Awesome. Hey if it works it works. Is fox 4k working okay everyone?
@m0ngr31 Did something change with BigTen+ with the last build? Getting an exception trying tonqcess propety name on a null value when the container loads.
Fox 4K is working fine.
Got 404 not found on the Arizona at BYU game, log shows the same chunklist problem.
Fix going up right now
Let me look at this and see if I can figure out the issue. Is it errors from fastly?
That fixed it! Thank you!
Yeah, looks like it's an issue with Fastly. They might be requiring different headers or something, so I've disabled that. Look for the update in the next 10 minutes or so
Yeah it's fastly.
Would it be possible to make the events end sooner? I usually have 90-120 min extra. So unless it was 4ot t is a bit too long. Would this break EPlusTV? Maybe this could be preferred in command line?
All NFL streams working great today except the browns/eagles game. I have Sunday ticket and logged in. Could this be a region lock thing? I live in Colorado but this game is not on local so a little confused by that. Otherwise working excellent! Appreciate the hard work.
Do you know what channel it's on?
I am able to watch Browns/Eagles and in Denver metro area. Maybe need to restart the container?
I actually love the additional built in time. I used to have so many games stop recording before they ended until this additional time was added. Adding the ability to adjust end times in the command line might be a good idea though.
Maybe just a custom script to have it lower and then we can add post padding? Maybe as a future option
is there a way to do a standard linear fox channel that is not solely reliable on live games. My TVE provider does not allow fox on channels. This would be a good way to get back the fox local channel network.
It doesn't work that way. If you want fox you need a streamer like YouTube tv/sat/cable etc.
I think that this is a question for @m0ngr31 to answer with all due respect
I could make this an option
Do FOX events work for you on this container? I'm using TVE login as well. It's hard to say, I'd have to check and see. Let me look at it
my bad. Late seeing this. But it was on fox. Every other game worked. Literally just that one. All day every other game worked. I'll see what happens next Sunday.
