Sorry for the delay, just had a chance to test this out today, works fine on a macos install but still fails in docker. I also tried switching from the nvidia docker to the tve docker with no difference.
Question for those having problems as I often do. Are you using a password manager or copy/pasting your login info? I just tried by manually filling it and it worked finally so I’m wondering if that’s coincidence or the issue.
Also admin- please add edit password option (if feasible) for the future as preciously requested. Many of us change passwords frequently.
I've been experiencing this same frustrating issue since Sunday, too (saw it about 3 weeks ago when a 48 hour pause fixed it(. Neither of the last two betas helped (currently 2020.11.11.0618 on a Synology x64). Each time I see the same invalid password screenshot, with a subsequent login directly to Comcast prompting for a password reset. I've waited the suggested 48 hours both times. This feels as though it really is a case of channels remembering and sending the prior password, but I've seen no way to confirm this. Is there a particular location where this password is stashed in a config file (plaintext), or can we at least force wipe this file to rule out a bad password attempt as opposed to some secret Comcast voodoo?
Log snippet:
2020/11/12 15:15:34.342296 [TVE] Auth starting for Comcast_SSO as {comcast primary username (NOT email)}
2020/11/12 15:15:34.342389 [TVE] action=auth mvpd=Comcast_SSO requestor=nbcentertainment
2020/11/12 15:15:34.494268 [TVE] action=mock
2020/11/12 15:15:34.495390 [TVE] action=navigate url=https://sp.auth.adobe.com/adobe-services/authenticate/saml?noflash=true&mso_id=Comcast_SSO&requestor_id=nbcentertainment&no_iframe=true&domain_name=adobe.com&redirect_url=https%3A%2F%2Fsp.auth.adobe.com%2Fadobe-services%2FcompletePassiveAuthentication
2020/11/12 15:15:34.497248 [TVE] action=request type=Document method=GET url=https://sp.auth.adobe.com/adobe-services/authenticate/saml
2020/11/12 15:15:34.832812 [TVE] action=request type=Document method=GET url=https://oauth.xfinity.com/oauth/authorize
2020/11/12 15:15:35.231069 [TVE] action=request type=Document method=GET url=https://login.xfinity.com/login
2020/11/12 15:15:35.231123 [TVE] action=auth_domain domain=login.xfinity.com
2020/11/12 15:15:35.547837 [TVE] action=wait_for_page
2020/11/12 15:15:43.291758 [TVE] action=page_ready
2020/11/12 15:15:43.291819 [TVE] action=wait_for_page done=true reason=page_ready
2020/11/12 15:15:43.291850 [TVE] action=fill_form u={comcast username}
2020/11/12 15:15:43.701725 [TVE] action=request type=Document method=POST url=https://login.xfinity.com/login
2020/11/12 15:15:43.706000 [TVE] action=wait_for_auth
2020/11/12 15:15:44.117075 [TVE] action=error_response type=Image error=net::ERR_ABORTED
2020/11/12 15:15:51.096327 [TVE] action=page_ready
2020/11/12 15:15:55.706177 [TVE] action=auth_timed_out
2020/11/12 15:15:55.706251 [TVE] action=screenshot
2020/11/12 15:15:55.893565 [TVE] action=screenshot size=50065
2020/11/12 15:15:55.894298 [TVE] action=capture_html
2020/11/12 15:15:55.902502 [TVE] action=capture_html size=30199
2020/11/12 15:15:55.928178 [TVE] Auth failed for Comcast_SSO: chrome auth_timed_out
Update: THIS time, a 2 day wait worked and Xfinity via TVE is now authenticating. I don't know if it was the wait, or the fact that I changed my password back a second time to the original one from before Thursday's failure. This is really getting old.
Yup, I havn't been able to get it working again despite numerous password resets and waiting two days. It's forcing me to cancel my sub and look for another solution.
I get this error when trying to add Xfinity. The user account is just a viewer account, so I'm guessing I need the primary user to help me past this screen elsewhere, perhaps signing into their account?
Please click Support > Submit Diagnostics on the dvr web UI
If you go to nbc.com/live and sign in there does the same thing show up? Can you dismiss it there then sign into the dvr again?
I was able to get around it by using chrome on my android phone for the setup while simultaneously signing in the stream app for android tv. How related all those things are with it working are above my skill level, but it worked.
I have the same problem. I can sign in to nbc.com/live but I cannot Verify Xfinity.
I submitted my Diagnostics 12/01/2020.
