Okay, 2.1.13 is out and fixes the MLB.tv issues
BEFORE RUNNING THE UPDATE, YOU NEED TO REMOVE entries.db and schedule.db files so that it can rebuild the schedule!
All good here. Thanks for your great work!
Is it strictly a linear feed or how does it work?
I have the latest version installed, but when I add the Custom Channel to Channels DVR I get " invalid source url: Get "http://192.168.68.77:8091/channels.m3u": dial tcp 192.168.68.77:8091: connect: connection refused".
I have the port set to 8091 as a variable. Any idea why I'm getting this error?
If you put that URL in a browser, do you get the file? Or if you put the XML location in the browser does it show it?
Good question.
Both don't work. I get connection refused. Any ideas why?
Did you install portainer as suggested in the other thread? If so does it show up under containers in portainer?
Yo either didn’t specify the port correctly or the port is blocked.
Doesn't that come through with FOX? Or maybe not +?
I'll look at this
No, it's a seperate streaming subscription service.
I think the BTN station does (some stuff) through Fox but BTN+ is a separate paid service.
I guess it just depends on if it uses DRM, if someone wants to share their credentials, and if I get the time to reverse engineer it.
Can someone help a noob out? I can't get my docker command to work when I add MLB.tv. I get a "docker: invalid reference format" error.
Here is my command:
What am I doing wrong?
TYIA
All of your e- flags should be -e
Well, that's embarrassing.
Thanks. I always appreciate the support from the community.
Does fox4k still work. Anything new since last year? Will this method die in September with tve basically dying?
