Try Firefox or Safari.
Seems to be issues using Brave, Chrome and Edge lately.
Thanks.
Separate Question - My guide data for MSG is not being refreshed past the current day
I subscribe to ESPN+ (Unlimited). I authenticated it in E+TV, what do I need to have it show in GetChannels (I don't see and ESPN added. I want to record today's NBA games )
You wonβt be able to use EPlusTV for ESPN Unlimited viewing right now, due to DRM on the streams.
To view via the Channels guide, you could use FruitDeepLinks β Universal Sports Aggregator for Channels DVR - #13 by KineticMan
To record, you will need something like ESPN+ with Custom Channels via ADBTuner
thanks
There's also KineticMan's ESPN4CC4C - GitHub - kineticman/ESPN4CC4C: ESPN+ for Chrome Capture For Channels
May be way late but redzone has worked with nfl+ premium
Iβm doing the initial setup. From the E+ TV page, I turn on NFL, but nothing happens. It doesnβt ask for login information. I have tried chrome , FF and Safari browsers.
When I try to add ESPN with TV provider or ISP, I get:
Open this link and follow instructions:
Code: undefined
v4.14.9
from terminal:
cause: Error: getaddrinfo EAI_AGAIN api.nfl.com at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:107:26) { errno: -3001, code: 'EAI_AGAIN', syscall: 'getaddrinfo', hostname: 'api.nfl.com'
} } Could not start the authentication process for NFL! TypeError: undefined is not iterable (cannot read property Symbol(Symbol.iterator )) at /app/services/providers/nfl/views/Login.tsx:14:16 at Generator.next (<anonymous>) at fulfilled (/app/services/providers/nfl/views/Login.tsx:5:58)
Works fine for me -- toggling on the NFL provider creates an activation link below it. I suspect you are getting blocked by the provider, likely due to running behind a proxy, VPN, or other network (mis)configuration. Can you log in at NFL.com on the same computer?
Is anyone else having audio problems with Victory+? I went from choppy, way out of sync audio on Stars games to no audio at all for the last handful of games. I even had to start recording the games from the Victory+ app on a firetv again but would rather get them from EPlusTV with audio. I just updated docker images so maybe there's a fix in there that I missed.
Also, @tonywagner, I saw a "LOVB Live" source in the web page that I don't remember seeing before and references to LOVB events in a log someone posted. Will that include the LOVB matches on Victory+? If not, would it be possible for you to add support for them?
I recorded one of the WHL games tonight. It had choppy and out of sync audio.
Thanks!!! I gave it a shot and got the container up and running. And after some trial and error I'm finally able to get some livebarn streams running. I did need to set the LAN_IP environment variable to the IP of my machine running the docker container to get it to work.
None of the rinks that I'm interested in publish schedules, so that portion of the container functionality is not relevant for me.
A few questions:
1)When I try to play a channel from a rink that presumably has no activity it seems to failover to some other rink channel that does have activity. Is that expected behavior?
2)I haven't yet been able to stream a rink channel during the time a game is being played, only just practices and public skate - and I've only ever seen the full rink PANO view. When a game is on, is it possible to get the AUTO view, or a way to select between AUTO/PANO if they are both available?
Again, this is pretty awesome. Thanks again for sharing!
hmmm.. i personally haven't noticed that-- in my experience, when livebarn doesnt have a stream going (inactive rink or privacy setting on like tryouts), the stream just doesn't work period. but let me mess with it and see if i can replicate that bug
yea only PANO view. i'd have to dig in further and see what their terrible app sends for Pano/Auto and see if we can borrow that feed. i suspect it's possible -- would probably have to create a seperate channel for each feed?
Regarding #1, incase it helps here are the logs when that situation occurs:
Channels DVR log:
2025/12/30 11:26:00.550935 [ERR] Could not start stream for M3U-livebarn ch9334 California): M3U: 901 Tuner Unreachable: Timeout after 20s connecting to: http://192.168.0.107:5000/proxy/282
2025/12/30 11:26:09.838685 [TNR] Opened connection to M3U-livebarn for ch9335 California)
Livebarn-Manager log:
2025-12-30 14:25:40,550 [WARNING] β No stream found for surface_id=282, will try to capture
2025-12-30 14:25:40,550 [INFO] π Auto-refreshing stream for surface_id=282...
2025-12-30 14:26:00,603 [INFO] π Token expiring in 4.7 minutes, auto-refreshing...
2025-12-30 14:26:00,603 [INFO] π Auto-refreshing stream for surface_id=160...
2025-12-30 14:26:04,298 [ERROR] β Auto-refresh failed: FAILED: Could not capture UTC Ice Sports Center - Rink #1
2025-12-30 14:26:04,298 [INFO] 192.168.0.104 - - [30/Dec/2025 14:26:04] "e[35me[1mGET /proxy/282 HTTP/1.1e[0m" 500 -
2025-12-30 14:26:09,184 [INFO] β
Auto-refresh succeeded!
2025-12-30 14:26:09,184 [INFO] πΊ Streaming surface_id=160: LA Kings Icetown - Rink A
2025-12-30 14:26:09,185 [INFO] URL: https://cdn-akamai-livebarn.akamaized.net/playlist.m3u8?venueuuid=a45c8d9c4dfe4c...
2025-12-30 14:26:09,187 [INFO] π Launching streamlink subprocess
2025-12-30 14:26:09,188 [INFO] β³ Waiting for first video chunk...
2025-12-30 14:26:09,838 [INFO] β
Got first chunk after 0.6s (8192 bytes)
2025-12-30 14:26:09,838 [INFO] 192.168.0.104 - - [30/Dec/2025 14:26:09] "GET /proxy/160 HTTP/1.1" 200 -
2025-12-30 14:26:10,528 [INFO] π Streamed 1000 chunks so far...
2025-12-30 14:26:29,389 [INFO] π Streamed 2000 chunks so far...
Thanks for the tip! I'll try to inspect the audio of a WHL game tonight.
The "LOVB Live" provider in EPlusTV was pulling the games they streamed on YouTube last season. Looks like that is going away for the upcoming season, but as you say, we should be able to pull some games via Victory. First such game in Jan. 8 so watch for an EPlusTV update around then.
Thanks.
Okay. This year, the games are on ESPN, USA and Victory+. I'll keep an eye out for the update. Thanks, again.
WHL games sound fine for me right now in VLC, and I donβt see anything unusual about the audio track if I record a sample with ffmpeg.
I wonder if there could be dynamic ad insertions with a different audio sample rate or something? Does it make a difference if you join a live game in progress?
Edit to add: now I have encountered some 404/502 errors in the EPlusTV Docker log and the stream stalled in VLC, briefly played wonky, then crashed. Do you see any errors in your EPlusTV Docker log?
Sorry I missed your prompt reply last night. I've been busy today and am just now getting the chance to catch up.
Yes, I think ad insertions are part of the problem. When I first starting seeing the issue, the first segment of the Stars pregame was always fine. After the first commercial break, however, the audio went bad. That was when I was still getting audio on Stars game. I haven't gotten any for about the last 2+ weeks/5 games or so. The WHL games are hit and miss for me. Sometimes they're fine and sometimes they're not.
I forgot to check my Docker logs but will try after tonight's Stars game.
I also see a LOVB match listed for tomorrow. I've set it to record and will see how well it does. Would it be possible to add a LOVB or Volleyball tag to those programs. Right now, it's listed as only at on Victory+.
Just pushed EPlusTV v4.14.10, adding LOVB Volleyball categories on Victory+, and removing the standalone LOVB provider.
