Incredible work @m0ngr31! Love the new web UI!!
I'm having issues getting linear FOX station into the lineup. After authenticating through the Fox Sports portal, the only channels listed are FS1, FS2, B1G Network, and FOX Soccer Plus. I'm able to watch events like the World Series on my Mac in Safari and through the Shield in the FS1 app, but tvOS and iOS FS1 apps give me an error stating local FOX station is not in my TVE package (it is, but I've had numerous authentication issues with Fox Sports over the years on tvOS/iOS, so I'm not sure this is the real issue). Is there anything that can be done so that I can watch the World Series (what's possibly left of it anyhow) in 4K through Channels?
I know it's over now but you can't watch any Fox broadcasts if you're using linear. You have to set it up without linear to get the Fox broadcasts since it's not a dedicated channel available through Fox Sports.
If it's on FS1 you're good, you'll get it with our without linear on. Sucks the Yankees blew it btw.
Thanks for the response, but I'm a bit confused, as I've seen others on this thread reporting success with their local FOX station using EPlusTV (the post just prior to mine from @troyboyjbl had screenshots of the World Series)... Are you suggesting my setup or import of stations is incorrect? If so, how do I import FOX broadcasts into EPlusTV without enabling linear? Thanks again for any assistance you can provide.
So the linear stuff is to create a separate m3u and xmltv endpoints for dedicated linear channels (FS1, FS2, ect). It won't make your local fox affiliate a linear channel. I only grab sporting events from that channel. If you don't enable linear channels it'll just schedule events on those channels regularly with the other E+ events.
OK, so is this setup not correct then?
Appreciate your help and the work you've put into this.
Yes it should work fine
But I'm unable to receive the national FOX (non-FS1/FS2/etc) events. Sorry if I'm just completely whiffing on the where the disconnect is here... I'm sure I've likely just missed something crucial somewhere along the line, but where would an event like the World Series or a Saturday night B1G game that is broadcast via the national FOX feed be available in Channels in 4K (assuming it is available in 4K through other platforms of course)?
They should show up with the rest of whatever other providers events you have. If it can't schedule them, it might be an issue authorizing with TVE like your other apps show
To clarify, I get 2 Fox feeds when something like the World Series is on or a football game. One says something along the lines of National Fox or something. This one doesn't work. Just gives a Timeout message or something. The other feed which has my local Fox call letters in there like Fox KFXL works.
Ok, appreciate the comments @m0ngr31 @troyboyjbl . Looks like this is most likely an authorization issue. Unfortunately, not a surprise... a few years ago, my small, regional TVE provider (North State) was purchased by another small, regional ISP (Lumos). There have been authentication issues with FOX networks ever since. No other network gives me so much grief
If you go here on your PC browser: FOX Sports Live - Watch Live Sports, Shows, and Events Online | FOX Sports
Do your Fox (not FS1 or FS2) college & NFL football games show up for you to watch? If not, they won't show up on EPlus.
MSG is currently not working can you look into this, here is the error:
TypeError: Cannot read properties of undefined (reading 'contentUrl')
at GothamHandler. (/app/services/gotham-handler.ts:460:25)
at Generator.next ()
at fulfilled (/app/services/gotham-handler.ts:5:58)
at processTicksAndRejections (node:internal/process/task_queues:95:5)
Could not get stream information!
Failed to parse the stream
Could not get a playlist for channel #460. Please make sure there is an event scheduled and you have access to it
@m0ngr31 did you ever get DAZN working? @TaliandTony this is going to be your best bet for NFL Gamepass
So I upgraded to the latest build and really like the new web ui.
So I'm trying to watch the Penn State/OSU game in 4K.
Server is on Synology utilizing container manager.
Client is latest version of FTV Cube.
Native resolution is 3840x2160
Scaled resolution is 1920x1080
TV resolution says 3840x2160 /60
Any reason that the scaled resolution is lower than the native res. All settings on tv & cube are set to 4K.
In the channels app on the FTV under settings-playback-streaming quality- is it set to original on your current connection type?
The game is definitely playing in 4K hdr through eplus.
Yes, it is set to original.
To add: Powered up the ATV and it shows as 4K (both native and scaled). Must be getting inaccurate resolution on the FTV.
Says this on the Channels app on Shield too. Think it's a typo/bug? as the quality looks way better than any of the other channels...
@troyboyjbl is correct. I forgot about that bug. Here is the explanation
I believe this is going to change on ATV soon??
What do you mean? In what way?
