Expand Quick Guide show info?
How do you expand the full show/episode description info from the quick guide? (Live tv)
I press down, to show the top bar, down again just selects the Record button.
Only way to read full episode description is to back out and go to the full guide? Which i don't want to do cause then I loose my timeline placement.
There is no way at this time. If it’s too long, it’s truncated, as you see.
Darn. Hope some day you can make it expandable or pop up a window or something to show full info while live.
