Experimental: Stream Links from the Guide via Custom Channels
If you are using an Android client:
Thanks. I'm using FireTV. I'm assuming that Peacock doesn't allow incoming links from apps on FireTV as well.
How do I determine the NBC stationid for WNBC NY? The I'm currently using stationid 10991 and it's showing me SIGN OFF in the guide for all times other than NBC News.
Indeed, Fire TV is based on Android.
http://127.0.0.1:8089/tms/stations/WNBC
Replace 127.0.0.1 with your server's IP address, unless you enter this URL on the same machine where your Channels DVR server is running, like I did.
This returns 8 results and I would say that there are 2 of them that are more likely to be the correct ones:
or
So try station ID 11705 or 20459.
Thank you. Station ID 11705 worked for WNBC NY. The /tms/stations/ is a very useful utility, thanks for sharing.
Is there a link available for Xfinity or the Tennis Channel?
Please forgive me if this has been answered before but I'm going between stream links (originally to use with NBC family ..opens nbc app but displays current sked in channels) works great ! and then Custom channels (Kister) YouTube .. but again channels (works great for my airport cams) ... trying not to confuse the two per say....
Goal:
to have channels display current grid for NBC (accomplished) others HBO SHOWTIME ESPN+ (but Im not using the container) I'm using the straight web based method..adding sources ... If shown how to do once I can replicate (NBC is example of that) other example is my LAX airplane YouTube ones..
I have sign-ins for Peacock and HBO and Showtime ESPN+ (aka not trying to steal anything) just want to display current grid with all that is showing, click on it and its ok if it opens that app (Using APPLE TV).. then plays (just like NBC does right now)... I've read the links. got into mini rabbit hole don't want to look at each show as a link but live grid (does that make sense ?)
so be much appreciated if someone could show the path (screen cap) if there is a way to replicate the NBC (which has source, txt, #extinf:1 channelid=xxx and so on) ESPN+ as well without having to use docker and add a source as custom channel??? (I know I'm mixing terms)...
appreciate any arrows right direction!
sparky
What would the full text be to add to text box for Netflix?
HBOwould be very helpful too…
This opens nbc app to cnbc and correct guide on grids for channel,displayed …
Below that I tried showtime?. But grid show showtime and doesn’t open app when clicked ..
Works finešŸ™‚
#EXTINF:-1 channel-id="cnbc" tvg-chno="6051" tvc-guide-stationid="58780",CNBC
nbctve://live/cnbc
Sort of works, appears on grid but no schedule nor opens showtime app…:frowning:
#EXTINF:-1 channel-id="showtime" tvg-chno="6312" tvc-guide-stationid="",Showtime
showtime://
Ok this was a great step forward for me (thank you)
I now can see the schedule on the grid, I know this is Hulu, how can I make open the MAX app for hbo or Showtime Anytime for Showtime?
@tmm1 Apple TV now has an MSG app. Can you provide the stream link to open this app / live feed? Is there a way for me to find links to open apps myself? (so I don't need to bother you)
This is what worked for me but I have not tried in a while.
Netflix is Nflx://
Not sure about Max you can try hbomax://
Amazon Prime is aiv://
@tmn1 if you don't mind sharing how to find the App stream link I would be happy to creating a running list for people. All of the ones I have complied have been from trial and error or scouring the forum.
not sure what you mean App Stream link.. but below are the ones from Hulu that work perfectly for guide data population... I just wish it would open each app (HBO, Showtime, Cinemax,) etc.. I feel im so close, I keep this because it tells me what's on on the guide if I do want to switch watching either to app or back to Uverse box....
I did Sub HBO for the hulu prefix but didn't work... did not open HBOMAX app...
follow up how do I get the other HBO channels ?
#EXTINF:-1 channel-id="HBOHD" tvg-chno="002" tvc-guide-stationid="19548",HBO
hbomax://
result is this guide (thats a great positive) but it does not open the app (HBOMAX) testing on iPhone.
here is the hulu items that produce accurate guide.. is this what you meant? To be clear, I do pay for all the access, and have it on uverse box. or each app as I desire to sign in .. but CHANNELS by far the best for ease of use, onscreen guide, use on the road, devices (apple). (really wish autotune feature... like a timer.. just a hint lads)... so I'm not trying to rip off anyone.. just really like channels and find it the. best guide display...
#EXTM3U
#EXTINF:-1 channel-id="5MAXHD" tvg-chno="5001" tvc-guide-stationid="59961",5 Star Max
hulu://watch/9ff633cc-f14d-4a7b-8ca3-3Ƅ8ef99def692
#EXTINF:-1 channel-id="ACMAXHD" tvg-chno="5002" tvc-guide-stationid="59948",Action Max East
hulu://watch/869d76bb-bff3-4ae6-a314-44b82b0d4283
#EXTINF:-1 channel-id="MAXHD" tvg-chno="8003" tvc-guide-stationid="34933",Cinemax East
hulu://watch/03cbd224-58c9-4c6b-80a9-757118bef480
#EXTINF:-1 channel-id="MOMAXHD" tvg-chno="5004" tvc-guide-stationid="59373",More Max
hulu://watch/e2ec75e8-1f8f-4569-b623-0d89346e231d
#EXTINF:-1 channel-id="MOVIEHD" tvg-chno="5005" tvc-guide-stationid="59963",Movie Max
hulu://watch/3e8a3675-a2bc-4146-8e8f-541f98c8a5eb
#EXTINF:-1 channel-id="OMAXHD" tvg-chno="5006" tvc-guide-stationid="59952",Outer Max
hulu://watch/3b6a972b-f2d0-4abf-9130-a671dc2277e3
#EXTINF:-1 channel-id="THMAXHD" tvg-chno="5007" tvc-guide-stationid="59954",Thriller Max
hulu://watch/90d3a3bb-88e8-4bfa-b1e7-7cedfaf6d3e6
#EXTINF:-1 channel-id="ACMXHDP" tvg-chno="5008" tvc-guide-stationid="59950",Action Max West
hulu://watch/4a2b756f-6b21-434b-a7a7-1512a94e0bac
#EXTINF:-1 channel-id="MAXHDP" tvg-chno="5009" tvc-guide-stationid="35975",Max West
hulu://watch/be997f44-f057-4d94-9f3b-535f08bec180
#EXTINF:-1 channel-id="MMAXPHD" tvg-chno="5010" tvc-guide-stationid="59375",More Max West
hulu://watch/301c445e-bc5e-4026-999c-c504c42882aa
#EXTINF:-1 channel-id="THMXHDP" tvg-chno="5011" tvc-guide-stationid="59959",Thriller Max West
hulu://watch/498a35f0-b253-4ecd-94d0-e8a1191a3030
#EXTINF:-1 channel-id="HBOHD" tvg-chno="5011" tvc-guide-stationid="19548",HBO
hulu://watch/58169e99-33c3-4444-a0ff-6c41d4262df9
#EXTINF:-1 channel-id="HBOHDP" tvg-chno="5012" tvc-guide-stationid="19566",HBO West
hulu://watch/0573ef6b-4a25-486d-a540-5d73c10270f0
#EXTINF:-1 channel-id="HBO2HD" tvg-chno="5013" tvc-guide-stationid="59368",HBO 2
hulu://watch/fa9e31d0-927c-4e4b-a2fd-8924fe3f4dff
#EXTINF:-1 channel-id="HBO2PHD" tvg-chno="5014" tvc-guide-stationid="59355",HBO 2 West
hulu://watch/9c922295-edc6-46c3-b444-5f37f003c998
#EXTINF:-1 channel-id="HBOSGHD" tvg-chno="5015" tvc-guide-stationid="59363",HBO Signature
hulu://watch/9008cdf7-83da-439d-974f-a496992c9ce5
#EXTINF:-1 channel-id="HBOSPHD" tvg-chno="5016" tvc-guide-stationid="59366",HBO Signature West
hulu://watch/9ea07fb9-aa0c-44bd-89cf-3e2bae8cede7
#EXTINF:-1 channel-id="HBOFHD" tvg-chno="5017" tvc-guide-stationid="59357",HBO Family
hulu://watch/8ebacca5-e390-43bd-9f99-285dfa0cfd70
#EXTINF:-1 channel-id="HBOFPHD" tvg-chno="5018" tvc-guide-stationid="59362",HBO Family West
hulu://watch/74e7af8e-4b1d-4094-8c29-cbe5cb88ebe4
#EXTINF:-1 channel-id="HBOCHD" tvg-chno="5019" tvc-guide-stationid="59839",HBO Comedy
hulu://watch/9752ad78-5ac9-423e-af81-31770075b5c2
#EXTINF:-1 channel-id="HBOCPHD" tvg-chno="5020" tvc-guide-stationid="59841",HBO Comedy West
hulu://watch/bfb0c7b6-a6d6-437f-b945-b67d5f0cd95e
#EXTINF:-1 channel-id="HBOZHD" tvg-chno="5021" tvc-guide-stationid="59845",HBO Zone
hulu://watch/0f0b3126-e8bb-4954-a972-53bed529e77f
#EXTINF:-1 channel-id="HBOZPHD" tvg-chno="5022" tvc-guide-stationid="59847",HBO Zone West
hulu://watch/1985733f-ef02-4b0d-910a-5a449602d683
#EXTINF:-1 channel-id="SHOWHD" tvg-chno="5023" tvc-guide-stationid="21868",Showtime
hulu://watch/e148d9fb-bf14-4416-bf2c-358dfaccb424
#EXTINF:-1 channel-id="SHOWHDP" tvg-chno="5024" tvc-guide-stationid="22532",Showtime West
hulu://watch/6aa76d95-7648-426f-9bee-a74b43e9e603
#EXTINF:-1 channel-id="SHO2HD" tvg-chno="5025" tvc-guide-stationid="58533",Showtime 2
hulu://watch/8cb68d8a-1848-4f47-8f5b-8b7398997962
#EXTINF:-1 channel-id="SHO2PHD" tvg-chno="5026" tvc-guide-stationid="60953",Showtime 2 West
hulu://watch/14975167-fff4-4aba-af3b-8f0e84ebff45
#EXTINF:-1 channel-id="SHOCSHD" tvg-chno="5027" tvc-guide-stationid="61001",Showcase
hulu://watch/384ec038-ecb7-4976-870c-fb1b4a03c0d6
#EXTINF:-1 channel-id="SHOCPHD" tvg-chno="5028" tvc-guide-stationid="61064",Showcase West
hulu://watch/8b79f214-1c4f-4db5-9ed1-e6fdf75eb2c2
#EXTINF:-1 channel-id="SHOBETH" tvg-chno="5029" tvc-guide-stationid="68340",Show BET
hulu://watch/d5a889ea-5637-44d8-b276-392b32fe445c
#EXTINF:-1 channel-id="SHOWXHD" tvg-chno="5030" tvc-guide-stationid="60947",Showtime Extreme
hulu://watch/cb6607ae-b4c8-41b3-a766-2adcbd7deb5c
#EXTINF:-1 channel-id="SHWXPHD" tvg-chno="5031" tvc-guide-stationid="60945",Showtime Extreme West
hulu://watch/014cdf47-5c63-4427-bdb9-ca192c41bf15
#EXTINF:-1 channel-id="WOMENHD" tvg-chno="5032" tvc-guide-stationid="68338",Show Women
hulu://watch/3870eec8-50e5-4861-a490-11d521d5fd1a
#EXTINF:-1 channel-id="NEXTHD tvg-chno="5033" tvc-guide-stationid="68342",Show Next
hulu://watch/d1133d3c-2d45-42e6-86f9-b7ee9cd89eec
#EXTINF:-1 channel-id="INDIEHD" tvg-chno="5034" tvc-guide-stationid="",Indie Plex
hulu://watch/8a93974e-ddc2-438a-a92f-1f7f0e9e7b1b
#EXTINF:-1 channel-id="RETROHD" tvg-chno="5035" tvc-guide-stationid="",Movie Plex
hulu://watch/6fb17a11-0301-4cd8-9cb8-046f9a54850a
#EXTINF:-1 channel-id="MPLEXHD" tvg-chno="5036" tvc-guide-stationid="",Retro Plex
hulu://watch/4e85ba1d-bde6-4fa3-80a1-72ae4b2c25f4
#EXTINF:-1 channel-id="STZHD" tvg-chno="5037" tvc-guide-stationid="34941",Starz East
hulu://watch/075f033e-9cf3-4c40-9970-840d1ff9c6a1
#EXTINF:-1 channel-id="STZHDP" tvg-chno="5038" tvc-guide-stationid="34949",Starz West
hulu://watch/af3cd83a-a8e4-4074-9784-3ac3f9717d27
#EXTINF:-1 channel-id="STRZCIH" tvg-chno="5039" tvc-guide-stationid="67236",Starz Cinema East
hulu://watch/83dabbe7-69ac-440b-b51d-e565534d2e18
#EXTINF:-1 channel-id="STZCHD" tvg-chno="5041" tvc-guide-stationid="34901",Starz Comedy East
hulu://watch/04ef79d3-b5b7-4e50-bd6e-989603d485c0
#EXTINF:-1 channel-id="STZEHD" tvg-chno="5043" tvc-guide-stationid="16311",Starz Edge East
hulu://watch/65f6254f-a806-4c4f-970e-5fef382dab75
#EXTINF:-1 channel-id="STZENHD" tvg-chno="5045" tvc-guide-stationid="36225",Starz Encore East
hulu://watch/462addfa-034f-426f-ac0c-50941d64fd13
#EXTINF:-1 channel-id="SZENHP" tvg-chno="5046" tvc-guide-stationid="67237",Starz Encore West
hulu://watch/f69a64b7-3569-4328-961f-c30d851b30f1
#EXTINF:-1 channel-id="SZEAHD" tvg-chno="5047" tvc-guide-stationid="72015",Starz Encore Action East
hulu://watch/faffea4e-8036-4923-aa33-55ee6224396b
#EXTINF:-1 channel-id="SZEBHD" tvg-chno="5049" tvc-guide-stationid="72014",Starz Encore Black East
hulu://watch/3665a7b8-8e68-447c-b514-32e5b5f8759b
#EXTINF:-1 channel-id="SZECLHD" tvg-chno="5051" tvc-guide-stationid="83404",Starz Encore Classic East
hulu://watch/f0838a1a-a5d5-42b4-b6cb-7901a152ed4c
#EXTINF:-1 channel-id="STZENFS" tvg-chno="5053" tvc-guide-stationid="102903",Starz Encore Family East
hulu://watch/40fbf1db-0d17-4d52-9291-0b0f59b98d14
#EXTINF:-1 channel-id="STZENSU tvg-chno="5055" tvc-guide-stationid="14766",Starz Encore Suspense East
hulu://watch/b43c6ccc-37c5-4d51-bdb0-e6a1290fcc6f
#EXTINF:-1 channel-id="STZEWSS" tvg-chno="5057" tvc-guide-stationid="102906",Starz Encore Western East
hulu://watch/18bf811b-e0ed-4eea-a5a6-b013ce60a828
#EXTINF:-1 channel-id="STRZIBH" tvg-chno="5059" tvc-guide-stationid="67235",Starz In Black East
hulu://watch/826f7a42-a831-47c9-b3d4-ac1e47c6ff39
#EXTINF:-1 channel-id="STZKHD" tvg-chno="5061" tvc-guide-stationid="57581,Starz Kids & Family East
hulu://watch/caa72305-aed8-4049-b6c7-5e52f5cc0175
Has anyone gotten NFL Network working?
How do you get the tv guide station id for different channels like FS1, Big10, etc?
Also, for reference:
I’m trying to create a stream link for nbc which takes me to Dateline on VOD. Using the link ā€œhttps://www.nbc.com/datelineā€ works perfectly in Channels on iOS/iPadOS but not on Apple TV. Any thoughts?
Forgive the noob question, but what is the complete link to open the NBA app and a specific team in TVOS? Is it something like gametime://live/suns? Or is it not possible?
Little help…upgraded to appletv 4K, now when I attempt to open a Hulu show ( nypd blue).. nothing happens.
Netflix opens the ā€œ would you like to open Netflix appā€
But it works fine on iPad and iPhone?
Any ideas beyond the standard , reboot aptv,
#EXTM3U
#EXTINF:-1 channel-id="NYPD Blue" tvg-chno="1.15" tvc-guide-stationid="2", NYPD BLUE
https://www.hulu.com/series/zzzzzzz
Yes I amended the link the link works fine opening the webpage of the series ..
Thx
