Any idea what might be causing these two errors?
Lots of Invalid Playlist : EXTINF duration errors
2025-11-26T11:00:00.409692470Z Channel #219 has an active event (Sesame Street Night). Going to start the stream.
2025-11-26T11:06:28.330909483Z Invalid Playlist : EXTINF duration, when rounded to the nearest integer, MUST be less than or equal to the target duration
Same error repeated 358 more times
2025-11-26T11:21:25.167082529Z Invalid Playlist : EXTINF duration, when rounded to the nearest integer, MUST be less than or equal to the target duration
Then later, the recording was interrupted with the error Could not get chunklist for channel and Channels DVR logged it as GET: http://192.168.1.4:8185/chunklist/219/rampLS8u.m3u8: 404 Not Found
2025-11-26T12:11:06.364902049Z Could not parse chunklist properly!
2025-11-26T12:11:06.843604552Z AxiosError: Request failed with status code 400
2025-11-26T12:11:06.843915343Z     at settle (/app/node_modules/axios/lib/core/settle.js:19:12)
2025-11-26T12:11:06.844017492Z     at IncomingMessage.handleStreamEnd (/app/node_modules/axios/lib/adapters/http.js:512:11)
2025-11-26T12:11:06.844075296Z     at IncomingMessage.emit (node:events:529:35)
2025-11-26T12:11:06.844131915Z     at IncomingMessage.emit (node:domain:489:12)
2025-11-26T12:11:06.844178955Z     at endReadableNT (node:internal/streams/readable:1400:12)
2025-11-26T12:11:06.844234764Z     at processTicksAndRejections (node:internal/process/task_queues:82:21) {
2025-11-26T12:11:06.844285778Z   code: 'ERR_BAD_REQUEST',
2025-11-26T12:11:06.844335037Z   config: {
2025-11-26T12:11:06.844379698Z     transitional: {
2025-11-26T12:11:06.844435579Z       silentJSONParsing: true,
2025-11-26T12:11:06.844480760Z       forcedJSONParsing: true,
2025-11-26T12:11:06.844530715Z       clarifyTimeoutError: false
2025-11-26T12:11:06.844575146Z     },
2025-11-26T12:11:06.844620468Z     adapter: [ 'xhr', 'http' ],
2025-11-26T12:11:06.844664261Z     transformRequest: [ [Function: transformRequest] ],
2025-11-26T12:11:06.844714482Z     transformResponse: [ [Function: transformResponse] ],
2025-11-26T12:11:06.844758304Z     timeout: 60000,
2025-11-26T12:11:06.844806169Z     xsrfCookieName: 'XSRF-TOKEN',
2025-11-26T12:11:06.844851215Z     xsrfHeaderName: 'X-XSRF-TOKEN',
2025-11-26T12:11:06.843813110Z Could not get chunklist for channel #219.
2025-11-26T12:11:06.845024028Z     maxContentLength: -1,
2025-11-26T12:11:06.845146187Z     maxBodyLength: -1,
2025-11-26T12:11:06.845187049Z     env: { FormData: [Function [FormData]], Blob: [class Blob] },
2025-11-26T12:11:06.845233880Z     validateStatus: [Function: validateStatus],
2025-11-26T12:11:06.845284445Z     headers: AxiosHeaders {
2025-11-26T12:11:06.845326637Z       Accept: 'application/json, text/plain, */*',
2025-11-26T12:11:06.845372176Z       'Accept-Encoding': 'identity',
2025-11-26T12:11:06.845458849Z       'User-Agent': 'foxone-androidtv/1.3.0 (Linux; Android 12; en-us; onn. 4K Streaming Box Build/SGZ1.221127.063.A1.9885170)'
2025-11-26T12:11:06.845530643Z     },
2025-11-26T12:11:06.845568726Z     method: 'get',
2025-11-26T12:11:06.845609314Z     url: 'https://cf.edge.foxdtc.digitalvideoplatform.com/59ec84a713f0b265a24af6e25fbd5e17ccfd1c73.20251126170001/live-dr/fmsc-ue2/index_7.m3u8?zipcode=95630',
2025-11-26T12:11:06.845747827Z     data: undefined
2025-11-26T12:11:06.845802726Z   },
2025-11-26T12:11:06.845840723Z   request: <ref *1> ClientRequest {
2025-11-26T12:11:06.845887305Z     _events: [Object: null prototype] {
2025-11-26T12:11:06.845959924Z       abort: [Function (anonymous)],
2025-11-26T12:11:06.846003334Z       aborted: [Function (anonymous)],
2025-11-26T12:11:06.846051112Z       connect: [Function (anonymous)],
2025-11-26T12:11:06.846091749Z       error: [Function (anonymous)],
2025-11-26T12:11:06.846132753Z       socket: [Function (anonymous)],
2025-11-26T12:11:06.846173221Z       timeout: [Function (anonymous)],
2025-11-26T12:11:06.846212809Z       finish: [Function: requestOnFinish]
2025-11-26T12:11:06.846255429Z     },
2025-11-26T12:11:06.846291842Z     _eventsCount: 7,
2025-11-26T12:11:06.846330780Z     _maxListeners: undefined,
2025-11-26T12:11:06.846376265Z     outputData: [],
2025-11-26T12:11:06.846441145Z     outputSize: 0,
2025-11-26T12:11:06.846483070Z     writable: true,
2025-11-26T12:11:06.846524243Z     destroyed: false,
2025-11-26T12:11:06.846566897Z     _last: true,
2025-11-26T12:11:06.846606258Z     chunkedEncoding: false,
2025-11-26T12:11:06.846652079Z     shouldKeepAlive: false,
2025-11-26T12:11:06.846699768Z     maxRequestsOnConnectionReached: false,
2025-11-26T12:11:06.846743196Z     _defaultKeepAlive: true,
2025-11-26T12:11:06.846786601Z     useChunkedEncodingByDefault: false,
2025-11-26T12:11:06.846829319Z     sendDate: false,
2025-11-26T12:11:06.846870273Z     _removedConnection: false,
2025-11-26T12:11:06.846911966Z     _removedContLen: false,
2025-11-26T12:11:06.846952391Z     _removedTE: false,
2025-11-26T12:11:06.846992457Z     strictContentLength: false,
2025-11-26T12:11:06.847034500Z     _contentLength: 0,
2025-11-26T12:11:06.847074418Z     _hasBody: true,
2025-11-26T12:11:06.847115833Z     _trailer: '',
2025-11-26T12:11:06.847159363Z     finished: true,
2025-11-26T12:11:06.847199040Z     _headerSent: true,
2025-11-26T12:11:06.847238256Z     _closed: false,
2025-11-26T12:11:06.847280291Z     socket: TLSSocket {
2025-11-26T12:11:06.847320355Z       _tlsOptions: [Object],
2025-11-26T12:11:06.847362095Z       _secureEstablished: true,
2025-11-26T12:11:06.847403395Z       _securePending: false,
2025-11-26T12:11:06.847476126Z       _newSessionPending: false,
2025-11-26T12:11:06.847518623Z       _controlReleased: true,
2025-11-26T12:11:06.847557690Z       secureConnecting: false,
2025-11-26T12:11:06.847598396Z       _SNICallback: null,
2025-11-26T12:11:06.847638633Z       servername: 'cf.edge.foxdtc.digitalvideoplatform.com',
2025-11-26T12:11:06.847690531Z       alpnProtocol: false,
2025-11-26T12:11:06.847731354Z       authorized: true,
2025-11-26T12:11:06.847772441Z       authorizationError: null,
2025-11-26T12:11:06.847812863Z       encrypted: true,
2025-11-26T12:11:06.847854421Z       _events: [Object: null prototype],
2025-11-26T12:11:06.847895589Z       _eventsCount: 10,
2025-11-26T12:11:06.847935063Z       connecting: false,
2025-11-26T12:11:06.847978405Z       _hadError: false,
2025-11-26T12:11:06.848021118Z       _parent: null,
2025-11-26T12:11:06.848064144Z       _host: 'cf.edge.foxdtc.digitalvideoplatform.com',
2025-11-26T12:11:06.848114861Z       _closeAfterHandlingError: false,
2025-11-26T12:11:06.848157537Z       _readableState: [ReadableState],
2025-11-26T12:11:06.848200974Z       _maxListeners: undefined,
2025-11-26T12:11:06.848241579Z       _writableState: [WritableState],
2025-11-26T12:11:06.848282480Z       allowHalfOpen: false,
2025-11-26T12:11:06.848327808Z       _sockname: null,
2025-11-26T12:11:06.848369697Z       _pendingData: null,
2025-11-26T12:11:06.848423410Z       _pendingEncoding: '',
2025-11-26T12:11:06.848464355Z       server: undefined,
2025-11-26T12:11:06.848505949Z       _server: null,
2025-11-26T12:11:06.848547440Z       ssl: [TLSWrap],
2025-11-26T12:11:06.848586607Z       _requestCert: true,
2025-11-26T12:11:06.848626896Z       _rejectUnauthorized: true,
2025-11-26T12:11:06.848667300Z       parser: null,
2025-11-26T12:11:06.848706761Z       _httpMessage: [Circular *1],
2025-11-26T12:11:06.848747567Z       timeout: 60000,
2025-11-26T12:11:06.848786152Z       [Symbol(alpncallback)]: null,
2025-11-26T12:11:06.848827832Z       [Symbol(res)]: [TLSWrap],
2025-11-26T12:11:06.848869198Z       [Symbol(verified)]: true,
2025-11-26T12:11:06.848910996Z       [Symbol(pendingSession)]: null,
2025-11-26T12:11:06.848953190Z       [Symbol(async_id_symbol)]: 1247694,
2025-11-26T12:11:06.848995328Z       [Symbol(kHandle)]: [TLSWrap],
2025-11-26T12:11:06.849037858Z       [Symbol(lastWriteQueueSize)]: 0,
2025-11-26T12:11:06.849079929Z       [Symbol(timeout)]: Timeout {
2025-11-26T12:11:06.849119869Z         _idleTimeout: 60000,
2025-11-26T12:11:06.849160019Z         _idlePrev: [TimersList],
2025-11-26T12:11:06.849205868Z         _idleNext: [Timeout],
2025-11-26T12:11:06.849249238Z         _idleStart: 274380630,
2025-11-26T12:11:06.849293798Z         _onTimeout: [Function: bound ],
2025-11-26T12:11:06.849336857Z         _timerArgs: undefined,
2025-11-26T12:11:06.849379689Z         _repeat: null,
2025-11-26T12:11:06.849447347Z         _destroyed: false,
2025-11-26T12:11:06.849507378Z         [Symbol(refed)]: false,
2025-11-26T12:11:06.849551051Z         [Symbol(kHasPrimitive)]: false,
2025-11-26T12:11:06.849593192Z         [Symbol(asyncId)]: 1247702,
2025-11-26T12:11:06.849638089Z         [Symbol(triggerId)]: 1247697
2025-11-26T12:11:06.849679872Z       },
2025-11-26T12:11:06.849725136Z       [Symbol(kBuffer)]: null,
2025-11-26T12:11:06.849766348Z       [Symbol(kBufferCb)]: null,
2025-11-26T12:11:06.849806104Z       [Symbol(kBufferGen)]: null,
2025-11-26T12:11:06.849846960Z       [Symbol(kCapture)]: false,
2025-11-26T12:11:06.849893426Z       [Symbol(kSetNoDelay)]: false,
2025-11-26T12:11:06.849936200Z       [Symbol(kSetKeepAlive)]: true,
2025-11-26T12:11:06.849979275Z       [Symbol(kSetKeepAliveInitialDelay)]: 60,
2025-11-26T12:11:06.850020704Z       [Symbol(kBytesRead)]: 0,
2025-11-26T12:11:06.850063988Z       [Symbol(kBytesWritten)]: 0,
2025-11-26T12:11:06.850103063Z       [Symbol(connect-options)]: [Object]
2025-11-26T12:11:06.850144690Z     },
2025-11-26T12:11:06.850181044Z     _header: 'GET /59ec84a713f0b265a24af6e25fbd5e17ccfd1c73.20251126170001/live-dr/fmsc-ue2/index_7.m3u8?zipcode=95630 HTTP/1.1\r\n' +
2025-11-26T12:11:06.850235669Z       'Accept: application/json, text/plain, */*\r\n' +
2025-11-26T12:11:06.850279389Z       'Accept-Encoding: identity\r\n' +
2025-11-26T12:11:06.850321158Z       'User-Agent: foxone-androidtv/1.3.0 (Linux; Android 12; en-us; onn. 4K Streaming Box Build/SGZ1.221127.063.A1.9885170)\r\n' +
2025-11-26T12:11:06.850375180Z       'Host: cf.edge.foxdtc.digitalvideoplatform.com\r\n' +
2025-11-26T12:11:06.850434773Z       'Connection: close\r\n' +
2025-11-26T12:11:06.850477541Z       '\r\n',
2025-11-26T12:11:06.850514789Z     _keepAliveTimeout: 0,
2025-11-26T12:11:06.850552825Z     _onPendingData: [Function: nop],
2025-11-26T12:11:06.850599161Z     agent: Agent {
2025-11-26T12:11:06.850637793Z       _events: [Object: null prototype],
2025-11-26T12:11:06.850681424Z       _eventsCount: 2,
2025-11-26T12:11:06.850720397Z       _maxListeners: undefined,
2025-11-26T12:11:06.850759913Z       defaultPort: 443,
2025-11-26T12:11:06.850802783Z       protocol: 'https:',
2025-11-26T12:11:06.850842792Z       options: [Object: null prototype],
2025-11-26T12:11:06.850889696Z       requests: [Object: null prototype] {},
2025-11-26T12:11:06.850933261Z       sockets: [Object: null prototype],
2025-11-26T12:11:06.850975550Z       freeSockets: [Object: null prototype] {},
2025-11-26T12:11:06.851019906Z       keepAliveMsecs: 1000,
2025-11-26T12:11:06.851059455Z       keepAlive: false,
2025-11-26T12:11:06.851099097Z       maxSockets: Infinity,
2025-11-26T12:11:06.851139147Z       maxFreeSockets: 256,
2025-11-26T12:11:06.851177850Z       scheduling: 'lifo',
2025-11-26T12:11:06.851217660Z       maxTotalSockets: Infinity,
2025-11-26T12:11:06.851257277Z       totalSocketCount: 1,
2025-11-26T12:11:06.851296694Z       maxCachedSessions: 100,
2025-11-26T12:11:06.851371112Z       _sessionCache: [Object],
2025-11-26T12:11:06.851417529Z       [Symbol(kCapture)]: false
2025-11-26T12:11:06.851458497Z     },
2025-11-26T12:11:06.851496962Z     socketPath: undefined,
2025-11-26T12:11:06.851536330Z     method: 'GET',
2025-11-26T12:11:06.851574308Z     maxHeaderSize: undefined,
2025-11-26T12:11:06.851613862Z     insecureHTTPParser: undefined,
2025-11-26T12:11:06.851653529Z     joinDuplicateHeaders: undefined,
2025-11-26T12:11:06.851695921Z     path: '/59ec84a713f0b265a24af6e25fbd5e17ccfd1c73.20251126170001/live-dr/fmsc-ue2/index_7.m3u8?zipcode=95630',
2025-11-26T12:11:06.851743828Z     _ended: true,
2025-11-26T12:11:06.851786420Z     res: IncomingMessage {
2025-11-26T12:11:06.851831506Z       _readableState: [ReadableState],
2025-11-26T12:11:06.851871258Z       _events: [Object: null prototype],
2025-11-26T12:11:06.851910611Z       _eventsCount: 4,
2025-11-26T12:11:06.851949405Z       _maxListeners: undefined,
2025-11-26T12:11:06.851987696Z       socket: [TLSSocket],
2025-11-26T12:11:06.852031553Z       httpVersionMajor: 1,
2025-11-26T12:11:06.852070943Z       httpVersionMinor: 1,
2025-11-26T12:11:06.852109059Z       httpVersion: '1.1',
2025-11-26T12:11:06.852147474Z       complete: true,
2025-11-26T12:11:06.852186647Z       rawHeaders: [Array],
2025-11-26T12:11:06.852231829Z       rawTrailers: [],
2025-11-26T12:11:06.852270900Z       joinDuplicateHeaders: undefined,
2025-11-26T12:11:06.852309758Z       aborted: false,
2025-11-26T12:11:06.852348511Z       upgrade: false,
2025-11-26T12:11:06.852387300Z       url: '',
2025-11-26T12:11:06.852433877Z       method: null,
2025-11-26T12:11:06.852471960Z       statusCode: 400,
2025-11-26T12:11:06.852510813Z       statusMessage: 'Bad Request',
2025-11-26T12:11:06.852552865Z       client: [TLSSocket],
2025-11-26T12:11:06.852592413Z       _consuming: false,
2025-11-26T12:11:06.852631309Z       _dumped: false,
2025-11-26T12:11:06.852673462Z       req: [Circular *1],
2025-11-26T12:11:06.852713053Z       responseUrl: 'https://cf.edge.foxdtc.digitalvideoplatform.com/59ec84a713f0b265a24af6e25fbd5e17ccfd1c73.20251126170001/live-dr/fmsc-ue2/index_7.m3u8?zipcode=95630',
2025-11-26T12:11:06.852765039Z       redirects: [],
2025-11-26T12:11:06.852803827Z       [Symbol(kCapture)]: false,
2025-11-26T12:11:06.852842734Z       [Symbol(kHeaders)]: [Object],
2025-11-26T12:11:06.852882299Z       [Symbol(kHeadersCount)]: 22,
2025-11-26T12:11:06.852926998Z       [Symbol(kTrailers)]: null,
2025-11-26T12:11:06.852967434Z       [Symbol(kTrailersCount)]: 0
2025-11-26T12:11:06.853007428Z     },
2025-11-26T12:11:06.853042907Z     aborted: false,
2025-11-26T12:11:06.853081540Z     timeoutCb: null,
2025-11-26T12:11:06.853120408Z     upgradeOrConnect: false,
2025-11-26T12:11:06.853160878Z     parser: null,
2025-11-26T12:11:06.853200326Z     maxHeadersCount: null,
2025-11-26T12:11:06.853239476Z     reusedSocket: false,
2025-11-26T12:11:06.853278709Z     host: 'cf.edge.foxdtc.digitalvideoplatform.com',
2025-11-26T12:11:06.853321808Z     protocol: 'https:',
2025-11-26T12:11:06.853359534Z     _redirectable: Writable {
2025-11-26T12:11:06.853399401Z       _writableState: [WritableState],
2025-11-26T12:11:06.853449089Z       _events: [Object: null prototype],
2025-11-26T12:11:06.853489012Z       _eventsCount: 3,
2025-11-26T12:11:06.853528605Z       _maxListeners: undefined,
2025-11-26T12:11:06.853567811Z       _options: [Object],
2025-11-26T12:11:06.853606561Z       _ended: true,
2025-11-26T12:11:06.853647387Z       _ending: true,
2025-11-26T12:11:06.853688162Z       _redirectCount: 0,
2025-11-26T12:11:06.853726934Z       _redirects: [],
2025-11-26T12:11:06.853766755Z       _requestBodyLength: 0,
2025-11-26T12:11:06.853805267Z       _requestBodyBuffers: [],
2025-11-26T12:11:06.853843659Z       _onNativeResponse: [Function (anonymous)],
2025-11-26T12:11:06.853884336Z       _currentRequest: [Circular *1],
2025-11-26T12:11:06.853924482Z       _currentUrl: 'https://cf.edge.foxdtc.digitalvideoplatform.com/59ec84a713f0b265a24af6e25fbd5e17ccfd1c73.20251126170001/live-dr/fmsc-ue2/index_7.m3u8?zipcode=95630',
2025-11-26T12:11:06.853977060Z       _timeout: null,
2025-11-26T12:11:06.854016434Z       [Symbol(kCapture)]: false
2025-11-26T12:11:06.854055754Z     },
2025-11-26T12:11:06.854091581Z     [Symbol(kCapture)]: false,
2025-11-26T12:11:06.854129903Z     [Symbol(kBytesWritten)]: 0,
2025-11-26T12:11:06.854169329Z     [Symbol(kNeedDrain)]: false,
2025-11-26T12:11:06.854208924Z     [Symbol(corked)]: 0,
2025-11-26T12:11:06.854251074Z     [Symbol(kOutHeaders)]: [Object: null prototype] {
2025-11-26T12:11:06.854293168Z       accept: [Array],
2025-11-26T12:11:06.854334788Z       'accept-encoding': [Array],
2025-11-26T12:11:06.854398904Z       'user-agent': [Array],
2025-11-26T12:11:06.854445731Z       host: [Array]
2025-11-26T12:11:06.854483591Z     },
2025-11-26T12:11:06.854519182Z     [Symbol(errored)]: null,
2025-11-26T12:11:06.854558042Z     [Symbol(kHighWaterMark)]: 16384,
2025-11-26T12:11:06.854602619Z     [Symbol(kRejectNonStandardBodyWrites)]: false,
2025-11-26T12:11:06.854644773Z     [Symbol(kUniqueHeaders)]: null
2025-11-26T12:11:06.854685965Z   },
2025-11-26T12:11:06.854722115Z   response: {
2025-11-26T12:11:06.854760391Z     status: 400,
2025-11-26T12:11:06.854798743Z     statusText: 'Bad Request',
2025-11-26T12:11:06.854843420Z     headers: AxiosHeaders {
2025-11-26T12:11:06.854882805Z       'content-type': 'application/json',
2025-11-26T12:11:06.854925030Z       'content-length': '61',
2025-11-26T12:11:06.854966973Z       connection: 'close',
2025-11-26T12:11:06.855005738Z       server: 'CloudFront',
2025-11-26T12:11:06.855047834Z       date: 'Wed, 26 Nov 2025 12:11:06 GMT',
2025-11-26T12:11:06.855092409Z       'x-cache': 'Miss from cloudfront',
2025-11-26T12:11:06.855133996Z       via: '1.1 61e47cd082bb04a8fb8ae61dd54f6b32.cloudfront.net (CloudFront)',
2025-11-26T12:11:06.855180515Z       'x-amz-cf-pop': 'SFO5-P1',
2025-11-26T12:11:06.855222329Z       'x-amz-cf-id': '0iQ5DKiQOEDWEtcVcceDSrKSvYThDn18dJYbalM3SfnMCg_jMtJtEw==',
2025-11-26T12:11:06.855264827Z       'x-cdn': 'cloudfront',
2025-11-26T12:11:06.855303908Z       vary: 'Origin'
2025-11-26T12:11:06.855343223Z     },
2025-11-26T12:11:06.855378970Z     config: {
2025-11-26T12:11:06.855426117Z       transitional: [Object],
2025-11-26T12:11:06.855465243Z       adapter: [Array],
2025-11-26T12:11:06.855505616Z       transformRequest: [Array],
2025-11-26T12:11:06.855547007Z       transformResponse: [Array],
2025-11-26T12:11:06.855585761Z       timeout: 60000,
2025-11-26T12:11:06.855624040Z       xsrfCookieName: 'XSRF-TOKEN',
2025-11-26T12:11:06.855665064Z       xsrfHeaderName: 'X-XSRF-TOKEN',
2025-11-26T12:11:06.855704338Z       maxContentLength: -1,
2025-11-26T12:11:06.855741953Z       maxBodyLength: -1,
2025-11-26T12:11:06.855779971Z       env: [Object],
2025-11-26T12:11:06.855819997Z       validateStatus: [Function: validateStatus],
2025-11-26T12:11:06.855861327Z       headers: [AxiosHeaders],
2025-11-26T12:11:06.855899716Z       method: 'get',
2025-11-26T12:11:06.855937804Z       url: 'https://cf.edge.foxdtc.digitalvideoplatform.com/59ec84a713f0b265a24af6e25fbd5e17ccfd1c73.20251126170001/live-dr/fmsc-ue2/index_7.m3u8?zipcode=95630',
2025-11-26T12:11:06.855989071Z       data: undefined
2025-11-26T12:11:06.856027930Z     },
2025-11-26T12:11:06.856063593Z     request: <ref *1> ClientRequest {
2025-11-26T12:11:06.856104870Z       _events: [Object: null prototype],
2025-11-26T12:11:06.856147158Z       _eventsCount: 7,
2025-11-26T12:11:06.856185351Z       _maxListeners: undefined,
2025-11-26T12:11:06.856223335Z       outputData: [],
2025-11-26T12:11:06.856262391Z       outputSize: 0,
2025-11-26T12:11:06.856299758Z       writable: true,
2025-11-26T12:11:06.856338163Z       destroyed: false,
2025-11-26T12:11:06.856376470Z       _last: true,
2025-11-26T12:11:06.856425393Z       chunkedEncoding: false,
2025-11-26T12:11:06.856465182Z       shouldKeepAlive: false,
2025-11-26T12:11:06.856504295Z       maxRequestsOnConnectionReached: false,
2025-11-26T12:11:06.856543179Z       _defaultKeepAlive: true,
2025-11-26T12:11:06.856581175Z       useChunkedEncodingByDefault: false,
2025-11-26T12:11:06.856619409Z       sendDate: false,
2025-11-26T12:11:06.856657781Z       _removedConnection: false,
2025-11-26T12:11:06.856696289Z       _removedContLen: false,
2025-11-26T12:11:06.856734405Z       _removedTE: false,
2025-11-26T12:11:06.856772422Z       strictContentLength: false,
2025-11-26T12:11:06.856810521Z       _contentLength: 0,
2025-11-26T12:11:06.856848158Z       _hasBody: true,
2025-11-26T12:11:06.856890407Z       _trailer: '',
2025-11-26T12:11:06.856927816Z       finished: true,
2025-11-26T12:11:06.856966066Z       _headerSent: true,
2025-11-26T12:11:06.857004031Z       _closed: false,
2025-11-26T12:11:06.857042098Z       socket: [TLSSocket],
2025-11-26T12:11:06.857083396Z       _header: 'GET /59ec84a713f0b265a24af6e25fbd5e17ccfd1c73.20251126170001/live-dr/fmsc-ue2/index_7.m3u8?zipcode=95630 HTTP/1.1\r\n' +
2025-11-26T12:11:06.857131692Z         'Accept: application/json, text/plain, */*\r\n' +
2025-11-26T12:11:06.857173753Z         'Accept-Encoding: identity\r\n' +
2025-11-26T12:11:06.857214368Z         'User-Agent: foxone-androidtv/1.3.0 (Linux; Android 12; en-us; onn. 4K Streaming Box Build/SGZ1.221127.063.A1.9885170)\r\n' +
2025-11-26T12:11:06.857264860Z         'Host: cf.edge.foxdtc.digitalvideoplatform.com\r\n' +
2025-11-26T12:11:06.857307032Z         'Connection: close\r\n' +
2025-11-26T12:11:06.857346872Z         '\r\n',
2025-11-26T12:11:06.857385821Z       _keepAliveTimeout: 0,
2025-11-26T12:11:06.857434870Z       _onPendingData: [Function: nop],
2025-11-26T12:11:06.857475925Z       agent: [Agent],
2025-11-26T12:11:06.857513837Z       socketPath: undefined,
2025-11-26T12:11:06.857552638Z       method: 'GET',
2025-11-26T12:11:06.857590466Z       maxHeaderSize: undefined,
2025-11-26T12:11:06.857629168Z       insecureHTTPParser: undefined,
2025-11-26T12:11:06.857669819Z       joinDuplicateHeaders: undefined,
2025-11-26T12:11:06.857708675Z       path: '/59ec84a713f0b265a24af6e25fbd5e17ccfd1c73.20251126170001/live-dr/fmsc-ue2/index_7.m3u8?zipcode=95630',
2025-11-26T12:11:06.857753112Z       _ended: true,
2025-11-26T12:11:06.857791506Z       res: [IncomingMessage],
2025-11-26T12:11:06.857830374Z       aborted: false,
2025-11-26T12:11:06.857868790Z       timeoutCb: null,
2025-11-26T12:11:06.857930810Z       upgradeOrConnect: false,
2025-11-26T12:11:06.857970089Z       parser: null,
2025-11-26T12:11:06.858007886Z       maxHeadersCount: null,
2025-11-26T12:11:06.858046271Z       reusedSocket: false,
2025-11-26T12:11:06.858084573Z       host: 'cf.edge.foxdtc.digitalvideoplatform.com',
2025-11-26T12:11:06.858125274Z       protocol: 'https:',
2025-11-26T12:11:06.858163278Z       _redirectable: [Writable],
2025-11-26T12:11:06.858204146Z       [Symbol(kCapture)]: false,
2025-11-26T12:11:06.858243844Z       [Symbol(kBytesWritten)]: 0,
2025-11-26T12:11:06.858284145Z       [Symbol(kNeedDrain)]: false,
2025-11-26T12:11:06.858323712Z       [Symbol(corked)]: 0,
2025-11-26T12:11:06.858362488Z       [Symbol(kOutHeaders)]: [Object: null prototype],
2025-11-26T12:11:06.858404438Z       [Symbol(errored)]: null,
2025-11-26T12:11:06.858451168Z       [Symbol(kHighWaterMark)]: 16384,
2025-11-26T12:11:06.858490071Z       [Symbol(kRejectNonStandardBodyWrites)]: false,
2025-11-26T12:11:06.858530054Z       [Symbol(kUniqueHeaders)]: null
2025-11-26T12:11:06.858569246Z     },
2025-11-26T12:11:06.858605237Z     data: { message: 'getManifest error', cause: [Object] }
2025-11-26T12:11:06.858648699Z   }
2025-11-26T12:11:06.858685412Z }
Hi! Thank you for everything you do!
I'm currently having trouble logging in with Paramount Plus. Everything is up to date, but the authenticator won't come up on the web interface. Here's the docker log:
2025-11-26 22:41:29.735 | TypeError: undefined is not iterable (cannot read property Symbol(Symbol.iterator))
2025-11-26 22:41:29.735 | at /app/services/providers/paramount/views/Login.tsx:15:23
2025-11-26 22:41:29.735 | at Generator.next ()
2025-11-26 22:41:29.735 | at fulfilled (/app/services/providers/paramount/views/Login.tsx:5:58)
2025-11-26 22:41:29.735 | at processTicksAndRejections (node:internal/process/task_queues:95:5)
2025-11-26 22:41:29.736 | Could not start the authentication process for Paramount+!
Has anyone tried getting new keys for espn? I changed password and now I cant register it at all.
Hi Tony, thanks for getting back to me on this. Sounds like others have been able to watch Redzone with NFL+ Premium. Do you think this is an issue with my subscription being through youtube? Let me know if there is any way for to get additional information for you when I try again tomorrow. Hope you had a great Thanksgiving. Thank you.
Perhaps the RedZone stream needs to be accessed a bit differently for Sunday Ticket subscribers, as compared to NFL+ subscribers.
I'll private message you with some troubleshooting suggestions for tomorrow.
Version 4.14.9 fixes RedZone for Sunday Ticket subscribers.
NFL+ subscribers might want to test it and make sure RedZone still works for you too!
Hi @tonywagner are you still working on a potential solution for my drops after short random periods of time? Is it isolated to just me?? Thanks
The update fixed NFL Network access via Hulu credentials, gave an error previously but works great now. Don't have Redzone in my package so couldn't check it.
not getting an epg for fox one thanks.
Try hitting the Rebuild EPG button on the container page
It should be fetching EPG data every 4 hours (check the container log)
bingo that did it thanks.
hey ive got an experimental program going for livebarn.. i'll share it when i get it stable.
Gotham Sports (MSG) stopped working tonight.
Log says: Could not get a playlist for channel #160. Please make sure there is an event scheduled and you have access to it.
And http://192.168.1.8000/channels/160.m3u8 is getting a 404 error.
Other channels seem to be working, even other Gotham Sports channels.
Any ideas?
Restart the EPlusTV container and try again — that was reported to work for this Gotham error upthread.
That would be much appreciated if you could pull that off. I think I've got espn4cc4c working with cc4c but sticking with eplustv (and cc4c) would be nicer.
Just a little follow-up that it appears that ESPN3 and many of the smaller other ones like it no longer exist at all and have been folded into ESPN Unlimited...
@KineticMan in case this affects anything you are doing with FruitDeepLinks.
I went back a couple weeks of posts but didn't see anything.
Is ESPN+ no longer accessible? I can play the ESPN channels (YouTube TV account). But my ESPN+ account no longer provides streams. I can authenticate and get XML & EPG but the streams don't work.
How about this post from 11/17
Not sure if that would apply to me? ESPN & it's related channels are all coming through fine.
Not sure. My understanding was that using an ESPN+ account to authenticate doesn't work anymore, only using a provider account will work.
