Exclude Channels from Sources
Is it possible to remove 'some' channels from a Source? For example, there are a number of Spanish channels that I get from my OTA. I've been making some of the Series Pass with Advanced Options - very cool by the way. However, these Series Pass recordings on occasion pick up movies from the Spanish channels (which I don't want).. I did try to 'Hide' the channels from the Sources, but seems like these channels are still used in the recordings
I'm trying the multiple 'Excludes' options for an advanced pass - but thinking it'd be great if this could be done globally - basically to ignore some channels so they don't show up in Guide/Recordings/etc.
Sure. Go into the browser and select “Manage Lineup” for the source in question. You can then choose to ignore the channels you don’t want.
@blackngold75 - yeah i did try that "Manage Lineup" option.. However, it looks like these channels still show up in the Advanced Series Pass Recordings - i see some movies queued up.. Not sure if that is expected or maybe a bug (maybe the Series Pass needs to refresh after I've done the 'Manage Lineup' ?)
pause and restart the pass see if that helps
After you hide or unhide channels, you need to refresh the guide data.
DVR web admin UI
Settings > Guide Database > Maintenance :gear: Delete and Recreate Database
Thanks for the tips - all looks good now!
