@jaidenc thanks
The container is independent of Fox TVE because it's getting national listings from Fox, a lot of us don't have channel 6002 anyway. That's why we're using the container and even if you have 6002 it won't have anything to do with what the container gets.
OK, it's supposed to list 4K broadcasts on any channel you can get with Fubo, including Fox.
I don't use it, but heard the Fox Sports app lists them too.
I know the Fox Sports website list events across different networks, but don't know if they specify 4K or not. Daily Sports TV Network Event Schedule | FOX Sports
I think I have a Paramount+ integration done... but I need to do a final test of it on Friday when the next live event is, but hopefully it'll be ready for NFL on Sunday...
Going to start on MSG Go tonight and see what I can figure out
Is that Paramount+ going to be added in the ESPN Plus Docker? or will it be a new docker install?
thanks
MSG playback is working, but we'll see if I can get the authentication working for it - they do their best to make it difficult...
It will be apart of the E+ docker
Nice
Is Paramount+ going to have super Bowl in 4K this year?
v2.1.0 is out as of a few minutes ago...
Added Paramount+ and MSG+ (MSG was a real pain to get working - hopefully it's all good now) as new options
I removed the USE_LINEAR option - it wasn't working like it should have
Hi, I am very excited to try out MSG+, I did get it working, but I'm getting some kind of conflict with my channel assignments. Any suggestions?
I tried to set ESPNPLUS=False and to just try an instance of the docker for MSG+. I have since stopped the other docker instance but still having the conflict. and still getting ~150 blank channels in my xml file.
Are you just referring to the channel logo? That's the project logo, not ESPN+. It doesn't change based on what is on that channel at any moment in time. MSG events won't be on dedicated channels
I have deleted the old container and have added the new container with the recent update and it is not working correctly any suggestions would be highly appreciated.
Looks like one of the configs got messed up somehow. Try deleting the espn_*.json files and see what that does
I tried no luck, I think it might be a permission issue
I had some problemes updating.
On the synology, i went ahead and ran the normal command that is part of the directions.
I got it started and then closed the terminal.
I went in to container manager and added the environment settings for Paramountplus and MLBTV.
I restarted and authorized ESPN and Paramountplus.
Watching some basketball from good old San diego.
I've been trying for 2 hours and so far no bueno
Can you delete the config directory and try again?
I have still same errors
I think I might have found the issue. I pushed a new update that should hopefully fix the issue
Thanks i will let you know if it works
