The Omaha Fox ATSC3 channel 142.1 is garbage :-1:
Lots of events going on today. I had to increase my NUM_OF_CHANNELS variable to 250. EPlusTV is currently using 212 of them. Incredible!
@m0ngr31 currently CBSSN does not work
Just checked Rice/Uconn on CBSSN. Working fine here.
It’s working here too — it’s the 177th channel in my EPlus channel collection lineup.
@m0ngr31 Is it possible to put the NUM_OF_CHANNELS setting in the web interface? Asking for a friend :upside_down_face:
Without logs it's hard to say, but maybe try reauthorizing. Or just to double check does your provider have CBSSN?
Possible. I'll look at adding it
@m0ngr31 the new web interface is great. Thanks for your hard work on this amazing project
Today's F1 Race is the Mexico City Grand Prix.
Channels displayed in multiview here are:
ABC: Mexico City Grand Prix
ESPN+ "F1: Mixed On-Board Camera"
ESPN+ "F1: Driver Tracker"
NFL RedZone
Channels DVR + EPlusTV + TiviMax on AppleTV make this setup possible and pretty fun to use!
I added Gotham Sports (YES and MSG networks) just now
Did you already push the update
Yep!
What are the new variables?
They are now toggles in the new web portal page.
<serverIP>:port
Talking about the new options for Gotham, I don't see it
There’s a toggle for GOTHAM in my screenshot, underneath NESM. If you don’t see it on your EPlus portal page then you haven’t updated OliveTin.
Once you enable that toggle and authenticate via your web browser, CDVR will see the two new channels: Yes and MSG
Got it, just had to re pull the image thanks.
Thanks for adding the version to the web interface @m0ngr31 :sunglasses:
Hello , awsome work on web interface , also any way I can set allways HIGHEST quality to play , currently using flosports , first it starts with some low and then it goes to top quality , anyway I can set it to be allways the best quality?
Delete
