I had an issue where we lost power and I had several shows that failed to record. When I manually search through the upcoming episodes to try and re-record them, it allows me to select record from the option but it doesn’t record. I have to manually go to the web browser interface and select each failed recording and delete it. Then I have to go back and find the failed recordings at another time and select them to record again.
Am I doing this wrong or is that how it’s supposed to work? Can it be set to automatically record the next airing when one fails?
