Experimental: Stream Links from the Guide via Custom Channels
Ive got things working. I especially like the new icon change in the guide. Great idea.
My RSN appears to work in the NBC app.
Will those also work with streamlinks?
If so , Is it possible for someone to give me the EXIF syntax for NBC sports boston? Anyone figure that one out?
I dont know the spellings for that particular channel.
That channel is working for me in the nbc app, so Im hoping to put it back in channels with the streamlink.
Thanks
In the iOS NBC app can you watch it, then click the share icon and share the link here?
While watching I used the share sheet and messaged the link to myself. This is what i got..
Check out @nbc Live
However, this only opens the app and doesnt jump to the channel I was watching.
Edit: interesting find. I turned of blocking on my pihole, and the link that was generated worked once.
Heres what i got after regenerating the link:
Check out @nbc Live
Edit: only worked once lol
Thanks for the notes, I'm learning a lot! Just curious, but how did you get the "GIBoX-XF5i0" for CNBC on YouTube TV? I'd love to experiment with other channels and apps to see how this all works, even with the caveats you've laid out.
rsn-boston
Not sure if that would work.
Like nbctve://live/rsn-boston
Tried this but didnt show up in manage lineup correctly
I don't know about logo or guide data. But did it at least launch the channel.
#EXTINF:-1 channel-id="nbcsn-boston" tvc-guide-stationid="49198",NBCSN BOSTON
Just start playing the live channel on the YTTV site and what I assume is their channel id shows up in the URL. Like https://tv.youtube.com/watch/GIBoX-XF5i0
If you would like your new Stream Link powered channels to slot in where they were as TV Everywhere channels, you can use this template. This will preserve the channel numbers and IDs, so that they'll show back up in the Channel Collections you had them in before:
#EXTINF:-1 channel-id="nbc" tvg-chno="6000" tvc-guide-stationid="10991",NBC
nbctve://live/nbc
#EXTINF:-1 channel-id="bravo" tvg-chno="6058" tvc-guide-stationid="58625",BRAVOHD
nbctve://live/bravo
#EXTINF:-1 channel-id="msnbc" tvg-chno="6050" tvc-guide-stationid="64241",MNBCHD
nbctve://live/msnbc
#EXTINF:-1 channel-id="cnbc" tvg-chno="6051" tvc-guide-stationid="58780",CNBC
nbctve://live/cnbc
#EXTINF:-1 channel-id="syfy" tvg-chno="6054" tvc-guide-stationid="58623",SYFYHD
nbctve://live/syfy
#EXTINF:-1 channel-id="usa" tvg-chno="6052" tvc-guide-stationid="58452",USAHD
nbctve://live/usa
#EXTINF:-1 channel-id="e" tvg-chno="6056" tvc-guide-stationid="61812",E
nbctve://live/e
#EXTINF:-1 channel-id="oxygen" tvg-chno="6060" tvc-guide-stationid="70522",Oxygen
nbctve://live/oxygen
#EXTINF:-1 channel-id="golf" tvg-chno="6159" tvc-guide-stationid="61854",GOLF
nbctve://live/golf
Well thats nice.. thank you!
Working on ipad and apple tv.
I have noticed some wonky behavior on the NBC app, where I need to close it in the app switcher before the station loads ..
It may not be just this channel - Ill test more
Here is a list of apps which should support deep links to live streams:
For others.
Ive noticed that I can avoid the wonkiness when opening the NBC app from the channels streamlink - and needing to use the app switcher to close the app before getting your station to load
Before you exit the NBC app while watching any live channel, go to the home page first before exiting the NBC app.
Next time you load the station from within channels , the streamlink it will load properly.
You could contact NBC support here and let them know: https://help.nbc.com/hc/en-us/requests/new?ticket_form_id=360001366074
This may work for NFL:
#EXTM3U
#EXTINF:-1 channel-id="nfl" channel-number="6192" tvc-guide-stationid="45399",NFL
nflnetwork://watch/nfl-network-live
FYI, on both my Shield and Android phone, I get the 503 error code that others have received. Is this new feature only for Apple devices at this time? Thanks.
It requires the beta update on your android device.
Interesting, so perhaps we could mix and match? Like choosing a live show on MSNBC would launch the MSNBC app, choosing a live show on CNBC would launch the CNBC app, and choosing any of the other NBCU Stream Links would launch the NBC app?
The tvc-guide-stationid for MSNBC is non-HD unlike all the others, so I changed it to 64241. Otherwise, perfect. Thank you!
nbctve://live/msnbc
Sure, you pick the links you want to use. the nbctve:// links launch the NBC app.
