HassOS has code to get the Argon One case fan to work on their stripped down OS that Channels based their OS on. Any chance we could see some kind of implementation for Channels Raspberry Pi image?
The reason people like this case is because it is the ONLY case that uses the case as a heatsink AND has room for internal storage with the M.2 add-on. There is now a NVMe version too. Plenty of cases do one or the other. Internal storage is important for Channels because it cuts one separate box out of the setup. You still need a HDHomerun and an Apple TV. So only 3 separate boxes vs 4 to run this setup.
Here is one of the solutions available.
