequestError],
2025-11-14 13:14:00.976 |       socket: [Array]
2025-11-14 13:14:00.976 |     _eventsCount: 3,
2025-11-14 13:14:00.976 |     _maxListeners: undefined,
2025-11-14 13:14:00.976 |     _options: {
2025-11-14 13:14:00.976 |       maxRedirects: 21,
2025-11-14 13:14:00.976 |       maxBodyLength: Infinity,
2025-11-14 13:14:00.976 |       protocol: 'https:',
2025-11-14 13:14:00.976 |       path: '/live-dr/fnc-ue2/hdntl=exp=1763232903~acl=%2f*~data=hdntl~hmac=b91fa6aa0d5e3c3323f7cdb2289073b9f20186e368b66c4515200865e20787ed/segment_7_8945676.ts',
2025-11-14 13:14:00.976 |       method: 'GET',
2025-11-14 13:14:00.976 |       headers: [Object: null prototype],
2025-11-14 13:14:00.976 |       agents: [Object],
2025-11-14 13:14:00.976 |       auth: undefined,
2025-11-14 13:14:00.976 |       beforeRedirect: [Function: dispatchBeforeRedirect],
2025-11-14 13:14:00.976 |       beforeRedirects: [Object],
2025-11-14 13:14:00.976 |       hostname: 'foxdtc-video.akamaized.net',
2025-11-14 13:14:00.976 |       port: '',
2025-11-14 13:14:00.976 |       agent: undefined,
2025-11-14 13:14:00.976 |       nativeProtocols: [Object],
2025-11-14 13:14:00.976 |       pathname: '/live-dr/fnc-ue2/hdntl=exp=1763232903~acl=%2f*~data=hdntl~hmac=b91fa6aa0d5e3c3323f7cdb2289073b9f20186e368b66c4515200865e20787ed/segment_7_8945676.ts'
2025-11-14 13:14:00.976 |     _ended: true,
2025-11-14 13:14:00.976 |     _ending: true,
2025-11-14 13:14:00.976 |     _redirectCount: 0,
2025-11-14 13:14:00.976 |     _redirects: [],
2025-11-14 13:14:00.976 |     _requestBodyLength: 0,
2025-11-14 13:14:00.976 |     _requestBodyBuffers: [],
2025-11-14 13:14:00.976 |     _onNativeResponse: [Function (anonymous)],
2025-11-14 13:14:00.976 |     _currentRequest: ClientRequest {
2025-11-14 13:14:00.976 |       _events: [Object: null prototype],
2025-11-14 13:14:00.976 |       _eventsCount: 7,
2025-11-14 13:14:00.976 |       outputData: [],
2025-11-14 13:14:00.976 |       outputSize: 0,
2025-11-14 13:14:00.976 |       writable: true,
2025-11-14 13:14:00.976 |       destroyed: false,
2025-11-14 13:14:00.976 |       _last: true,
2025-11-14 13:14:00.976 |       chunkedEncoding: false,
2025-11-14 13:14:00.976 |       shouldKeepAlive: false,
2025-11-14 13:14:00.976 |       maxRequestsOnConnectionReached: false,
2025-11-14 13:14:00.976 |       _defaultKeepAlive: true,
2025-11-14 13:14:00.976 |       useChunkedEncodingByDefault: false,
2025-11-14 13:14:00.976 |       sendDate: false,
2025-11-14 13:14:00.976 |       _removedConnection: false,
2025-11-14 13:14:00.976 |       _removedContLen: false,
2025-11-14 13:14:00.976 |       _removedTE: false,
2025-11-14 13:14:00.976 |       strictContentLength: false,
2025-11-14 13:14:00.976 |       _contentLength: 0,
2025-11-14 13:14:00.976 |       _hasBody: true,
2025-11-14 13:14:00.976 |       _trailer: '',
2025-11-14 13:14:00.976 |       finished: true,
2025-11-14 13:14:00.976 |       _headerSent: true,
2025-11-14 13:14:00.976 |       _closed: false,
2025-11-14 13:14:00.976 |       socket: [TLSSocket],
2025-11-14 13:14:00.976 |       _header: 'GET /live-dr/fnc-ue2/hdntl=exp=1763232903~acl=%2f*~data=hdntl~hmac=b91fa6aa0d5e3c3323f7cdb2289073b9f20186e368b66c4515200865e20787ed/segment_7_8945676.ts HTTP/1.1\r\n' +
2025-11-14 13:14:00.976 |         'Accept: application/json, text/plain, */*\r\n' +
2025-11-14 13:14:00.976 |         'User-Agent: foxone-androidtv/1.3.0 (Linux; Android 12; en-us; onn. 4K Streaming Box Build/SGZ1.221127.063.A1.9885170)\r\n' +
2025-11-14 13:14:00.976 |         'Accept-Encoding: gzip, compress, deflate, br\r\n' +
2025-11-14 13:14:00.976 |         'Host: foxdtc-video.akamaized.net\r\n' +
2025-11-14 13:14:00.976 |         'Connection: close\r\n' +
2025-11-14 13:14:00.976 |         '\r\n',
2025-11-14 13:14:00.976 |       _keepAliveTimeout: 0,
2025-11-14 13:14:00.976 |       _onPendingData: [Function: nop],
2025-11-14 13:14:00.976 |       agent: [Agent],
2025-11-14 13:14:00.977 |       socketPath: undefined,
2025-11-14 13:14:00.977 |       method: 'GET',
2025-11-14 13:14:00.977 |       maxHeaderSize: undefined,
2025-11-14 13:14:00.977 |       insecureHTTPParser: undefined,
2025-11-14 13:14:00.977 |       joinDuplicateHeaders: undefined,
2025-11-14 13:14:00.977 |       path: '/live-dr/fnc-ue2/hdntl=exp=1763232903~acl=%2f*~data=hdntl~hmac=b91fa6aa0d5e3c3323f7cdb2289073b9f20186e368b66c4515200865e20787ed/segment_7_8945676.ts',
2025-11-14 13:14:00.977 |       _ended: false,
2025-11-14 13:14:00.977 |       res: null,
2025-11-14 13:14:00.977 |       aborted: false,
2025-11-14 13:14:00.977 |       timeoutCb: null,
2025-11-14 13:14:00.977 |       upgradeOrConnect: false,
2025-11-14 13:14:00.977 |       parser: [HTTPParser],
2025-11-14 13:14:00.977 |       maxHeadersCount: null,
2025-11-14 13:14:00.977 |       reusedSocket: false,
2025-11-14 13:14:00.977 |       host: 'foxdtc-video.akamaized.net',
2025-11-14 13:14:00.977 |       protocol: 'https:',
2025-11-14 13:14:00.977 |       _redirectable: [Circular *1],
2025-11-14 13:14:00.977 |       [Symbol(kCapture)]: false,
2025-11-14 13:14:00.977 |       [Symbol(kBytesWritten)]: 0,
2025-11-14 13:14:00.977 |       [Symbol(kNeedDrain)]: false,
2025-11-14 13:14:00.977 |       [Symbol(corked)]: 0,
2025-11-14 13:14:00.977 |       [Symbol(kOutHeaders)]: [Object: null prototype],
2025-11-14 13:14:00.977 |       [Symbol(errored)]: null,
2025-11-14 13:14:00.977 |       [Symbol(kHighWaterMark)]: 16384,
2025-11-14 13:14:00.977 |       [Symbol(kRejectNonStandardBodyWrites)]: false,
2025-11-14 13:14:00.977 |       [Symbol(kUniqueHeaders)]: null
2025-11-14 13:14:00.977 |     },
2025-11-14 13:14:00.977 |     _currentUrl: 'https://foxdtc-video.akamaized.net/live-dr/fnc-ue2/hdntl=exp=1763232903~acl=%2f*~data=hdntl~hmac=b91fa6aa0d5e3c3323f7cdb2289073b9f20186e368b66c4515200865e20787ed/segment_7_8945676.ts',
2025-11-14 13:14:00.977 |     _timeout: null,
2025-11-14 13:14:00.978 | AxiosError: timeout of 60000ms exceeded
2025-11-14 13:14:00.978 |     at RedirectableRequest.handleRequestTimeout (/app/node_modules/axios/lib/adapters/http.js:570:16)
2025-11-14 13:14:00.978 |     at RedirectableRequest.emit (node:events:517:28)
2025-11-14 13:14:00.978 |     at RedirectableRequest.emit (node:domain:489:12)
2025-11-14 13:14:00.978 |     at Timeout.<anonymous> (/app/node_modules/follow-redirects/index.js:169:12)
2025-11-14 13:14:00.978 |     at listOnTimeout (node:internal/timers:569:17)
2025-11-14 13:14:00.978 |     at processTimers (node:internal/timers:512:7) {
2025-11-14 13:14:00.978 |   code: 'ECONNABORTED',
2025-11-14 13:14:00.978 |   config: {
2025-11-14 13:14:00.978 |     transitional: {
2025-11-14 13:14:00.978 |       silentJSONParsing: true,
2025-11-14 13:14:00.978 |       forcedJSONParsing: true,
2025-11-14 13:14:00.978 |       clarifyTimeoutError: false
2025-11-14 13:14:00.978 |     },
2025-11-14 13:14:00.978 |     adapter: [ 'xhr', 'http' ],
2025-11-14 13:14:00.978 |     transformRequest: [ [Function: transformRequest] ],
2025-11-14 13:14:00.978 |     transformResponse: [ [Function: transformResponse] ],
2025-11-14 13:14:00.978 |     timeout: 60000,
2025-11-14 13:14:00.978 |     xsrfCookieName: 'XSRF-TOKEN',
2025-11-14 13:14:00.978 |     xsrfHeaderName: 'X-XSRF-TOKEN',
2025-11-14 13:14:00.978 |     maxContentLength: -1,
2025-11-14 13:14:00.978 |     maxBodyLength: -1,
2025-11-14 13:14:00.978 |     env: { FormData: [Function [FormData]], Blob: [class Blob] },
2025-11-14 13:14:00.978 |     validateStatus: [Function: validateStatus],
2025-11-14 13:14:00.978 |     headers: AxiosHeaders {
2025-11-14 13:14:00.978 |       Accept: 'application/json, text/plain, */*',
2025-11-14 13:14:00.978 |       'User-Agent': 'foxone-androidtv/1.3.0 (Linux; Android 12; en-us; onn. 4K Streaming Box Build/SGZ1.221127.063.A1.9885170)',
2025-11-14 13:14:00.978 |       'Accept-Encoding': 'gzip, compress, deflate, br'
2025-11-14 13:14:00.978 |     responseType: 'arraybuffer',
2025-11-14 13:14:00.978 |     method: 'get',
2025-11-14 13:14:00.978 |     url: 'https://foxdtc-video.akamaized.net/live-dr/fnc-ue2/hdntl=exp=1763232903~acl=%2f*~data=hdntl~hmac=b91fa6aa0d5e3c3323f7cdb2289073b9f20186e368b66c4515200865e20787ed/segment_7_8945676.ts',
2025-11-14 13:14:00.978 |     data: undefined
2025-11-14 13:14:00.978 |   request: <ref *1> Writable {
2025-11-14 13:14:00.978 |     _writableState: WritableState {
2025-11-14 13:14:00.978 |       objectMode: false,
2025-11-14 13:14:00.978 |       highWaterMark: 16384,
2025-11-14 13:14:00.978 |       finalCalled: false,
2025-11-14 13:14:00.978 |       needDrain: false,
2025-11-14 13:14:00.978 |       ending: false,
2025-11-14 13:14:00.978 |       ended: false,
2025-11-14 13:14:00.978 |       finished: false,
2025-11-14 13:14:00.978 |       destroyed: false,
2025-11-14 13:14:00.978 |       decodeStrings: true,
2025-11-14 13:14:00.978 |       defaultEncoding: 'utf8',
2025-11-14 13:14:00.978 |       length: 0,
2025-11-14 13:14:00.978 |       writing: false,
2025-11-14 13:14:00.978 |       corked: 0,
2025-11-14 13:14:00.978 |       sync: true,
2025-11-14 13:14:00.978 |       bufferProcessing: false,
2025-11-14 13:14:00.978 |       onwrite: [Function: bound onwrite],
2025-11-14 13:14:00.978 |       writecb: null,
2025-11-14 13:14:00.978 |       writelen: 0,
2025-11-14 13:14:00.978 |       afterWriteTickInfo: null,
2025-11-14 13:14:00.978 |       buffered: [],
2025-11-14 13:14:00.978 |       bufferedIndex: 0,
2025-11-14 13:14:00.978 |       allBuffers: true,
2025-11-14 13:14:00.978 |       allNoop: true,
2025-11-14 13:14:00.978 |       pendingcb: 0,
2025-11-14 13:14:00.978 |       constructed: true,
2025-11-14 13:14:00.978 |       prefinished: false,
2025-11-14 13:14:00.979 |       errorEmitted: false,
2025-11-14 13:14:00.979 |       emitClose: true,
2025-11-14 13:14:00.979 |       autoDestroy: true,
2025-11-14 13:14:00.979 |       errored: null,
2025-11-14 13:14:00.979 |       closed: false,
2025-11-14 13:14:00.979 |       closeEmitted: false,
2025-11-14 13:14:00.979 |       [Symbol(kOnFinished)]: []
2025-11-14 13:14:00.979 |     },
2025-11-14 13:14:00.979 |     _events: [Object: null prototype] {
2025-11-14 13:14:00.979 |       response: [Function: handleResponse],
2025-11-14 13:14:00.979 |       error: [Function: handleRequestError],
2025-11-14 13:14:00.979 |       socket: [Array]
2025-11-14 13:14:00.979 |     _eventsCount: 3,
2025-11-14 13:14:00.979 |     _maxListeners: undefined,
2025-11-14 13:14:00.979 |     _options: {
2025-11-14 13:14:00.979 |       maxRedirects: 21,
2025-11-14 13:14:00.979 |       maxBodyLength: Infinity,
2025-11-14 13:14:00.979 |       protocol: 'https:',
2025-11-14 13:14:00.979 |       path: '/live-dr/fnc-ue2/hdntl=exp=1763232903~acl=%2f*~data=hdntl~hmac=b91fa6aa0d5e3c3323f7cdb2289073b9f20186e368b66c4515200865e20787ed/segment_7_8945676.ts',
2025-11-14 13:14:00.979 |       method: 'GET',
2025-11-14 13:14:00.979 |       headers: [Object: null prototype],
2025-11-14 13:14:00.979 |       agents: [Object],
2025-11-14 13:14:00.979 |       auth: undefined,
2025-11-14 13:14:00.979 |       beforeRedirect: [Function: dispatchBeforeRedirect],
2025-11-14 13:14:00.979 |       beforeRedirects: [Object],
2025-11-14 13:14:00.979 |       hostname: 'foxdtc-video.akamaized.net',
2025-11-14 13:14:00.979 |       port: '',
2025-11-14 13:14:00.979 |       agent: undefined,
2025-11-14 13:14:00.979 |       nativeProtocols: [Object],
2025-11-14 13:14:00.979 |       pathname: '/live-dr/fnc-ue2/hdntl=exp=1763232903~acl=%2f*~data=hdntl~hmac=b91fa6aa0d5e3c3323f7cdb2289073b9f20186e368b66c4515200865e20787ed/segment_7_8945676.ts'
2025-11-14 13:14:00.979 |     _ended: true,
2025-11-14 13:14:00.979 |     _ending: true,
2025-11-14 13:14:00.979 |     _redirectCount: 0,
2025-11-14 13:14:00.979 |     _redirects: [],
2025-11-14 13:14:00.979 |     _requestBodyLength: 0,
2025-11-14 13:14:00.979 |     _requestBodyBuffers: [],
2025-11-14 13:14:00.979 |     _onNativeResponse: [Function (anonymous)],
2025-11-14 13:14:00.979 |     _currentRequest: ClientRequest {
2025-11-14 13:14:00.979 |       _events: [Object: null prototype],
2025-11-14 13:14:00.979 |       _eventsCount: 7,
2025-11-14 13:14:00.979 |       outputData: [],
2025-11-14 13:14:00.979 |       outputSize: 0,
2025-11-14 13:14:00.979 |       writable: true,
2025-11-14 13:14:00.979 |       destroyed: false,
2025-11-14 13:14:00.979 |       _last: true,
2025-11-14 13:14:00.979 |       chunkedEncoding: false,
2025-11-14 13:14:00.979 |       shouldKeepAlive: false,
2025-11-14 13:14:00.979 |       maxRequestsOnConnectionReached: false,
2025-11-14 13:14:00.979 |       _defaultKeepAlive: true,
2025-11-14 13:14:00.979 |       useChunkedEncodingByDefault: false,
2025-11-14 13:14:00.979 |       sendDate: false,
2025-11-14 13:14:00.979 |       _removedConnection: false,
2025-11-14 13:14:00.979 |       _removedContLen: false,
2025-11-14 13:14:00.979 |       _removedTE: false,
2025-11-14 13:14:00.979 |       strictContentLength: false,
2025-11-14 13:14:00.979 |       _contentLength: 0,
2025-11-14 13:14:00.979 |       _hasBody: true,
2025-11-14 13:14:00.979 |       _trailer: '',
2025-11-14 13:14:00.979 |       finished: true,
2025-11-14 13:14:00.979 |       _headerSent: true,
2025-11-14 13:14:00.979 |       _closed: false,
2025-11-14 13:14:00.979 |       socket: [TLSSocket],
2025-11-14 13:14:00.979 |       _header: 'GET /live-dr/fnc-ue2/hdntl=exp=1763232903~acl=%2f*~data=hdntl~hmac=b91fa6aa0d5e3c3323f7cdb2289073b9f20186e368b66c4515200865e20787ed/segment_7_8945676.ts HTTP/1.1\r\n' +
2025-11-14 13:14:00.979 |         'Accept: application/json, text/plain, */*\r\n' +
2025-11-14 13:14:00.979 |         'User-Agent: foxone-androidtv/1.3.0 (Linux; Android 12; en-us; onn. 4K Streaming Box Build/SGZ1.221127.063.A1.9885170)\r\n' +
2025-11-14 13:14:00.979 |         'Accept-Encoding: gzip, compress, deflate, br\r\n' +
2025-11-14 13:14:00.979 |         'Host: foxdtc-video.akamaized.net\r\n' +
2025-11-14 13:14:00.979 |         'Connection: close\r\n' +
2025-11-14 13:14:00.979 |         '\r\n',
2025-11-14 13:14:00.979 |       _keepAliveTimeout: 0,
2025-11-14 13:14:00.979 |       _onPendingData: [Function: nop],
2025-11-14 13:14:00.979 |       agent: [Agent],
2025-11-14 13:14:00.979 |       socketPath: undefined,
2025-11-14 13:14:00.979 |       maxHeaderSize: undefined,
2025-11-14 13:14:00.979 |       insecureHTTPParser: undefined,
2025-11-14 13:14:00.979 |       joinDuplicateHeaders: undefined,
2025-11-14 13:14:00.979 |       _ended: false,
2025-11-14 13:14:00.979 |       res: null,
2025-11-14 13:14:00.979 |       aborted: false,
2025-11-14 13:14:00.979 |       timeoutCb: null,
2025-11-14 13:14:00.979 |       upgradeOrConnect: false,
2025-11-14 13:14:00.979 |       parser: [HTTPParser],
2025-11-14 13:14:00.979 |       maxHeadersCount: null,
2025-11-14 13:14:00.979 |       reusedSocket: false,
2025-11-14 13:14:00.979 |       host: 'foxdtc-video.akamaized.net',
2025-11-14 13:14:00.979 |       _redirectable: [Circular *1],
2025-11-14 13:14:00.979 |       [Symbol(kCapture)]: false,
2025-11-14 13:14:00.979 |       [Symbol(kBytesWritten)]: 0,
2025-11-14 13:14:00.979 |       [Symbol(kNeedDrain)]: false,
2025-11-14 13:14:00.979 |       [Symbol(corked)]: 0,
2025-11-14 13:14:00.979 |       [Symbol(kOutHeaders)]: [Object: null prototype],
2025-11-14 13:14:00.979 |       [Symbol(errored)]: null,
2025-11-14 13:14:00.979 |       [Symbol(kHighWaterMark)]: 16384,
2025-11-14 13:14:00.979 |       [Symbol(kRejectNonStandardBodyWrites)]: false,
2025-11-14 13:14:00.979 |       [Symbol(kUniqueHeaders)]: null
2025-11-14 13:14:00.979 |     _currentUrl: 'https://foxdtc-video.akamaized.net/live-dr/fnc-ue2/hdntl=exp=1763232903~acl=%2f*~data=hdntl~hmac=b91fa6aa0d5e3c3323f7cdb2289073b9f20186e368b66c4515200865e20787ed/segment_7_8945676.ts',
2025-11-14 13:14:00.979 |     _timeout: null,
2025-11-14 13:14:00.980 |     [Symbol(kCapture)]: false
2025-11-14 13:14:00.980 |   }
2025-11-14 13:14:00.980 | Error fetching 316-segment-1HWiWfvE: Cached segment or key failed to resolve!
In my docker settings there is:
Default networking mode: set to IPv4 only
Inhibit DNS resolution for IPv4/IPv6: set to Auto
Those look correct?
Those look fine.
Ok need an explanation on this. I set 10 items from Fox One EPLUSTV to record last night to test recording versus Live playback. Every one of them has a red "Interrupted" label in the Channels DVR interface. However if I navigate to any of the 10 recordings in Windows and try to play with VLC, all of them seem to have completed the entire time and play back properly. Example, if it was a 2 hour basketball game, the file size is 2 hours long and it plays and looks normal with the file showing 2 hours long in VLC. If the program was 1 hour long the file is 1 hour long and shows 1 hour in VLC and plays and looks normal. All 10 files.
Is this odd? Does this explain anything?
How did you switch back to your ISP DNS?
Do it as a container override with --dsn=x.x.x.x in your docker run statement
Otherwise it uses the docker engine DNS relay (which caused me problems)
What does your container /etc/resolv.conf look like?
Look at the Channels DVR log for the interruptions.
Channels DVR will splice together the video when it's interrupted and there will be glitches in it (at best) or the timestamps will be corrupted (at worst).
Where did you get that from?
Is ESPN3 and SEC+ drm now?
I assume sec+ and ESPN3 are drm now?
